- To:
- Subject: Re: [cgal-discuss] Questions about interpolation
- Date: Mon, 27 Dec 2010 09:29:30 +0100
Jatin Relan wrote:
Hi all,Is your mesh a surface or volume mesh? Interpolation method in CGAL are only available in 2D and for 2D surfaces.
I have a question about interpolation on a mesh.
(see http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Interpolation/Chapter_main.html)
Have a look at the surface mesh simplification package here:
Q.1 Say, I have a mesh with an attribute values for some of the vertices (a
subset), is there any interpolation method in CGAL to interpolate the
attribute values for all the remaining vertices (where I didn't had data)?
Q.2 Which interpolation method it would use?
Q.3 Say I have a mesh with given set of vertices, I choose a subset of
vertices. Now I want to remesh (or decimate) the surface such that the new
surface would have total number of vertices as only those vertices which I
chose. Is there any method to do that in CGAL?
Look at "Example with edges marked as non-removable". Marking all edges
incident to your marked vertices as non-removable should do what you
want.
Do you mean smoothing the surface and maintain the tetrahedral mesh?
Q.4 Is it possible to smooth a tetrahedral mesh in CGAL?
Thanks very much in advance.
Cheers,
Jatin
- [cgal-discuss] Convex hull errors, johnzjq, 12/08/2010
- Re: [cgal-discuss] Convex hull errors, Sebastien Loriot (GeometryFactory), 12/09/2010
- [cgal-discuss] Re: Convex hull errors, johnzjq, 12/09/2010
- Re: [cgal-discuss] Re: Convex hull errors, Sebastien Loriot (GeometryFactory), 12/09/2010
- [cgal-discuss] Re: Convex hull errors, johnzjq, 12/10/2010
- Re: [cgal-discuss] Re: Convex hull errors, Sebastien Loriot (GeometryFactory), 12/20/2010
- [cgal-discuss] 答复: Convex hull errors, johnzjq, 12/20/2010
- Re: [cgal-discuss] 答复: Convex hull errors, Sebastien Loriot (GeometryFactory), 12/20/2010
- [cgal-discuss] Questions about interpolation, Jatin Relan, 12/20/2010
- Re: [cgal-discuss] Questions about interpolation, Sebastien Loriot (GeometryFactory), 12/27/2010
- Re: [cgal-discuss] Questions about interpolation, Jatin Relan, 12/29/2010
- Re: [cgal-discuss] Questions about interpolation, Sebastien Loriot (GeometryFactory), 12/29/2010
- [cgal-discuss] Re: re: Convex hull errors, johnzjq, 12/20/2010
