cgal-discuss - [cgal-discuss] Checking for a vertex in a Polyhedron
  • To:
  • Subject: [cgal-discuss] Checking for a vertex in a Polyhedron
  • Date: Sat, 5 Feb 2011 08:36:30 -0800 (PST)
Hi,
Is there a way I can query a polyhedron model to check whether a point
exists as a vertex in the polyhedron?
I looked into the documentation and could not seem to find any direct query.
I do not really want to iterate over the whole set of vertices because this
query needs to be done repeatedly in the algorithm I am implementing.
If there is no direct query, what are the suggestions for the shortest /
most efficient way of obtaining this information?
At present, the best I can think of is to maintain a separate HashTable of
the vertices added to the polyhedron, where the x-y-z co-ordinate of the
vertex is concatinated as a string to serve as the key of the HashTable.
Then when I have a new point, I can use its co-ordinate values to query the
HashTable. However, I might possibly run into accuracy issues.
Thanks
Vani
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Checking-for-a-vertex-in-a-Polyhedron-tp3262000p3262000.html
