- To:
- Subject: [cgal-discuss] AX_LIB_CGAL_CORE: use CGAL in autotools based projects
- Date: Wed, 5 Jan 2011 09:54:19 +0100
Hi!
As I work with the autotools for my projects, I wrote an autotools script,
AX_LIB_CGAL_CORE, to use CGAL with these tools. The script is included in the
"GNU autoconf archive" project's git repository; see
"http://www.gnu.org/software/autoconf-archive/" for further info.
Current feature set:
* detects the CGAL core libraries (libCGAL.so and libCGAL_Core.so)
* works with CGAL 3.6 and newer
Current shortcomings:
* does not detect the CGAL libraries that depend on Qt
* it is up to the user to keep track about the compiler flags used for CGAL
and all dependent projects
* maybe a lot more
How do the CGAL developers themselves think about also including this in the
CGAL distribution itself?
Yours,
Sebastian
- [cgal-discuss] AX_LIB_CGAL_CORE: use CGAL in autotools based projects, Sebastian Hegler, 01/05/2011
- Re: [cgal-discuss] AX_LIB_CGAL_CORE: use CGAL in autotools based projects, Sebastien Loriot (GeometryFactory), 01/10/2011
- Re: [cgal-discuss] AX_LIB_CGAL_CORE: use CGAL in autotools based projects, Sebastian Hegler, 01/10/2011
