cgal-discuss - Re: [cgal-discuss] routine Stream_line_2
  • To:
  • Subject: Re: [cgal-discuss] routine Stream_line_2
  • Date: Mon, 20 Dec 2010 18:06:08 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=JEeVPWbh6B9y1R5VEhcGODgNv3T0+B2m9nsfzc66DtGGbmvvgb0EsWvwXVAnMsc9sX YMhCdaQ3tccrzGStAMgjIQBnyJVz9gTc8bVef+J1YQSELs19lSDO/saHb4Z7Fwbp21NG rO6AgFA7zl/5RTlYjr06kIDzs5e38/iLZqiKY=
Kessler wrote:
I have asked the list several times about the streamline routine Stream_line_2
with no responses. Am I the only one who uses this routine?
I can run the streamline example code (stl_regular_field.cpp), and modify it
to
plot my data, with constant values for density and separation. But I don't see
how to modify the code to find streamlines with separation distance as a
function of velocity (i.e. the distance between streamlines is proportional to
the velocity magnitude). As far as I can see the streamline separation is
controlled by the two *constant* values dSep and dRat, but these only change
the density uniformly over the field. How to make these functions of the flow
velocity magnitude, as is typically done in meteorology?
After digging a little bit into the code, I did not find a constructor
to set the separation distance as a function. The authors of the paper
probably used an experimental version that is different from the version
published in CGAL.
I will try to get more information from the author of the package and let you know.
S.
For an example of what I am trying to do, see Fig.7 of Mebarki, Alliez and
Devillers: "Farthest point seeding for efficient placement of streamlines".
IEEE Visualization, 2005.
Any suggestions appreciated.
Billy K
