- To:
- Subject: Re: [cgal-discuss] 2d weighted alpha shapes - various radii
- Date: Wed, 05 Jan 2011 08:20:26 +0100
Dear Max,
The 2D and 3D alpha shapes are working the same way. You can put a regular triangulation as template parameter of the alpha shape class, and get a weighted alpha shape. There, input points are weighted, and weights can actually be different.
Best regards,
Monique
Eggersdorfer Maximilian wrote:
Thank you for your quick reply, Andreas!
I only used the 3d weighted alpha shapes before. There you could first create a triangulation and a weight for each point (weight = radius^2). With the triangulation I could create the alpha shapes. I am wondering if it is possible to do the same in 2d. I did not find this in the online manual for 2d alhpa shapes and in the example all weigths are the same. I tried to use the 3d code with a data set in 2d but it did not work.
Thanks again!
max
Max Eggersdorfer
Particle Technology Laboratory, ETH Zürich
Sonneggstrasse 3, ML F 18
CH-8092 Zurich (Switzerland)
+41 44 632 39 52
________________________________________
Sent: Tuesday, January 04, 2011 8:59 PM
To:
hi maximilian,
the alpha has to do with the ball moving around.
if all radii are the same you obtain something
almost identical to just points.
andreas
On 04/01/2011 19:36, Eggersdorfer Maximilian wrote:
Hello Everybody,
I try to use the 2d weighted alpha shapes to calculate the projected surface
area of a union of balls. As far as I understand the alpha value is the same
for all points (all circles have the same radius). Has anybody used 2d
weighted alpha shapes already with various radii for different points?
Thanks in advance!
Best
Max
Max Eggersdorfer
+41 44 632 39 52
<mailto:>
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: ++33.492.954.912 skype: andreas.fabri
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
- [cgal-discuss] 2d weighted alpha shapes - various radii, Eggersdorfer Maximilian, 01/04/2011
- Re: [cgal-discuss] 2d weighted alpha shapes - various radii, Andreas Fabri, 01/04/2011
- RE: [cgal-discuss] 2d weighted alpha shapes - various radii, Eggersdorfer Maximilian, 01/04/2011
- Re: [cgal-discuss] 2d weighted alpha shapes - various radii, Monique Teillaud, 01/05/2011
- RE: [cgal-discuss] 2d weighted alpha shapes - various radii, Eggersdorfer Maximilian, 01/05/2011
