cgal-discuss - Re: [cgal-discuss] 答复: Convex hull errors
  • To:
  • Subject: Re: [cgal-discuss] 答复: Convex hull errors
  • Date: Mon, 20 Dec 2010 11:43:44 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type; b=EcfJLmhEXmqLevnnQXb39gN0jUluAKNMmgRhiK+qTj9B8Lrsj3jexfhW1p+R5rEYs5 9xFvJoKBOLRbLm1cdm2t1sS/6g+WT4pvCObgaOEtALdRGwlCgS+Hlp3raR6pySu8hNMt Q2OijAZda62VLIjxADrph8u9sf9G+z/vqLkXM=
In the meantime I worked out an example of how to use the
Delaunay_triangulation_3 and Polyhedron_incremental_builder_3 to do the same job than documented functions in the case the input points are not contained in a plane.
S.
johnzjq wrote:
<style> <!-- /* Font Definitions */ @font-face {font-family:宋体; panose-1:2 1 6 0 3 1 1 1 1 1;} @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} @font-face {font-family:"\@宋体"; panose-1:2 1 6 0 3 1 1 1 1 1;} @font-face {font-family:Tahoma; panose-1:2 11 6 4 3 5 4 4 2 4;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {margin:0cm; margin-bottom:.0001pt; font-size:12.0pt; font-family:"Times New Roman","serif";} a:link, span.MsoHyperlink {mso-style-priority:99; color:blue; text-decoration:underline;} a:visited, span.MsoHyperlinkFollowed {mso-style-priority:99; color:purple; text-decoration:underline;} span.EmailStyle17 {mso-style-type:personal-reply; font-family:"Calibri","sans-serif"; color:#1F497D;} .MsoChpDefault {mso-style-type:export-only;} @page WordSection1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt;} div.WordSection1 {page:WordSection1;} --> </style>
That’s very kind of you! I will try it by myself using newly updated Qhull.
John
View message @ http://cgal-discuss.949826.n4.nabble.com/Convex-hull-errors-tp3078363p3095161.html <http://cgal-discuss.949826.n4.nabble.com/Convex-hull-errors-tp3078363p3095161.html?by-user=t>
To unsubscribe from Convex hull errors, click here <http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=3078363&code=am9obnpqcUBnbWFpbC5jb218MzA3ODM2M3wtMTE5MjU5NDk4Nw==&by-user=t>.
View this message in context: 答复: Convex hull errors <http://cgal-discuss.949826.n4.nabble.com/Convex-hull-errors-tp3078363p3095187.html>
Sent from the cgal-discuss mailing list archive <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
#include <CGAL/Polyhedron_incremental_builder_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Delaunay_triangulation_3.h>
#include <fstream>
// A modifier creating a triangle with the incremental builder.
template <class HDS,class Triangulation>
class Build_convex_hull_from_triangulation_3 : public CGAL::Modifier_base<HDS> {
  typedef std::map<typename Triangulation::Vertex_handle,unsigned> Vertex_map;
  const Triangulation& t;
  template <class Builder>
  static unsigned get_vertex_index( Vertex_map& vertex_map,
                                    typename Triangulation::Vertex_handle vh,
                                    Builder& builder,
                                    unsigned& vindex)
    std::pair<typename Vertex_map::iterator,bool>
      res=vertex_map.insert(std::make_pair(vh,vindex));
    if (res.second){
      builder.add_vertex(vh->point());
      ++vindex;
    return res.first->second;
public:
  Build_convex_hull_from_triangulation_3(const Triangulation& t_):t(t_)
    CGAL_assertion(t.dimension()==3);
  void operator()( HDS& hds) {
    // Postcondition: `hds' is a valid polyhedral surface.
    typedef typename HDS::Vertex   Vertex;
    typedef typename Vertex::Point Point;
    CGAL::Polyhedron_incremental_builder_3<HDS> B( hds, true);
    std::vector<typename Triangulation::Cell_handle>  ch_facets;
    Vertex_map vertex_map;
    t.incident_cells(t.infinite_vertex(),std::back_inserter(ch_facets));
    std::size_t nb_facets=ch_facets.size();
    //start the surface
    B.begin_surface( nb_facets, nb_facets);
    unsigned vindex=0;
    for (typename std::vector<typename Triangulation::Cell_handle>::const_iterator it=
          ch_facets.begin();it!=ch_facets.end();++it)
      unsigned ifv_index= (*it)->index(t.infinite_vertex());
      bool is_odd=ifv_index%2==0;
      unsigned i0=get_vertex_index(vertex_map,(*it)->vertex((ifv_index + (is_odd?3:1) )%4),B,vindex);
      unsigned i1=get_vertex_index(vertex_map,(*it)->vertex((ifv_index + 2            )%4),B,vindex);
      unsigned i2=get_vertex_index(vertex_map,(*it)->vertex((ifv_index + (is_odd?1:3) )%4),B,vindex);
      B.begin_facet();
      B.add_vertex_to_facet( i0 );
      B.add_vertex_to_facet( i1 );
      B.add_vertex_to_facet( i2 );
      B.end_facet();
    B.end_surface();
template <class PointIterator,class Polyhedron>
void make_convex_hull_3(PointIterator begin,PointIterator end,Polyhedron& P)
  typedef typename CGAL::Kernel_traits<
    typename std::iterator_traits<PointIterator>::value_type
  >::Kernel                                                      Kernel;
  typedef typename Polyhedron::HalfedgeDS                        HalfedgeDS;
  typedef typename CGAL::Delaunay_triangulation_3<Kernel>        Triangulation;
  Triangulation dt3(begin,end);
  Build_convex_hull_from_triangulation_3<HalfedgeDS,Triangulation> get_chull(dt3);
  P.delegate( get_chull );
  CGAL_assertion( P.is_pure_triangle() );
typedef CGAL::Exact_predicates_inexact_constructions_kernel     Kernel;
typedef CGAL::Polyhedron_3<Kernel>                              Polyhedron;
int main() {
  std::ifstream iFile;
  iFile.open("1.off");
  if (!iFile.is_open())
    std::cerr<<"Error opening file\n";
    exit(EXIT_FAILURE);
  Polyhedron P_tmp;
  iFile >> P_tmp;
  iFile.close();
  Polyhedron chull;
  make_convex_hull_3(P_tmp.points_begin(),P_tmp.points_end(),chull);
  std::ofstream out("out.off");
  out << chull;
  return 0;
