- To: "" <>
- Subject: RE: [cgal-discuss] 2d weighted alpha shapes - various radii
- Date: Tue, 4 Jan 2011 21:11:09 +0000
- Accept-language: en-US, de-CH
Thank you for your quick reply, Andreas!
I only used the 3d weighted alpha shapes before. There you could first create
a triangulation and a weight for each point (weight = radius^2). With the
triangulation I could create the alpha shapes. I am wondering if it is
possible to do the same in 2d. I did not find this in the online manual for
2d alhpa shapes and in the example all weigths are the same. I tried to use
the 3d code with a data set in 2d but it did not work.
Thanks again!
max
Max Eggersdorfer
Particle Technology Laboratory, ETH Zürich
Sonneggstrasse 3, ML F 18
CH-8092 Zurich (Switzerland)
+41 44 632 39 52
________________________________________
Sent: Tuesday, January 04, 2011 8:59 PM
To:
Subject: Re: [cgal-discuss] 2d weighted alpha shapes - various radii
hi maximilian,
the alpha has to do with the ball moving around.
if all radii are the same you obtain something
almost identical to just points.
andreas
On 04/01/2011 19:36, Eggersdorfer Maximilian wrote:
> Hello Everybody,
> I try to use the 2d weighted alpha shapes to calculate the projected
> surface area of a union of balls. As far as I understand the alpha value is
> the same for all points (all circles have the same radius). Has anybody
> used 2d weighted alpha shapes already with various radii for different
> points?
> Thanks in advance!
> Best
> Max
> Max Eggersdorfer
> +41 44 632 39 52
> <mailto:>
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: ++33.492.954.912 skype: andreas.fabri
- [cgal-discuss] 2d weighted alpha shapes - various radii, Eggersdorfer Maximilian, 01/04/2011
- Re: [cgal-discuss] 2d weighted alpha shapes - various radii, Andreas Fabri, 01/04/2011
- RE: [cgal-discuss] 2d weighted alpha shapes - various radii, Eggersdorfer Maximilian, 01/04/2011
- Re: [cgal-discuss] 2d weighted alpha shapes - various radii, Monique Teillaud, 01/05/2011
- RE: [cgal-discuss] 2d weighted alpha shapes - various radii, Eggersdorfer Maximilian, 01/05/2011
