cgal-discuss - RE: [cgal-discuss] 2d weighted alpha shapes - various radii
  • To: "" <>
  • Subject: RE: [cgal-discuss] 2d weighted alpha shapes - various radii
  • Date: Wed, 5 Jan 2011 09:17:52 +0000
  • Accept-language: en-US, de-CH
Dear Monique,
thank you for your reply. It works as you described.
Thank you
Max
Max Eggersdorfer
Particle Technology Laboratory, ETH Zürich
Sonneggstrasse 3, ML F 18
CH-8092 Zurich (Switzerland)
+41 44 632 39 52
________________________________________
Sent: Wednesday, January 05, 2011 8:20 AM
To:
Subject: Re: [cgal-discuss] 2d weighted alpha shapes - various radii
Dear Max,
The 2D and 3D alpha shapes are working the same way. You can put a
regular triangulation as template parameter of the alpha shape class,
and get a weighted alpha shape. There, input points are weighted, and
weights can actually be different.
Best regards,
Monique
Eggersdorfer Maximilian wrote:
> Thank you for your quick reply, Andreas!
> I only used the 3d weighted alpha shapes before. There you could first
> create a triangulation and a weight for each point (weight = radius^2).
> With the triangulation I could create the alpha shapes. I am wondering if
> it is possible to do the same in 2d. I did not find this in the online
> manual for 2d alhpa shapes and in the example all weigths are the same. I
> tried to use the 3d code with a data set in 2d but it did not work.
> Thanks again!
> max
> Max Eggersdorfer
> +41 44 632 39 52
> From: Andreas Fabri
> Sent: Tuesday, January 04, 2011 8:59 PM
> To:
> hi maximilian,
> the alpha has to do with the ball moving around.
> if all radii are the same you obtain something
> almost identical to just points.
> andreas
> On 04/01/2011 19:36, Eggersdorfer Maximilian wrote:
>> Hello Everybody,
>> I try to use the 2d weighted alpha shapes to calculate the projected
>> surface area of a union of balls. As far as I understand the alpha value
>> is the same for all points (all circles have the same radius). Has anybody
>> used 2d weighted alpha shapes already with various radii for different
>> points?
>> Thanks in advance!
>> Best
>> Max
>> Max Eggersdorfer
>> +41 44 632 39 52
>> <mailto:>
> Andreas Fabri, PhD
> Chief Officer, GeometryFactory
> Editor, The CGAL Project
> phone: ++33.492.954.912 skype: andreas.fabri
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
