cgal-discuss - [cgal-discuss] Questions about interpolation
  • To:
  • Subject: [cgal-discuss] Questions about interpolation
  • Date: Mon, 20 Dec 2010 13:36:31 +0100 (CET)
#include <CGAL/Polyhedron_incremental_builder_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Delaunay_triangulation_3.h>
#include <fstream>
// A modifier creating a triangle with the incremental builder.
template <class HDS,class Triangulation>
class Build_convex_hull_from_triangulation_3 : public CGAL::Modifier_base<HDS> {
  typedef std::map<typename Triangulation::Vertex_handle,unsigned> Vertex_map;
  const Triangulation& t;
  template <class Builder>
  static unsigned get_vertex_index( Vertex_map& vertex_map,
                                    typename Triangulation::Vertex_handle vh,
                                    Builder& builder,
                                    unsigned& vindex)
    std::pair<typename Vertex_map::iterator,bool>
      res=vertex_map.insert(std::make_pair(vh,vindex));
    if (res.second){
      builder.add_vertex(vh->point());
      ++vindex;
    return res.first->second;
public:
  Build_convex_hull_from_triangulation_3(const Triangulation& t_):t(t_)
    CGAL_assertion(t.dimension()==3);
  void operator()( HDS& hds) {
    // Postcondition: `hds' is a valid polyhedral surface.
    typedef typename HDS::Vertex   Vertex;
    typedef typename Vertex::Point Point;
    CGAL::Polyhedron_incremental_builder_3<HDS> B( hds, true);
    std::vector<typename Triangulation::Cell_handle>  ch_facets;
    Vertex_map vertex_map;
    t.incident_cells(t.infinite_vertex(),std::back_inserter(ch_facets));
    std::size_t nb_facets=ch_facets.size();
    //start the surface
    B.begin_surface( nb_facets, nb_facets);
    unsigned vindex=0;
    for (typename std::vector<typename Triangulation::Cell_handle>::const_iterator it=
          ch_facets.begin();it!=ch_facets.end();++it)
      unsigned ifv_index= (*it)->index(t.infinite_vertex());
      bool is_odd=ifv_index%2==0;
      unsigned i0=get_vertex_index(vertex_map,(*it)->vertex((ifv_index + (is_odd?3:1) )%4),B,vindex);
      unsigned i1=get_vertex_index(vertex_map,(*it)->vertex((ifv_index + 2            )%4),B,vindex);
      unsigned i2=get_vertex_index(vertex_map,(*it)->vertex((ifv_index + (is_odd?1:3) )%4),B,vindex);
      B.begin_facet();
      B.add_vertex_to_facet( i0 );
      B.add_vertex_to_facet( i1 );
      B.add_vertex_to_facet( i2 );
      B.end_facet();
    B.end_surface();
template <class PointIterator,class Polyhedron>
void make_convex_hull_3(PointIterator begin,PointIterator end,Polyhedron& P)
  typedef typename CGAL::Kernel_traits<
    typename std::iterator_traits<PointIterator>::value_type
  >::Kernel                                                      Kernel;
  typedef typename Polyhedron::HalfedgeDS                        HalfedgeDS;
  typedef typename CGAL::Delaunay_triangulation_3<Kernel>        Triangulation;
  Triangulation dt3(begin,end);
  Build_convex_hull_from_triangulation_3<HalfedgeDS,Triangulation> get_chull(dt3);
  P.delegate( get_chull );
  CGAL_assertion( P.is_pure_triangle() );
typedef CGAL::Exact_predicates_inexact_constructions_kernel     Kernel;
typedef CGAL::Polyhedron_3<Kernel>                              Polyhedron;
int main() {
  std::ifstream iFile;
  iFile.open("1.off");
  if (!iFile.is_open())
    std::cerr<<"Error opening file\n";
    exit(EXIT_FAILURE);
  Polyhedron P_tmp;
  iFile >> P_tmp;
  iFile.close();
  Polyhedron chull;
  make_convex_hull_3(P_tmp.points_begin(),P_tmp.points_end(),chull);
  std::ofstream out("out.off");
  out << chull;
  return 0;
