cgal-discuss - Re: [cgal-discuss] is there a size limit for edge_collapse surface mesh decimation?
  • To:
  • Subject: Re: [cgal-discuss] is there a size limit for edge_collapse surface mesh decimation?
  • Date: Thu, 6 Jan 2011 09:48:55 -0500
Hi Sebastien,
thanks for your kind reply. This is a good place to start.
Best wishes,
Michel
On Thu, Jan 6, 2011 at 2:59 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
Michel Audette wrote:
Dear CGAL developers,
I'm trying to use the edge_collapse() surface mesh decimation method in conjunction with the output, in off format, of GNU Triangulated Surface Library, to compare the results of VTK's Marching Cubes with GTS' Dual Marching Tetrahedrons. The GTS surface is a little denser than the VTK Marching Cubes result: 18M polygons vs 7M polygons, and currently does not seem to produce an output..
michel@michel-desktop:~/simProject/NeuroSurgSim/SimplexDecimationBuild/bin$ ./OffMarchingCubesCGALDecimate brainDualMarchingTet.off 0.002 brainDualMarchingTet_0_002
Reading polyhedron ...
   .... done.
Finished...
0 edges removed.
0 final edges.
The 0 final edges is strange. Maybe you should check that the input has been correctly read.
Is there a verbose way of using the function that can provide hints?
Before any CGAL include file add
#define CGAL_SURFACE_SIMPLIFICATION_ENABLE_TRACE 4
void Surface_simplification_external_trace( std::string s )
 static std::ofstream out("log.txt");
 out << s << std::endl ;
and in the main before calling simplification code:
internal::cgal_enable_ecms_trace = true ;
Also you need to use CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_with_id_3>
as polyhedron type.
you will then have a log.txt. I will provide no support on
information in this log file. You can play with the value of
CGAL_SURFACE_SIMPLIFICATION_ENABLE_TRACE to print more or less
information (the greater the value is, more information you will get)
S.
Does 18M faces seem like a lot for edge_collapse to process?
Best wishes,
Michel
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
