- To:
- Subject: Re: [cgal-discuss] AX_LIB_CGAL_CORE: use CGAL in autotools based projects
- Date: Mon, 10 Jan 2011 16:44:10 +0100
Dear Sebastien,
Am 10.01.2011 um 14:47 schrieb Sebastien Loriot (GeometryFactory):
> Sebastian Hegler wrote:
>> As I work with the autotools for my projects, I wrote an autotools script,
>> AX_LIB_CGAL_CORE, to use CGAL with these tools. The script is included in
>> the "GNU autoconf archive" project's git repository; see
>> "http://www.gnu.org/software/autoconf-archive/" for further info. Current
>> feature set:
>> * detects the CGAL core libraries (libCGAL.so and libCGAL_Core.so)
>> * works with CGAL 3.6 and newer
>> Current shortcomings:
>> * does not detect the CGAL libraries that depend on Qt
>> * it is up to the user to keep track about the compiler flags used for
>> CGAL and all dependent projects
>> * maybe a lot more
> As you know, the CGAL project made the choice to move to cmake as building
> tool.
> We currently do not have enough manpower to maintain two different build
> systems, and I think this probably would not be a good idea to maintain
> both.
Just in case we misunderstood: this script is no build system (replacement)
for CGAL itself, you still need to build CGAL somehow. It is a script for the
autotools toolchain to facilitate the inclusion of CGAL into other software
projects, where the other projects use the autotools as their build system.
Sincerely,
Sebastian
- [cgal-discuss] AX_LIB_CGAL_CORE: use CGAL in autotools based projects, Sebastian Hegler, 01/05/2011
- Re: [cgal-discuss] AX_LIB_CGAL_CORE: use CGAL in autotools based projects, Sebastien Loriot (GeometryFactory), 01/10/2011
- Re: [cgal-discuss] AX_LIB_CGAL_CORE: use CGAL in autotools based projects, Sebastian Hegler, 01/10/2011
