[cgal-discuss] is there a size limit for edge_collapse surface mesh decimation?
- To:
- Subject: [cgal-discuss] is there a size limit for edge_collapse surface mesh decimation?
- Date: Wed, 5 Jan 2011 16:34:22 -0500
Dear CGAL developers,
I'm trying to use the edge_collapse() surface mesh decimation method in conjunction with the output, in off format, of GNU Triangulated Surface Library, to compare the results of VTK's Marching Cubes with GTS' Dual Marching Tetrahedrons. The GTS surface is a little denser than the VTK Marching Cubes result: 18M polygons vs 7M polygons, and currently does not seem to produce an output..
michel@michel-desktop:~/simProject/NeuroSurgSim/SimplexDecimationBuild/bin$ ./OffMarchingCubesCGALDecimate brainDualMarchingTet.off 0.002 brainDualMarchingTet_0_002
Reading polyhedron ...
.... done.
Finished...
0 edges removed.
0 final edges.
Is there a verbose way of using the function that can provide hints? Does 18M faces seem like a lot for edge_collapse to process?
Best wishes,
Michel
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
- [cgal-discuss] is there a size limit for edge_collapse surface mesh decimation?, Michel Audette, 01/05/2011
- Re: [cgal-discuss] is there a size limit for edge_collapse surface mesh decimation?, Sebastien Loriot (GeometryFactory), 01/06/2011
- Re: [cgal-discuss] is there a size limit for edge_collapse surface mesh decimation?, Michel Audette, 01/06/2011
