Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors
- To:
- Subject: Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors
- Date: Fri, 28 Jan 2011 09:36:47 +0000
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:organization:to:subject:date:user-agent:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=x6tMf1ZNnf6Y8CUUjDzerarsuRGkFxYnmvXhH35sm6SPsnFA5acRUg9XVi1dyFe3Xs QLena0mJdC+Gm4qa3VFQqG3A56gxFTZOy+qBqfmpXYf9nNn795R/EZgr5l9lIEf7K3jp oXOG8QPtfwmdjDkW20m9nRl0VbGyYLui94OLU=
- Organization: OpenCFD Ltd.
Hi Sebastien,
Do you have any further info on using gcc 4.5? Is it an isolated problem
related to where I found it, or are there wider implications across CGAL?
Thanks,
Graham
On Monday 17 January 2011 13:40:04 Sebastien Loriot (GeometryFactory) wrote:
> Graham Macpherson wrote:
> > Hi Sebastien,
> > Thanks for the reply.
> > I've checked and I do see the linear memory increase with openSUSE and
> > not with
> > Ubuntu; the logs I attached to my email are valid.
> > Is it worth investigating if gcc 4.4 vs 4.5 makes a difference?
> You were right, there seems to be a problem when using gcc 4.5.
> I don't know right now what. I'll post here when I have more
> information.
> S.
> > Regards,
> > Graham
> > On Monday 17 January 2011 08:40:52 Sebastien Loriot (GeometryFactory)
> > wrote:
> >> There is no memory leak in your code.
> >> Behind the Exact_predicates_exact_constructions_kernel, there are
> >> *a multi-precision number type (for example Gmpq if GMP is available)
> >> *filtering mechanism on constructed objects (such as points)
> >> In your for loop, you are iteratively summing to your points a vector.
> >> Both implementation details are responsible for the memory increase:
> >> *The precision needed by the number type to exactly do the sums
> >> requires more precision, thus more space. Running you code with
> >> CGAL::Simple_cartesian<CGAL::Gmpq>, you will observe an increase in
> >> memory usage, but not at each iteration (only when precision of numbers
> >> is increased).
> >> *the filtering mechanism maintain a DAG of the cascaded constructions.
> >> Each sum create a note in the DAG. This is the real cause of the memory
> >> usage increase in your case.
> >> However, I am surprised that you do not observe the memory consumption
> >> increase on Ubuntu.
> >> Can you please check again to confirm whether there is a problem?
> >> S.
> >>> Hello all,
> >>> I've found a strange memory problem that I've reproduced in the
> >>> attached code.
> >>> I'm taking the vertices of a Delaunay tessellation, calculating a
> >>> displacement
> >>> for them, clearing the tessellation, then reinserting the displaced
> >>> vertices.
> >>> When I run this, the memory use by the process increases linearly with
> >>> each
> >>> iteration, which is wrong, it should be essentially constant, however:
> >>> + The problem doesn't occur with option A in the attached, only with
> >>> option B,
> >>> i.e. when adding a Vector_3 to the point;
> >>> + The problem doesn't occur using
> >>> Exact_predicates_inexact_constructions_kernel, only with
> >>> Exact_predicates_exact_constructions_kernel;
> >>> + It doesn't appear on all operating systems - it appears on openSUSE
> >>> 11.3, but
> >>> not on Ubuntu 10.04.
> >>> Also attached are two log files showing the contrasting behaviour on
> >>> the two
> >>> operating systems with the code the same.
> >>> I've tried on openSUSE 11.3 with gcc 4.5.0 (system compiler) and gcc
> >>> 4.5.2,
> >>> boost versions 1.40.0, 1.42.0 (system) and 1.45.0, and with CGAL 3.5.1
> >>> and CGAL
> >>> 3.7, and they all essentially do the same thing.
> >>> On Ubuntu I'm using CGAL 3.7, gcc 4.4.3 (system compiler) and boost
> >>> 1.40.0
> >>> (system).
> >>> Note, the memInfo class is one that's part of other libraries I'm
> >>> using, so it
> >>> won't compile for you, it's only there to show how the output was
> >>> generated.
> >>> Assuming that the addition operation in option B is legitimate, then
> >>> this looks
> >>> like a bug in a library. Any suggestions for how to get to the bottom
> >>> of it?
> >>> Best regards,
> >>> Graham
> >>> Graham Macpherson
> >>> OpenCFD Ltd.
> >>> www.openfoam.com
> >>> +44 (0)118 9471030
> >>> 9 Albert Road
> >>> Caversham
> >>> Reading RG4 7AN
- [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors, Graham Macpherson, 01/14/2011
- Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors, Sebastien Loriot (GeometryFactory), 01/17/2011
- Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors, Graham Macpherson, 01/17/2011
- Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors, Graham Macpherson, 01/28/2011
- Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors, Francois Berenger, 01/18/2011
- Re: [cgal-discuss] Memory issue with openSUSE 11.3, exact kernel, adding points/vectors, Sebastien Loriot (GeometryFactory), 01/18/2011
