- To:
- Subject: Re: [cgal-discuss] point location/interpolation on a 2d mesh
- Date: Mon, 24 Jan 2011 14:55:53 +0100
Hansjoerg Seybold wrote:
Hi,You cannot use directly Delaunay_triangulation as your input mesh is probably not Delaunay.
thanks a lot for the answer.
Yes, i want to use the results from another program to postprocess
with a cgal.
The mesh is only flat 2d, so it is a simple 2d triangulation problem.
The mesh has a complex geometry of holes, which i want to exclude from
the calculation of the interpolation.
I could try to load the mesh vertices and create a delaunay triangulation,
but then i need a way to mark/exclude the hole parts,
thus i was thinking of using the 2d mesh class with triangulation hierarchy
A solution is to use Triangulation_2 and
Triangulation_data_structure_2 but it may be tricky to
make a copy of your mesh (mimicking the function copy_tds
in CGAL/Triangulation_data_structure_2 is probably the easiest way).
To add a tag into faces see:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_face_base_with_info_2.html
Another alternative if remeshing is acceptable for your application is to use Mesh_2 with constrained edges and excluded parts (see
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_2/Chapter_main.html)
S.
cheers hj
On Mon, Jan 24, 2011 at 9:31 AM, Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>> wrote:
Hello,
Hello I would like to calculate interpolated values from
vertices on a 2d mesh.
My problem is as follows:
- I have a mesh given by vertices and constraints (i know the
boundary and the partitioning of the space (holes) )
- With this information i would like to create a cgal mesh to
perform interpolation operations of lets say the velocity field
stored in the
vertices.
I saw the cgal interpolation page and the point location page
for the triangulation.
Is it also possible to use the triangulation hierarchy on a mesh
for efficient point location.
I need a mesh to determine what is inside and what is outside as
the domain has holes or is there a simpler way to perform
interpolation/and determining inside/outside like in the mesh case.
Thank you very much
hj
From what I understand, you have a surface mesh with hole that you
computed (not using CGAL surface mesher) and you want:
1) determine whether a point is on your surface
2) use CGAL::surface_neighbor_coordinates_3 only on points detected on
your surface
For 1) using AABB_tree and closest_point_and_primitive might help
(http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree/Chapter_main.html#Section_62.6).
Using the triangulation hierarchy will be complicated as you first need
to have a your surface included into a 3D triangulation.
S.
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] point location/interpolation on a 2d mesh, Hansjoerg Seybold, 01/21/2011
- Re: [cgal-discuss] point location/interpolation on a 2d mesh, Sebastien Loriot (GeometryFactory), 01/24/2011
- Re: [cgal-discuss] point location/interpolation on a 2d mesh, Hansjoerg Seybold, 01/24/2011
- Re: [cgal-discuss] point location/interpolation on a 2d mesh, Sebastien Loriot (GeometryFactory), 01/25/2011
