cgal-discuss - Re: [cgal-discuss] AX_LIB_CGAL_CORE: use CGAL in autotools based projects
  • To:
  • Subject: Re: [cgal-discuss] AX_LIB_CGAL_CORE: use CGAL in autotools based projects
  • Date: Mon, 10 Jan 2011 14:47:14 +0100
Sebastian Hegler wrote:
Hi!
As I work with the autotools for my projects, I wrote an autotools script, AX_LIB_CGAL_CORE, to use CGAL with these tools. The script is included in the "GNU autoconf archive" project's git repository; see "http://www.gnu.org/software/autoconf-archive/"; for further info.
Current feature set:
* detects the CGAL core libraries (libCGAL.so and libCGAL_Core.so)
* works with CGAL 3.6 and newer
Current shortcomings:
* does not detect the CGAL libraries that depend on Qt
* it is up to the user to keep track about the compiler flags used for CGAL
and all dependent projects
* maybe a lot more
How do the CGAL developers themselves think about also including this in the CGAL distribution itself?
Yours,
Sebastian
Dear Sebastian,
As you know, the CGAL project made the choice to move to cmake as
building tool.
We currently do not have enough manpower to maintain two different build
systems, and I think this probably would not be a good idea to maintain both. From my personal experience, we have enough user reporting
problems during installation, so officially offering another way to install CGAL will just duplicate problems: to me it is better to
support and well document only one build system.
Moreover, the fact that from your side you already report shortcomings,
I am quite sure we would have other from dependencies of CGAL you don't
use (this is the kind of tasks that look simple but consume a lot of
time).
Best regards,
Sebastien.
