- To:
- Subject: [cgal-discuss] Re: About Bezier curves in Arrangement
- Date: Sat, 5 Feb 2011 07:11:43 -0800 (PST)
Thanks for the patch! It works for most case, except the one when the point lies in the vertical line segment. For example, using the code and data as before, and change the point for point location to (30, 10), where it located in the vertical line segment, the assertion will come.
2011/2/4 Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]>
stzpz wrote:
> Thanks so much for the patch. It looks OK. But I found another problem:
> When I use locate() to determine the location of the point, assertion
> will appear if the point lies in one of the lines in arrangement (but
> not in the intersection point), just like the code below:
Thanks for the bug report. Please try with the patched file attached.
S.--> <http://cgal-discuss.949826.n4.nabble.com/About-Bezier-curves-in-Arrangement-tp3238384p3250909.html?by-user=t>
> ----------------------------- CODE BEGIN -----------------------------
> #include <CGAL/basic.h>
> #include <CGAL/Cartesian.h>
> #include <CGAL/CORE_algebraic_number_traits.h>
> #include <CGAL/Arr_Bezier_curve_traits_2.h>
> #include <CGAL/Arrangement_2.h>
> #include <CGAL/Arr_curve_data_traits_2.h>
> #include <CGAL/Arr_walk_along_line_point_location.h>
> #include <CGAL/to_rational.h>
> typedef CGAL::CORE_algebraic_number_traits Nt_traits;
> typedef Nt_traits::Rational NT;
> typedef Nt_traits::Rational Rational;
> typedef Nt_traits::Algebraic Algebraic;
> typedef CGAL::Cartesian<Rational> Rat_kernel;
> typedef CGAL::Cartesian<Algebraic> Alg_kernel;
> typedef Rat_kernel::Point_2 Rat_point_2;
> typedef CGAL::Arr_Bezier_curve_traits_2<Rat_kernel, Alg_kernel,
> Nt_traits> Traits_org_2;
> typedef Traits_org_2::Curve_2 Bezier_curve_2;
> typedef unsigned int CurveNumber;
> typedef CGAL::Arr_curve_data_traits_2<Traits_org_2, CurveNumber> Traits_2;
> typedef Traits_2::Curve_2 Bezier_curve_num_2;
> typedef Traits_2::X_monotone_curve_2 X_monotone_curve_2;
> typedef Traits_2::Point_2 Point_2;
> typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
> typedef CGAL::Arr_walk_along_line_point_location<Arrangement_2> Naive_pl;
> #define TORAT(x) (CGAL::to_rational<Rational>((x)))
> int main (int argc, char *argv[])
> const char *filename = (argc > 1) ? argv[1] : "test4.dat";
> std::ifstream in_file (filename);
> int n_curves;
> std::list<Bezier_curve_num_2> curves;
> Bezier_curve_2 B;
> int k;
> in_file >> n_curves;
> for (k = 0; k < n_curves; k++) {
> in_file >> B;
> Bezier_curve_num_2 bb(B, k);
> curves.push_back (bb);
> Arrangement_2 arr;
> insert (arr, curves.begin(), curves.end());
> // Points like (10, 0), (40, 30), (30, 10) are lie in the lines
> Point_2 p(TORAT(40), TORAT(30));
> // Here comes the assertion
> CGAL::Object obj = pl.locate(p);
> return 0;
> ----------------------------- CODE END -----------------------------
> Here is the test4.dat:
> ---------------------------- DATA BEGIN ------------------------------
> 3
> 2 0 0 100 0
> 2 30 -20 30 80
> 2 100 -15 -20 75
> ---------------------------- DATA END ------------------------------
> Thanks again for your kindly help!
> Sincerely yours,
> Stzpz
> 2011/2/1 Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden
> email] </user/SendEmail.jtp?type=node&node=3258664&i=0>>
> stzpz wrote:
> > Thanks very much for your reply!
> Please found attached patch files that should solve your problem.
> Can you try them and tell us whether it works now?
> > For the first question, is that better to let the returning
> > supporting_curve() contains the correct auxiliary data? Because the
> > returning type of supporting_curve() is Arr_curve_data_traits_2.
> The return type of
> Arr_curve_data_traits_2<Traits_org_2,CurveNumber>::X_monotone_curve_2::supporting_curve()
> is Traits_org_2::Curve_2 because it inherits from
> Traits_org_2::X_monotone_curve_2
> > In addition, I have one more question. Because I want to
> calculate the
> > new control points of each sub bezier curve (X_monotone_curve_2),
> I use
> > parameter_range() with de_Casteljau_2() to do that. But it seems
> that
> > the returned values of parameter_range() is not so accurate for some
> > case and hence influences the result of de_Casteljau_2(). For
> example,
> > in the following code,
> As documented parameter_range() returns "the approximate parameter
> range defining the subcurve b."
> S.
> [snip]
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
> *patch.tgz* (17K) Download Attachment
> <http://attachment/3250909/0/patch.tgz>
> If you reply to this email, your message will be added to the
> discussion below:
> To unsubscribe from About Bezier curves in Arrangement, click here
> <http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=3238384&code=bmV3c3R6cHpAZ21haWwuY29tfDMyMzgzODR8LTE2MDE4MTIwOA==&by-user=t>.
> View this message in context: Re: About Bezier curves in Arrangement
> <http://cgal-discuss.949826.n4.nabble.com/About-Bezier-curves-in-Arrangement-tp3238384p3258664.html>
> Sent from the cgal-discuss mailing list archive
> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
// Copyright (c) 2006 Tel-Aviv University (Israel).
// All rights reserved.
// This file is part of CGAL (www.cgal.org); you may redistribute it under
// the terms of the Q Public License version 1.0.
// See the file LICENSE.QPL distributed with CGAL.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.7-branch/Arrangement_on_surface_2/include/CGAL/Arr_geometry_traits/Bezier_x_monotone_2.h $
// $Id: Bezier_x_monotone_2.h 57724 2010-08-02 14:53:10Z lrineau $
// Author(s) : Ron Wein <[hidden email]>
// Iddo Hanniel <[hidden email]>
#ifndef CGAL_BEZIER_X_MONOTONE_2_H
#define CGAL_BEZIER_X_MONOTONE_2_H
/*! \file
* Header file for the _Bezier_x_monotone_2 class.
#include <CGAL/Arr_geometry_traits/Bezier_curve_2.h>
#include <CGAL/Arr_geometry_traits/Bezier_point_2.h>
#include <CGAL/Arr_geometry_traits/Bezier_cache.h>
#include <ostream>
namespace CGAL {
/*! \class
* Representation of an x-monotone Bezier subcurve, specified by a Bezier curve
* and two end points.
template <class Rat_kernel_, class Alg_kernel_, class Nt_traits_,
class Bounding_traits_>
class _Bezier_x_monotone_2
public:
typedef Rat_kernel_ Rat_kernel;
typedef Alg_kernel_ Alg_kernel;
typedef Nt_traits_ Nt_traits;
typedef Bounding_traits_ Bounding_traits;
typedef _Bezier_curve_2<Rat_kernel,
Alg_kernel,
Nt_traits,
Bounding_traits> Curve_2;
typedef _Bezier_point_2<Rat_kernel,
Alg_kernel,
Nt_traits,
Bounding_traits> Point_2;
typedef _Bezier_x_monotone_2<Rat_kernel,
Alg_kernel,
Nt_traits,
Bounding_traits> Self;
typedef unsigned int Multiplicity;
typedef _Bezier_cache<Nt_traits> Bezier_cache;
private:
typedef typename Alg_kernel::Point_2 Alg_point_2;
typedef typename Rat_kernel::Point_2 Rat_point_2;
typedef typename Nt_traits::Integer Integer;
typedef typename Nt_traits::Rational Rational;
typedef typename Nt_traits::Algebraic Algebraic;
typedef typename Nt_traits::Polynomial Polynomial;
typedef typename Point_2::Originator Originator;
typedef typename Point_2::Originator_iterator Originator_iterator;
typedef typename Bounding_traits::Bez_point_bound Bez_point_bound;
typedef typename Bounding_traits::Bez_point_bbox Bez_point_bbox;
// Type definition for the vertical tangency-point mapping.
typedef typename Bezier_cache::Curve_id Curve_id;
typedef std::pair<Curve_id, Curve_id> Curve_pair;
typedef typename Bezier_cache::Vertical_tangency_list Vert_tang_list;
typedef typename Bezier_cache::Vertical_tangency_iter Vert_tang_iter;
// Type definition for the intersection-point mapping.
typedef typename Bezier_cache::Intersection_list Intersect_list;
typedef typename Bezier_cache::Intersection_iter Intersect_iter;
// Representation of an intersection point with its multiplicity:
typedef std::pair<Point_2, unsigned int> Intersection_point_2;
/*! \class Less_intersection_point
* Comparison functor for intersection points.
private:
Bezier_cache *p_cache;
public:
Less_intersection_point (Bezier_cache& cache) :
p_cache (&cache)
bool operator() (const Intersection_point_2& ip1,
const Intersection_point_2& ip2) const
// Use an xy-lexicographic comparison.
return (ip1.first.compare_xy (ip2.first, *p_cache) == SMALLER);
// Type definition for the bounded intersection-point mapping.
typedef std::list<Point_2> Intersection_list;
/*! \struct Less_curve_pair
* An auxiliary functor for comparing a pair of curve IDs.
bool operator() (const Curve_pair& cp1, const Curve_pair& cp2) const
// Compare the pairs of IDs lexicographically.
return (cp1.first < cp2.first ||
(cp1.first == cp2.first && cp1.second < cp2.second));
/*! \struct Subcurve
* For the usage of the _exact_vertical_position() function.
struct Subcurve
std::list<Rat_point_2> control_points;
Rational t_min;
Rational t_max;
/*! Get the rational bounding box of the subcurve. */
void bbox (Rational& x_min, Rational& y_min,
Rational& x_max, Rational& y_max) const
typename std::list<Rat_point_2>::const_iterator pit =
control_points.begin();
CGAL_assertion (pit != control_points.end());
x_min = x_max = pit->x();
y_min = y_max = pit->y();
for (++pit; pit != control_points.end(); ++pit)
if (CGAL::compare (x_min, pit->x()) == LARGER)
x_min = pit->x();
else if (CGAL::compare (x_max, pit->x()) == SMALLER)
x_max = pit->x();
if (CGAL::compare (y_min, pit->y()) == LARGER)
y_min = pit->y();
else if (CGAL::compare (y_max, pit->y()) == SMALLER)
y_max = pit->y();
return;
public:
typedef std::map<Curve_pair,
Intersection_list,
Less_curve_pair> Intersection_map;
typedef typename Intersection_map::value_type Intersection_map_entry;
typedef typename Intersection_map::iterator Intersection_map_iterator;
private:
// Data members:
Curve_2 _curve; /*!< The supporting Bezier curve. */
unsigned int _xid; /*!< The serial number of the basic x-monotone
subcurve of the Bezier curve. */
Point_2 _ps; /*!< The source point. */
Point_2 _pt; /*!< The target point. */
bool _dir_right; /*!< Is the subcurve directed right
(or left). */
bool _inc_to_right; /*!< Does the parameter value increase when
traversing the subcurve from left to
right. */
bool _is_vert; /*!< Is the subcurve a vertical segment. */
public:
/*! Default constructor. */
_Bezier_x_monotone_2 () :
_xid(0),
_dir_right (false),
_is_vert (false)
* Constructor given two endpoints.
* \param B The supporting Bezier curve.
* \param xid The serial number of the x-monotone subcurve with respect to
* the parameter range of the Bezier curve.
* For example, if B is split to two x-monotone subcurves at t',
* the subcurve defined over [0, t'] has a serial number 1,
* and the other, defined over [t', 1] has a serial number 2.
* \param ps The source point.
* \param pt The target point.
* \param cache Caches the vertical tangency points and intersection points.
* \pre B should be an originator of both ps and pt.
* \pre xid is a non-zero serial number.
_Bezier_x_monotone_2 (const Curve_2& B, unsigned int xid,
const Point_2& ps, const Point_2& pt,
Bezier_cache& cache);
* Get the supporting Bezier curve.
const Curve_2& supporting_curve () const
return (_curve);
* Get the x-monotone ID of the curve.
unsigned int xid () const
return (_xid);
* Get the source point.
const Point_2& source () const
return (_ps);
* Get the target point.
const Point_2& target () const
return (_pt);
* Get the left endpoint (the lexicographically smaller one).
const Point_2& left () const
return (_dir_right ? _ps : _pt);
* Get the right endpoint (the lexicographically larger one).
const Point_2& right () const
return (_dir_right ? _pt : _ps);
* Check if the subcurve is a vertical segment.
bool is_vertical () const
return (_is_vert);
* Check if the subcurve is directed from left to right.
bool is_directed_right () const
return (_dir_right);
* Get the approximate parameter range defining the curve.
* \return A pair of t_src and t_trg, where B(t_src) is the source point
* and B(t_trg) is the target point.
std::pair<double, double> parameter_range () const;
* Get the relative position of the query point with respect to the subcurve.
* \param p The query point.
* \pre p is in the x-range of the arc.
* \return SMALLER if the point is below the arc;
* LARGER if the point is above the arc;
* EQUAL if p lies on the arc.
Comparison_result point_position (const Point_2& p,
Bezier_cache& cache) const;
* Compare the relative y-position of two x-monotone subcurve to the right
* of their intersection point.
* \param cv The other subcurve.
* \param p The intersection point.
* \pre p is incident to both subcurves, and both are defined to its right.
* \return SMALLER if (*this) lies below cv to the right of p;
* EQUAL in case of an overlap (should not happen);
* LARGER if (*this) lies above cv to the right of p.
Comparison_result compare_to_right (const Self& cv,
const Point_2& p,
* Compare the relative y-position of two x-monotone subcurve to the left
* \pre p is incident to both subcurves, and both are defined to its left.
Comparison_result compare_to_left (const Self& cv,
const Point_2& p,
* Check whether the two subcurves are equal (have the same graph).
* \return (true) if the two subcurves have the same graph;
* (false) otherwise.
bool equals (const Self& cv,
* Compute the intersections with the given subcurve.
* \param inter_map Caches the bounded intersection points.
* \param oi The output iterator.
* \return The past-the-end iterator.
template<class OutputIterator>
OutputIterator intersect (const Self& cv,
Intersection_map& inter_map,
Bezier_cache& cache,
OutputIterator oi) const
// In case we have two x-monotone subcurves of the same Bezier curve,
// check if they have a common left endpoint.
if (_curve.is_same (cv._curve))
if (left().is_same (cv.left()) || left().is_same (cv.right()))
*oi = CGAL::make_object (Intersection_point_2 (left(), 0));
++oi;
// Compute the intersections of the two sucurves. Note that for caching
// purposes we always apply the _intersect() function on the subcurve whose
// curve ID is smaller.
std::vector<Intersection_point_2> ipts;
Self ovlp_cv;
bool do_ovlp;
if (_curve.id() <= cv._curve.id())
do_ovlp = _intersect (cv, inter_map, cache, ipts, ovlp_cv);
else
do_ovlp = cv._intersect (*this, inter_map, cache, ipts, ovlp_cv);
// In case of overlap, just report the overlapping subcurve.
if (do_ovlp)
*oi = CGAL::make_object (ovlp_cv);
++oi;
return (oi);
// If we have a set of intersection points, sort them in ascending
// xy-lexicorgraphical order, and insert them to the output iterator.
typename std::vector<Intersection_point_2>::const_iterator ip_it;
std::sort (ipts.begin(), ipts.end(), Less_intersection_point (cache));
for (ip_it = ipts.begin(); ip_it != ipts.end(); ++ip_it)
*oi = CGAL::make_object (*ip_it);
++oi;
// check if they have a common right endpoint.
if (right().is_same (cv.left()) || right().is_same (cv.right()))
*oi = CGAL::make_object (Intersection_point_2 (right(), 0));
++oi;
return (oi);
* Split the subcurve into two at a given split point.
* \param p The split point.
* \param c1 Output: The first resulting arc, lying to the left of p.
* \param c2 Output: The first resulting arc, lying to the right of p.
* \pre p lies in the interior of the subcurve (not one of its endpoints).
void split (const Point_2& p,
Self& c1, Self& c2) const;
* Check if the two subcurves are mergeable.
* \return Whether the two subcurves can be merged.
bool can_merge_with (const Self& cv) const;
* Merge the current arc with the given arc.
* \pre The two arcs are mergeable.
* \return The merged arc.
Self merge (const Self& cv) const;
* Flip the subcurve (swap its source and target points).
* \return The flipped subcurve.
Self flip () const
// Note that we just swap the source and target of the original subcurve
// and do not touch the supporting Beizer curve.
Self cv = *this;
cv._ps = this->_pt;
cv._pt = this->_ps;
cv._dir_right = ! this->_dir_right;
return (cv);
private:
* Check if the given t-value is in the range of the subcurve.
* \param t The parameter value.
* \return If t in the parameter-range of the subcurve.
bool _is_in_range (const Algebraic& t,
* Check if the given point lies in the range of this x-monotone subcurve.
* \param p The point, which lies on the supporting Bezier curve.
* \param is_certain Output: Is the answer we provide is certain.
* \return Whether p is on the x-monotone subcurve.
bool _is_in_range (const Point_2& p, bool& is_certain) const;
* Given a point p that lies on the supporting Bezier curve (X(t), Y(t)),
* determine whether p lies within the t-range of the x-monotone subcurve.
* If so, the value t0 such that p = (X(t0), Y(t0)) is also computed.
* \param t0 Output: A parameter value such that p = (X(t0), Y(t0)).
* \param is_endpoint Output: Whether p equals on the of the endpoints.
* \return Whether p lies in the t-range of the subcurve.
Algebraic& t0,
bool& is_endpoint) const;
* Compute a y-coordinate of a point on the x-monotone subcurve with a
* given x-coordinate.
* \param x0 The given x-coodinate.
* \return The y-coordinate.
Algebraic _get_y (const Rational& x0,
* Compare the slopes of the subcurve with another given Bezier subcurve at
* their given intersection point.
* \pre p lies of both subcurves.
* \pre Neither of the subcurves is a vertical segment.
* \return SMALLER if (*this) slope is less than cv's;
* EQUAL if the two slopes are equal;
* LARGER if (*this) slope is greater than cv's.
Comparison_result _compare_slopes (const Self& cv,
const Point_2& p,
* Get the range of t-value over which the subcurve is defined.
* \return A pair comprised of the t-value for the source point and the
* t-value for the target point.
std::pair<Algebraic, Algebraic> _t_range (Bezier_cache& cache) const;
* (or to the left) of their intersection point, whose multiplicity is
* greater than 1.
* \param to_right Should we compare to p's right or to p's left.
* \pre The x-coordinate of the right endpoint of *this is smaller than
* (or equal to) the x-coordinate of the right endpoint of cv.
* \pre p is a common point of both subcurves.
* \return SMALLER if (*this) lies below cv next to p;
* LARGER if (*this) lies above cv next to p.
Comparison_result _compare_to_side (const Self& cv,
const Point_2& p,
bool to_right,
* Clip the control polygon of the supporting Bezier curve such that it
* fits the current x-monotone subcurve.
* \param ctrl Output: The clipped control polygon.
* \param t_min Output: The minimal t-value of the clipped curve.
* \param t_max Output: The maximal t-value of the clipped curve.
void _clip_control_polygon
(typename Bounding_traits::Control_points& ctrl,
typename Bounding_traits::NT& t_min,
typename Bounding_traits::NT& t_max) const;
* Approximate the intersection points between the supporting Bezier curves
* of the given x-monotone curves.
* \param cv The x-monotone curve we intersect.
* \param inter_pts Output: An output list of intersection points between
* the supporting Bezier curves.
* In case (*this) and cv are subcurve of the same
* Bezier curve, only the self-intersection points
* between the subcurves are approximated.
* \return Whether all intersection points where successfully approximated.
bool _approximate_intersection_points (const Self& cv,
std::list<Point_2>& inter_pts) const;
* \param ipts Output: A vector of intersection points + multiplicities.
* \param ovlp_cv Output: An overlapping subcurve (if exists).
* \return Whether an overlap has occured.
bool _intersect (const Self& cv,
std::vector<Intersection_point_2>& ipts,
Self& ovlp_cv) const;
* Compute the exact vertical position of the given point with respect to
* the x-monotone curve.
* \param p The point.
* \param force_exact Sould we force an exact result.
* \return SMALLER if the point is below the curve;
* LARGER if the point is above the curve;
* EQUAL if p lies on the curve.
Comparison_result _exact_vertical_position (const Point_2& p,
bool force_exact) const;
* Exporter for Bezier curves.
template <class Rat_kernel, class Alg_kernel, class Nt_traits,
class Bounding_traits>
std::ostream&
operator<< (std::ostream& os,
const _Bezier_x_monotone_2<Rat_kernel, Alg_kernel, Nt_traits,
Bounding_traits>& cv)
os << cv.supporting_curve()
<< " [" << cv.xid()
<< "] | " << cv.source()
<< " --> " << cv.target();
return (os);
// Constructor given two endpoints.
template <class RatKer, class AlgKer, class NtTrt, class BndTrt>
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_Bezier_x_monotone_2
_curve (B),
_xid (xid),
_ps (ps),
_pt (pt),
_is_vert (false)
CGAL_precondition (xid > 0);
// Get the originators of the point that correspond to the curve B.
Originator_iterator ps_org = ps.get_originator (B, _xid);
CGAL_precondition (ps_org != ps.originators_end());
Originator_iterator pt_org = pt.get_originator (B, _xid);
CGAL_precondition (pt_org != pt.originators_end());
// Check if the subcurve is directed left or right.
const Comparison_result res = _ps.compare_x (_pt, cache);
if (res == EQUAL)
// We have a vertical segment. Check if the source is below the target.
_is_vert = true;
_dir_right = (CGAL::compare (_ps.y(), _pt.y()) == SMALLER);
else
_dir_right = (res == SMALLER);
// Check if the value of the parameter t increases when we traverse the
// curve from left to right: If the curve is directed to the right, we
// check if t_src < t_trg, otherwise we check whether t_src > t_trg.
Comparison_result t_res;
if (CGAL::compare (ps_org->point_bound().t_max,
pt_org->point_bound().t_min) == SMALLER ||
CGAL::compare (ps_org->point_bound().t_min,
pt_org->point_bound().t_max) == LARGER)
// Perform the comparison assuming that the possible parameter
// values do not overlap.
t_res = CGAL::compare (ps_org->point_bound().t_min,
pt_org->point_bound().t_min);
else
// In this case both exact parameter values must be known.
// We use them to perform an exact comparison.
CGAL_assertion (ps_org->has_parameter() && pt_org->has_parameter());
t_res = CGAL::compare (ps_org->parameter(), pt_org->parameter());
CGAL_precondition (t_res != EQUAL);
if (_dir_right)
_inc_to_right = (t_res == SMALLER);
else
_inc_to_right = (t_res == LARGER);
// Get the approximate parameter range defining the curve.
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::parameter_range () const
// First try to use the approximate representation of the endpoints.
Originator_iterator s_org = _ps.get_originator (_curve, _xid);
CGAL_assertion (s_org != _ps.originators_end());
Originator_iterator t_org = _pt.get_originator (_curve, _xid);
CGAL_assertion (t_org != _pt.originators_end());
double t_src = (CGAL::to_double (s_org->point_bound().t_min) +
CGAL::to_double (s_org->point_bound().t_max)) / 2;
double t_trg = (CGAL::to_double (t_org->point_bound().t_min) +
CGAL::to_double (t_org->point_bound().t_max)) / 2;
return (std::make_pair (t_src, t_trg));
// Get the relative position of the query point with respect to the subcurve.
Comparison_result
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::point_position
(const Point_2& p,
if (p.identical(_ps)) {
return EQUAL;
// First check whether p has the same x-coordinate as one of the endpoints.
const Comparison_result res1 = p.compare_x (_ps, cache);
if (res1 == EQUAL)
// In this case both points must be exact.
CGAL_assertion (p.is_exact() && _ps.is_exact());
// If both point are rational, compare their rational y-coordinates.
if (p.is_rational() && _ps.is_rational())
const Rat_point_2& rat_p = (Rat_point_2) p;
const Rat_point_2& rat_ps = (Rat_point_2) _ps;
return (CGAL::compare (rat_p.y(), rat_ps.y()));
// Compare the algebraic y-coordinates.
return (CGAL::compare (p.y(), _ps.y()));
if (p.identical(_pt)) {
return EQUAL;
const Comparison_result res2 = p.compare_x (_pt, cache);
if (res2 == EQUAL)
CGAL_assertion (p.is_exact() && _pt.is_exact());
if (p.is_rational() && _pt.is_rational())
const Rat_point_2& rat_pt = (Rat_point_2) _pt;
return (CGAL::compare (rat_p.y(), rat_pt.y()));
return (CGAL::compare (p.y(), _pt.y()));
// Make sure that p is in the x-range of our subcurve.
CGAL_precondition (res1 != res2);
// Check for the case when curve is an originator of the point.
Originator_iterator p_org = p.get_originator (_curve, _xid);
if (p_org != p.originators_end())
Originator_iterator ps_org = _ps.get_originator (_curve, _xid);
CGAL_assertion (ps_org != _ps.originators_end());
Originator_iterator pt_org = _pt.get_originator (_curve, _xid);
CGAL_assertion (pt_org != _pt.originators_end());
// Check if the point is in the parameter range of this subcurve.
// First try an approximate check of the parameter bounds.
bool correct_res;
bool in_range = false;
in_range = _is_in_range (p, correct_res);
if (! correct_res)
// Perform the comparsion in an exact manner.
if (! p.is_exact())
p.make_exact (cache);
CGAL_assertion (p_org->has_parameter());
in_range = _is_in_range (p_org->parameter(), cache);
if (in_range)
return (EQUAL);
// Call the vertical-position function that uses the bounding-boxes
// to evaluate the comparsion result.
typename Bounding_traits::Control_points cp;
std::copy (_curve.control_points_begin(), _curve.control_points_end(),
std::back_inserter(cp));
Comparison_result res_bound = EQUAL;
typename Bounding_traits::NT x_min, y_min, x_max, y_max;
bool can_refine;
p.get_bbox (x_min, y_min, x_max, y_max);
pt_org->point_bound().t_min) == SMALLER)
// Examine the parameter range of the originator of the source point
// with respect to the current subcurve B, and make sure that B(t_max)
// lies to the left of p if the curve is directed from left to right
// (or to the right of p, if the subcurve is directed from right to left).
can_refine = ! _ps.is_exact();
do
const Rat_point_2& ps = _curve (ps_org->point_bound().t_max);
if ((_dir_right && CGAL::compare (ps.x(), x_min) != LARGER) ||
(! _dir_right && CGAL::compare (ps.x(), x_max) != SMALLER))
break;
if (can_refine)
can_refine = _ps.refine();
} while (can_refine);
// Examine the parameter range of the originator of the target point
// with respect to the current subcurve B, and make sure that B(t_min)
// lies to the right of p if the curve is directed from left to right
// (or to the left of p, if the subcurve is directed from right to left).
can_refine = ! _pt.is_exact();
do
const Rat_point_2& pt = _curve (pt_org->point_bound().t_min);
if ((_dir_right && CGAL::compare (pt.x(), x_max) != SMALLER) ||
(! _dir_right && CGAL::compare (pt.x(), x_min) != LARGER))
break;
if (can_refine)
can_refine = _pt.refine();
// In this case the parameter value of the source is smaller than the
// target's, so we compare the point with the subcurve of B defined over
// the proper parameter range.
res_bound = p.vertical_position (cp,
else if (CGAL::compare (pt_org->point_bound().t_max,
ps_org->point_bound().t_min) == SMALLER)
do
const Rat_point_2& ps = _curve (ps_org->point_bound().t_min);
break;
if (can_refine)
do
const Rat_point_2& pt = _curve (pt_org->point_bound().t_max);
break;
if (can_refine)
// In this case the parameter value of the source is large than the
if (res_bound != EQUAL)
return (res_bound);
if ( p.is_rational() ){
Nt_traits nt_traits;
Rational px = ((Rat_point_2) p).x();
Integer denom_px=nt_traits.denominator(px);
Integer numer_px=nt_traits.numerator(px);
Polynomial poly_px = CGAL::sign(numer_px) == ZERO ? Polynomial() : nt_traits.construct_polynomial(&numer_px,0);
Polynomial poly_x = nt_traits.scale(_curve.x_polynomial(),denom_px) - poly_px;
std::vector <Algebraic> roots;
std::pair<double,double> prange = parameter_range();
nt_traits.compute_polynomial_roots (poly_x,prange.first,prange.second,std::back_inserter(roots));
CGAL_assertion(roots.size()==1); //p is in the range and the curve is x-monotone
return CGAL::compare(
((Rat_point_2) p).y(),
nt_traits.evaluate_at (_curve.y_polynomial(), *roots.begin())
// In this case we have to switch to exact computations and check whether
// p lies of the given subcurve. We take one of p's originating curves and
// compute its intersections with our x-monotone curve.
if (! p.is_exact())
CGAL_assertion (p.originators_begin() != p.originators_end());
Originator org = *(p.originators_begin());
bool do_ovlp;
bool swap_order = (_curve.id() > org.curve().id());
const Intersect_list& inter_list = (! swap_order ?
(cache.get_intersections (_curve.id(),
_curve.x_polynomial(), _curve.x_norm(),
_curve.y_polynomial(), _curve.y_norm(),
org.curve().id(),
org.curve().x_polynomial(), org.curve().x_norm(),
org.curve().y_polynomial(), org.curve().y_norm(),
do_ovlp)) :
(cache.get_intersections (org.curve().id(),
_curve.id(),
do_ovlp)));
if (do_ovlp)
return (EQUAL);
// Go over the intersection points and look for p there.
Intersect_iter iit;
for (iit = inter_list.begin(); iit != inter_list.end(); ++iit)
// Get the parameter of the originator and compare it to p's parameter.
const Algebraic& s = swap_order ? iit->s : iit->t;
if (CGAL::compare (s, org.parameter()) == EQUAL)
// Add this curve as an originator for p.
const Algebraic& t = swap_order ? iit->t : iit->s;
CGAL_assertion (_is_in_range (t, cache));
Point_2& pt = const_cast<Point_2&> (p);
pt.add_originator (Originator (_curve, _xid, t));
// The point p lies on the subcurve.
return (EQUAL);
// We now know that p is not on the subcurve. We therefore subdivide the
// curve using exact rational arithmetic, until we reach a separation
// between the curve and the point. (This case should be very rare.)
// Note that we first try to work with inexact endpoint representation, and
// only if we fail we make the endpoints of the x-monotone curves exact.
if (! p.is_exact())
Comparison_result exact_res = _exact_vertical_position (p, false);
if (exact_res != EQUAL)
return (exact_res);
if (! _ps.is_exact())
_ps.make_exact (cache);
if (! _pt.is_exact())
_pt.make_exact (cache);
return (_exact_vertical_position (p, true));
// Compare the relative y-position of two x-monotone subcurves to the right
// of their intersection point.
Comparison_result
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::compare_to_right
(const Self& cv,
const Point_2& p,
CGAL_precondition (p.compare_xy (right(), cache) != LARGER);
CGAL_precondition (p.compare_xy (cv.right(), cache) != LARGER);
if (this == &cv)
return (EQUAL);
// Make sure that p is incident to both curves (either equals the left
// endpoint or lies in the curve interior). Note that this is important to
// carry out these tests, as it assures us the eventually both curves are
// originators of p.
if (! p.equals (left(), cache))
if (point_position (p, cache) != EQUAL)
CGAL_precondition_msg (false, "p is not on cv1");
if (! p.equals (cv.left(), cache))
if (cv.point_position (p, cache) != EQUAL)
CGAL_precondition_msg (false, "p is not on cv2");
// Check for vertical subcurves. A vertical segment is above any other
// x-monotone subcurve to the right of their common endpoint.
if (is_vertical())
if (cv.is_vertical())
// Both are vertical segments with a common endpoint, so they overlap:
return (EQUAL);
return (LARGER);
else if (cv.is_vertical())
return (SMALLER);
// Check if both subcurves originate from the same Bezier curve.
// Get the originator, and check whether p is a vertical tangency
// point of this originator (otherwise it is a self-intersection point,
// and we proceed as if it is a regular intersection point).
Originator_iterator org = p.get_originator(_curve, _xid);
CGAL_assertion (org != p.originators_end());
if (org->point_bound().type == Bez_point_bound::VERTICAL_TANGENCY_PT)
CGAL_assertion (_inc_to_right != cv._inc_to_right);
if (! p.is_exact())
// Comparison based on the control polygon of the bounded vertical
// tangency point, using the fact this polygon is y-monotone.
const typename Bounding_traits::Control_points& cp =
org->point_bound().ctrl;
if (_inc_to_right)
return (CGAL::compare (cp.back().y(), cp.front().y()));
else
return (CGAL::compare (cp.front().y(), cp.back().y()));
// Iddo: Handle rational points (using de Casteljau derivative)?
// In this case we know that we have a vertical tangency at t0, so
// X'(t0) = 0. We evaluate the sign of Y'(t0) in order to find the
// vertical position of the two subcurves to the right of this point.
CGAL_assertion (org->has_parameter());
const Algebraic& t0 = org->parameter();
Polynomial polyY_der = nt_traits.derive (_curve.y_polynomial());
const CGAL::Sign sign_der =
CGAL::sign (nt_traits.evaluate_at (polyY_der, t0));
CGAL_assertion (sign_der != CGAL::ZERO);
if (_inc_to_right)
return ((sign_der == CGAL::POSITIVE) ? LARGER : SMALLER);
else
return ((sign_der == CGAL::NEGATIVE) ? LARGER : SMALLER);
// Compare the slopes of the two supporting curves at p. In the general
// case, the slopes are not equal and their comparison gives us the
// vertical order to p's right.
Comparison_result slope_res = _compare_slopes (cv, p, cache);
if (slope_res != EQUAL)
return (slope_res);
// Compare the two subcurves by choosing some point to the right of p
// and comparing the vertical position there.
Comparison_result right_res;
if (right().compare_x (cv.right(), cache) != LARGER)
right_res = _compare_to_side (cv, p,
true, // Compare to p's right.
cache);
else
right_res = cv._compare_to_side (*this, p,
cache);
right_res = CGAL::opposite (right_res);
return (right_res);
// Compare the relative y-position of two x-monotone subcurve to the left
Comparison_result
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::compare_to_left
(const Self& cv,
const Point_2& p,
CGAL_precondition (p.compare_xy (left(), cache) != SMALLER);
CGAL_precondition (p.compare_xy (cv.left(), cache) != SMALLER);
if (this == &cv)
return (EQUAL);
// Make sure that p is incident to both curves (either equals the right
if (! p.equals (right(), cache))
if (! p.equals (cv.right(), cache))
// Check for vertical subcurves. A vertical segment is below any other
// x-monotone subcurve to the left of their common endpoint.
if (is_vertical())
return (EQUAL);
return (SMALLER);
return (LARGER);
Originator_iterator org = p.get_originator (_curve, _xid);
if (! p.is_exact())
if (_inc_to_right)
return (CGAL::compare(cp.front().y(), cp.back().y()));
else
return (CGAL::compare(cp.back().y(), cp.front().y()));
if (_inc_to_right)
else
// vertical order to p's right; note that we swap the order of the curves
// to obtains their position to the left.
Comparison_result slope_res = cv._compare_slopes (*this, p, cache);
return (slope_res);
// Compare the two subcurves by choosing some point to the left of p
// and compareing the vertical position there.
Comparison_result left_res;
if (left().compare_x (cv.left(), cache) != SMALLER)
left_res = _compare_to_side (cv, p,
false, // Compare to p's left.
cache);
else
left_res = cv._compare_to_side (*this, p,
cache);
left_res = CGAL::opposite (left_res);
return (left_res);
// Check whether the two subcurves are equal (have the same graph).
bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::equals
(const Self& cv,
// Check if the two subcurve have overlapping supporting curves.
if (! _curve.is_same (cv._curve))
// Check whether the two curves have the same support:
if (! _curve.has_same_support (cv._curve))
return (false);
// Mark that the two curves overlap in the cache.
const Curve_id id1 = _curve.id();
const Curve_id id2 = cv._curve.id();
if (id1 < id2)
cache.mark_as_overlapping (id1, id2);
else
cache.mark_as_overlapping (id2, id1);
// Check for equality of the endpoints.
return (left().equals (cv.left(), cache) &&
right().equals (cv.right(), cache));
// Split the subcurve into two at a given split point.
void _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::split
(const Point_2& p,
CGAL_precondition (p.get_originator (_curve, _xid) != p.originators_end());
// Duplicate the curve.
c1 = c2 = *this;
// Perform the split.
if (_dir_right)
c1._pt = p;
c2._ps = p;
else
c1._ps = p;
c2._pt = p;
return;
// Check if the two subcurves are mergeable.
bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::can_merge_with
// Note that we only allow merging subcurves of the same originating
// Bezier curve (overlapping curves will not do in this case).
return (_curve.is_same (cv._curve) &&
_xid == cv._xid &&
(right().is_same (cv.left()) || left().is_same (cv.right())));
return (false);
// Merge the current arc with the given arc.
typename _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::Self
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::merge
CGAL_precondition (_curve.is_same (cv._curve));
CGAL_precondition (_xid == cv._xid);
Self res = cv;
if (right().is_same (cv.left()))
// Extend the subcurve to the right.
if (_dir_right)
res._pt = cv.right();
else
res._ps = cv.right();
else
CGAL_precondition (left().is_same (cv.right()));
// Extend the subcurve to the left.
if (_dir_right)
res._ps = cv.left();
else
res._pt = cv.left();
return (res);
// Check if the given t-value is in the range of the subcurve.
bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_is_in_range
bool p_lt_ps =
(CGAL::compare (t, nt_traits.convert (s_org->point_bound().t_min)) ==
SMALLER);
bool p_gt_ps =
(CGAL::compare (t, nt_traits.convert (s_org->point_bound().t_max)) ==
LARGER);
bool p_lt_pt =
(CGAL::compare (t, nt_traits.convert (t_org->point_bound().t_min)) ==
SMALLER);
bool p_gt_pt =
(CGAL::compare (t, nt_traits.convert (t_org->point_bound().t_max)) ==
LARGER);
if ((p_gt_ps && p_lt_pt) || (p_lt_ps && p_gt_pt))
// The point p is definately in the x-range of the subcurve, as its
// parameter is between the source and target parameters.
return (true);
if ((p_lt_ps && p_lt_pt) || (p_gt_ps && p_gt_pt))
// The point p is definately not in the x-range of the subcurve,
// as its parameter is smaller than both source and target parameter
// (or greater than both of them).
return (false);
// Obtain the exact t-range of the curve and peform an exact comparison.
std::pair<Algebraic, Algebraic> range = _t_range (cache);
const Algebraic& t_src = range.first;
const Algebraic& t_trg = range.second;
const Comparison_result res1 = CGAL::compare (t, t_src);
const Comparison_result res2 = CGAL::compare (t, t_trg);
return (res1 == EQUAL || res2 == EQUAL || res1 != res2);
// Check if the given point lies in the range of this x-monotone subcurve.
(const Point_2& p,
is_certain = true;
// Check the easy case that p is one of the subcurve endpoints.
if (p.is_same(_ps) || p.is_same(_pt))
return true;
// Compare the parameter of p with the parameters of the endpoints.
if (p_org == p.originators_end())
CGAL_assertion (p.get_originator (_curve) != p.originators_end());
// In this case a different x-monotone curve of the supporting Bezier
// curve is an originator of the point, so we know that p does not
// lie in the range of our x-monotone subcurve.
return (false);
bool can_refine_p = ! p.is_exact();
bool can_refine_s = ! _ps.is_exact();
bool can_refine_t = ! _pt.is_exact();
while (can_refine_p || can_refine_s || can_refine_t)
bool p_lt_ps = (CGAL::compare (p_org->point_bound().t_max,
s_org->point_bound().t_min) == SMALLER);
bool p_gt_ps = (CGAL::compare (p_org->point_bound().t_min,
s_org->point_bound().t_max) == LARGER);
bool p_lt_pt = (CGAL::compare (p_org->point_bound().t_max,
t_org->point_bound().t_min) == SMALLER);
bool p_gt_pt = (CGAL::compare (p_org->point_bound().t_min,
t_org->point_bound().t_max) == LARGER);
return (true);
return (false);
// Try to refine the points.
if (can_refine_p)
can_refine_p = p.refine();
if (can_refine_s)
can_refine_s = _ps.refine();
if (can_refine_t)
can_refine_t = _pt.refine();
// If we reached here, we do not have a certain answer.
is_certain = false;
return (false);
// Given a point p that lies on the supporting Bezier curve (X(t), Y(t)),
// determine whether p lies within the t-range of the x-monotone subcurve.
// If so, the value t0 such that p = (X(t0), Y(t0)) is also computed.
(const Point_2& p,
Algebraic& t0,
// The given point p must be rational, otherwise there is no point checking
// whether it lies in the interior of the curve.
if (! p.is_rational())
is_endpoint = false;
return (false);
// Determine the parameter range [t_min, t_max] for our x-monotone
// subcurve.
std::pair<Algebraic, Algebraic> t_range = _t_range (cache);
Algebraic t_min, t_max;
if ((_dir_right && _inc_to_right) || (! _dir_right && ! _inc_to_right))
t_min = t_range.first;
t_max = t_range.second;
else
t_min = t_range.second;
t_max = t_range.first;
// The given point p must lie on (X(t), Y(t)) for some t-value. Obtain the
// parameter value t0 for that point. We start by computing all t-values
// such that X(t) equals the x-coordinate of p.
std::list<Algebraic> t_vals;
typename std::list<Algebraic>::iterator t_iter;
Comparison_result res1, res2;
Algebraic y0;
_curve.get_t_at_x (rat_p.x(), std::back_inserter(t_vals));
CGAL_assertion (! t_vals.empty());
for (t_iter = t_vals.begin(); t_iter != t_vals.end(); ++t_iter)
// Compare the current t-value with t_min.
res1 = CGAL::compare (t_min, *t_iter);
if (res1 == LARGER)
continue;
// Make sure the y-coordinates match.
y0 = nt_traits.evaluate_at (_curve.y_polynomial(), *t_iter) /
nt_traits.convert (_curve.y_norm());
if (CGAL::compare (nt_traits.convert (rat_p.y()), y0) == EQUAL)
if (res1 == EQUAL)
t0 = t_min;
is_endpoint = true;
return (true);
// Compare the current t-value with t_max.
res2 = CGAL::compare (t_max, *t_iter);
if (res2 == EQUAL)
t0 = t_max;
is_endpoint = true;
return (true);
if (res2 == LARGER)
t0 = *t_iter;
return (true);
// In this case, we have not found a t-value in the range of our subcurve,
// so p does not lie on the subcurve:
return (false);
// Compute a y-coordinate of a point on the x-monotone subcurve with a
// given x-coordinate.
typename _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::Algebraic
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_get_y
// Obtain the t-values for with the x-coordinates of the supporting
// curve equal x0.
_curve.get_t_at_x (x0, std::back_inserter(t_vals));
// Find a t-value that is in the range of the current curve.
const Algebraic& t_src = t_range.first;
const Algebraic& t_trg = t_range.second;
res1 = CGAL::compare (*t_iter, t_src);
if (res1 == EQUAL)
// Return the y-coordinate of the source point:
return (_ps.y());
res2 = CGAL::compare (*t_iter, t_trg);
if (res2 == EQUAL)
return (_pt.y());
if (res1 != res2)
// We found a t-value in the range of our x-monotone subcurve.
// Use this value to compute the y-coordinate.
return (nt_traits.evaluate_at (_curve.y_polynomial(), *t_iter) /
nt_traits.convert (_curve.y_norm()));
// If we reached here, x0 is not in the x-range of our subcurve.
CGAL_error();
return (0);
// Compare the slopes of the subcurve with another given Bezier subcurve at
// their given intersection point.
Comparison_result
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_compare_slopes
(const Self& cv,
const Point_2& p,
// Get the originators of p.
Originator_iterator org1 = p.get_originator (_curve, _xid);
const bool valid_org1 = (org1 != p.originators_end());
Originator_iterator org2 = p.get_originator (cv._curve, cv._xid);
const bool valid_org2 = (org2 != p.originators_end());
CGAL_assertion (valid_org1 || valid_org2);
// If the point is only approximated, we can carry out a comparison using
// an approximate number type.
if (valid_org1 && valid_org2 && ! p.is_exact())
// If the point is inexact, we assume it is a bounded intersection
// point of two curves, and therefore the bounding angle these curves
// span do not overlap.
const Bez_point_bound& bound1 = org1->point_bound();
const Bez_point_bound& bound2 = org2->point_bound();
Bounding_traits bound_tr;
return (bound_tr.compare_slopes_at_intersection_point (bound1,
bound2));
// Obtain the parameter values t1 and t2 that correspond to the point p.
// Note that it is possible that one of the curves is not an originator
// of p. This can happen if p is an endpoint of the other curve (hence
// it must be a ratioal point!) and lies in its interior. In this
// (degenerate) case we compute the parameter value and set the appropriate
// originator for p.
Algebraic t1;
Algebraic t2;
if (valid_org1)
CGAL_assertion (org1->has_parameter());
t1 = org1->parameter();
else
bool is_endpoint1;
CGAL_assertion_code (bool in_range1 =)
_is_in_range (p, cache, t1, is_endpoint1);
CGAL_assertion (in_range1);
p.add_originator (Originator (_curve, _xid, t1));
if (valid_org2)
CGAL_assertion (org2->has_parameter());
t2 = org2->parameter();
else
bool is_endpoint2;
CGAL_assertion_code (bool in_range2 =)
cv._is_in_range (p, cache, t2, is_endpoint2);
CGAL_assertion (in_range2);
p.add_originator (Originator (cv._curve, cv._xid, t2));
// The slope of (X(t), Y(t)) at t0 is given by Y'(t0)/X'(t0).
// Compute the slope of (*this).
// Note that we take special care of the case X'(t0) = 0, when the tangent
// is vertical and its slope is +/- oo.
Polynomial derivX = nt_traits.derive (_curve.x_polynomial());
Polynomial derivY = nt_traits.derive (_curve.y_polynomial());
Algebraic numer1 = nt_traits.evaluate_at (derivY, t1) *
nt_traits.convert (_curve.x_norm());
Algebraic denom1 = nt_traits.evaluate_at (derivX, t1) *
CGAL::Sign inf_slope1 = CGAL::ZERO;
Algebraic slope1;
if (CGAL::sign (denom1) == CGAL::ZERO)
inf_slope1 = is_directed_right() ? CGAL::sign (numer1) : CGAL::opposite( CGAL::sign (numer1) );
// If both derivatives are zero, we cannot perform the comparison:
if (inf_slope1 == CGAL::ZERO)
return (EQUAL);
else
slope1 = numer1 / denom1;
// Compute the slope of the other subcurve.
derivX = nt_traits.derive (cv._curve.x_polynomial());
derivY = nt_traits.derive (cv._curve.y_polynomial());
Algebraic numer2 = nt_traits.evaluate_at (derivY, t2) *
nt_traits.convert (cv._curve.x_norm());
Algebraic denom2 = nt_traits.evaluate_at (derivX, t2) *
nt_traits.convert (cv._curve.y_norm());
CGAL::Sign inf_slope2 = CGAL::ZERO;
Algebraic slope2;
if (CGAL::sign (denom2) == CGAL::ZERO)
inf_slope2 = cv.is_directed_right() ? CGAL::sign (numer2) : CGAL::opposite( CGAL::sign (numer2) );
if (inf_slope2 == CGAL::ZERO)
return (EQUAL);
else
slope2 = numer2 / denom2;
// Handle the comparison when one slope (or both) is +/- oo.
if (inf_slope1 == CGAL::POSITIVE)
return (inf_slope2 == CGAL::POSITIVE ? EQUAL : LARGER);
if (inf_slope1 == CGAL::NEGATIVE)
return (inf_slope2 == CGAL::NEGATIVE ? EQUAL : SMALLER);
if (inf_slope2 == CGAL::POSITIVE)
return (SMALLER);
if (inf_slope2 == CGAL::NEGATIVE)
return (LARGER);
// Compare the slopes.
return (CGAL::compare (slope1, slope2));
// Get the range of t-value over which the subcurve is defined.
std::pair<typename _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt,
BndTrt>::Algebraic,
BndTrt>::Algebraic>
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_t_range
CGAL_assertion(ps_org != _ps.originators_end());
CGAL_assertion(pt_org != _pt.originators_end());
// Make sure that the two endpoints are exact.
if (! ps_org->has_parameter())
if (! pt_org->has_parameter())
return (std::make_pair (ps_org->parameter(),
pt_org->parameter()));
// Compare the relative y-position of two x-monotone subcurve to the right
// (or to the left) of their intersection point, whose multiplicity is
// greater than 1.
Comparison_result
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_compare_to_side
(const Self& cv,
const Point_2& p,
bool to_right,
// Get the intersection points of the two curves from the cache. Note that
// we make sure that the ID of this->_curve is smaller than of cv's curve ID.
const bool no_swap_curves = (_curve.id() <= cv._curve.id());
bool do_ovlp;
(no_swap_curves ?
cv._curve.id(),
cv._curve.x_polynomial(), cv._curve.x_norm(),
cv._curve.y_polynomial(), cv._curve.y_norm(),
do_ovlp)) :
(cache.get_intersections (cv._curve.id(),
_curve.id(),
do_ovlp)));
// Get the parameter value for the point p.
// Get the parameter range of the curve.
const std::pair<Algebraic,
Algebraic>& range = _t_range (cache);
// Find the next intersection point that lies to the right of p.
Intersect_iter iit;
Algebraic next_t;
Comparison_result res = CGAL::EQUAL;
bool found = false;
// Check if the current point lies to the right (left) of p. We do so by
// considering its originating parameter value s (or t, if we swapped
// the curves).
const Algebraic& t = (no_swap_curves ? (iit->s) : iit->t);
res = CGAL::compare (t, t0);
if ((to_right && ((_inc_to_right && res == LARGER) ||
(! _inc_to_right && res == SMALLER))) ||
(! to_right && ((_inc_to_right && res == SMALLER) ||
(! _inc_to_right && res == LARGER))))
if (! found)
next_t = t;
found = true;
else
// If we have already located an intersection point to the right
// (left) of p, choose the leftmost (rightmost) of the two points.
res = CGAL::compare (t, next_t);
if ((to_right && ((_inc_to_right && res == SMALLER) ||
(! _inc_to_right && res == LARGER))) ||
(! to_right && ((_inc_to_right && res == LARGER) ||
(! _inc_to_right && res == SMALLER))))
next_t = t;
// If the next intersection point occurs before the right (left) endpoint
// of the subcurve, keep it. Otherwise, take the parameter value at
// the endpoint.
if (found)
if (to_right == _dir_right)
res = CGAL::compare (t_trg, next_t);
else
res = CGAL::compare (t_src, next_t);
if (! found ||
next_t = ((to_right == _dir_right) ? t_trg : t_src);
// Find a rational value between t0 and t_next. Using this value, we
// a point with rational coordinates on our subcurve. We also locate a point
// on the other curve with the same x-coordinates.
const Rational& mid_t = nt_traits.rational_in_interval (t0, next_t);
const Rat_point_2& q1 = _curve (mid_t);
const Algebraic& y2 = cv._get_y (q1.x(), cache);
// We now just have to compare the y-coordinates of the two points we have
// computed.
return (CGAL::compare (nt_traits.convert (q1.y()), y2));
// Clip the control polygon of the supporting Bezier curve such that it fits
// the current x-monotone subcurve.
BndTrt>::_clip_control_polygon
// Start from the control polygon of the supporting curve.
ctrl.clear();
std::back_inserter (ctrl));
// The x-monotone subcurve is defined over a parameter range
// 0 <= t_min < t_max <= 1. Determine the endpoint with minimal t-value and
// the one with maximal t-value.
const Point_2& p_min = (_inc_to_right ? left() : right());
Originator_iterator org_min = p_min.get_originator (_curve, _xid);
const Point_2& p_max = (_inc_to_right ? right() : left());
Originator_iterator org_max = p_max.get_originator (_curve, _xid);
bool clipped_min = false;
CGAL_assertion (org_min != p_min.originators_end());
CGAL_assertion (org_max != p_max.originators_end());
// Check if t_min = 0. If so, there is no need to clip.
if (! (org_min->point_bound().type == Bez_point_bound::RATIONAL_PT &&
CGAL::sign (org_min->point_bound().t_min) == CGAL::ZERO))
// It is possible that the paramater range of the originator is too large.
// We therefore make sure it fits the current bounding box of the point
// (which we know is tight enough).
p_min.fit_to_bbox();
// Obtain two control polygons, the first for [0, t_min] and the other for
// [t_min, 1] and take the second one.
typename Bounding_traits::Control_points cp_a;
typename Bounding_traits::Control_points cp_b;
t_min = org_min->point_bound().t_max;
de_Casteljau_2 (ctrl.begin(), ctrl.end(),
t_min,
std::back_inserter(cp_a),
std::front_inserter(cp_b));
ctrl.clear();
std::copy (cp_b.begin(), cp_b.end(),
clipped_min = true;
else
t_min = 0;
// Check if t_max = 1. If so, there is no need to clip.
if (! (org_max->point_bound().type == Bez_point_bound::RATIONAL_PT &&
CGAL::compare (org_max->point_bound().t_max, 1) == CGAL::EQUAL))
p_max.fit_to_bbox();
// Obtain two control polygons, the first for [t_min, t_max] and the other
// for [t_max, 1] and take the first one.
if (clipped_min)
t_max = (org_max->point_bound().t_min - t_min) / (1 - t_min);
else
t_max = org_max->point_bound().t_min;
t_max,
ctrl.clear();
std::copy (cp_a.begin(), cp_a.end(),
else
t_max = 1;
return;
// Approximate the intersection points between the two given curves.
BndTrt>::_approximate_intersection_points
(const Self& cv,
typedef typename Bounding_traits::Intersection_point Intersection_point;
inter_pts.clear();
// Get the supporting Bezier curves, and make local copies of their control
// polygons.
const Curve_2& B1 = this->_curve;
const Curve_2& B2 = cv._curve;
typename Bounding_traits::Control_points cp1;
typename Bounding_traits::NT t_min1 = 0, t_max1 = 1;
typename Bounding_traits::Control_points cp2;
typename Bounding_traits::NT t_min2 = 0, t_max2 = 1;
bool is_self_intersection = false;
if (! B1.is_same (B2))
// In case B1 and B2 are different curves, use their full control polygons
// in order to approximate all intersection points between the two
// supporting Bezier curves.
std::copy (B1.control_points_begin(), B1.control_points_end(),
std::back_inserter (cp1));
std::copy (B2.control_points_begin(), B2.control_points_end(),
std::back_inserter(cp2));
else
// In this case we need to approximate the (self-)intersection points of
// two subcurves of the same Bezier curve. Clip the control polygons and
// obtain the control polygons of the two subcurves.
_clip_control_polygon (cp1, t_min1, t_max1);
cv._clip_control_polygon (cp2, t_min2, t_max2);
is_self_intersection = true;
// Use the bounding traits to isolate the intersection points.
std::list<Intersection_point> ipt_bounds;
bound_tr.compute_intersection_points (cp1, cp2,
std::back_inserter (ipt_bounds));
// Construct the approximated points.
typename std::list<Intersection_point>::const_iterator iter;
for (iter = ipt_bounds.begin(); iter != ipt_bounds.end(); ++iter)
const Bez_point_bound& bound1 = iter->bound1;
const Bez_point_bound& bound2 = iter->bound2;
const Bez_point_bbox& bbox = iter->bbox;
// In case it is impossible to further refine the point, stop here.
if (! bound1.can_refine || ! bound2.can_refine)
return (false);
// Create the approximated intersection point.
Point_2 pt;
if (bound1.type == Bounding_traits::Bez_point_bound::RATIONAL_PT &&
bound2.type == Bounding_traits::Bez_point_bound::RATIONAL_PT)
CGAL_assertion (CGAL::compare (bound1.t_min, bound1.t_max) == EQUAL);
CGAL_assertion (CGAL::compare (bound2.t_min, bound2.t_max) == EQUAL);
Rational t1 = bound1.t_min;
Rational t2 = bound2.t_min;
if (is_self_intersection)
// Set the originators with the curve x-monotone IDs.
// Note that the parameter values we have computed relate to the
// parameter range [t_min1, t_max1] and [t_min2, t_max2], respectively,
// so we scale them back to the parameter range [0, 1] that represent
// the entire curve.
t1 = t_min1 + t1 * (t_max1 - t_min1);
t2 = t_min2 + t2 * (t_max2 - t_min2);
pt = Point_2 (B1, _xid, t1);
pt.add_originator (Originator (B2, cv._xid, t2));
else
// Set the originators referring to the entire supporting curves.
pt = Point_2 (B1, t1);
pt.add_originator (Originator (B2, nt_traits.convert (t2)));
else
Bez_point_bound sc_bound1 = bound1;
sc_bound1.t_min = t_min1 + bound1.t_min * (t_max1 - t_min1);
sc_bound1.t_max = t_min1 + bound1.t_max * (t_max1 - t_min1);
pt.add_originator (Originator (B1, _xid, sc_bound1));
Bez_point_bound sc_bound2 = bound2;
sc_bound2.t_min = t_min2 + bound2.t_min * (t_max2 - t_min2);
sc_bound2.t_max = t_min2 + bound2.t_max * (t_max2 - t_min2);
pt.add_originator (Originator (B2, cv._xid, sc_bound2));
else
pt.add_originator (Originator (B1, bound1));
pt.add_originator (Originator (B2, bound2));
pt.set_bbox (bbox);
inter_pts.push_back (pt);
// The approximation process ended OK.
return (true);
// Compute the intersections with the given subcurve.
bool _Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_intersect
(const Self& cv,
CGAL_precondition (_curve.id() <= cv._curve.id());
ipts.clear();
// In case the two x-monotone curves are subcurves of the same Bezier curve,
// first check if this base curve is not self-intersecting. If this is the
// case we can avoid any attempt of computing intersection points between
// the two subcurves.
const bool self_intersect = (_curve.id() == cv._curve.id());
if (self_intersect)
if (_xid == cv._xid)
return (false);
if (_curve.has_no_self_intersections())
return (false);
// Construct the pair of curve IDs and look for it in the intersection map.
Curve_pair curve_pair (_curve.id(), cv._curve.id());
Intersection_map_iterator map_iter = inter_map.find (curve_pair);
std::list<Point_2> inter_pts;
bool app_ok = true;
if (map_iter != inter_map.end())
// Get the intersection points between the two supporting curves as stored
// in the map.
inter_pts = map_iter->second;
else
// Approximate the intersection points and store them in the map.
// Note that we do not store approximated self-intersections in the map,
// as they realte only to the pecific x-monotone curves, and not to the
// entire curve.
app_ok = _approximate_intersection_points (cv,
inter_pts);
if (app_ok && ! self_intersect)
inter_map[curve_pair] = inter_pts;
// Try to approximate the intersection points.
bool in_range1, in_range2;
bool correct_res;
if (app_ok)
// If the approximation went OK, then we know that we just have simple
// intersection points (with multiplicity 1). We go over the points
// and report the ones lying in the parameter ranges of both curves.
// Note that in case of self-intersections, all points we get are in
// the respective parameter range of the curves.
typename std::list<Point_2>::iterator pit;
for (pit = inter_pts.begin(); pit != inter_pts.end(); ++pit)
// Check if the point is in the range of this curve - first using
// its parameter bounds, and if we fail we perform an exact check.
if (! self_intersect)
in_range1 = _is_in_range (*pit, correct_res);
else
in_range1 = true;
correct_res = true;
if (! correct_res)
if (! pit->is_exact())
pit->make_exact (cache);
Originator_iterator p_org = pit->get_originator (_curve, _xid);
CGAL_assertion (p_org != pit->originators_end());
in_range1 = _is_in_range (p_org->parameter(), cache);
if (! in_range1)
continue;
// Check if the point is in the range of the other curve - first using
in_range2 = cv._is_in_range (*pit, correct_res);
else
in_range2 = true;
correct_res = true;
if (! correct_res)
Originator_iterator p_org = pit->get_originator (cv._curve, cv._xid);
in_range2 = cv._is_in_range (p_org->parameter(), cache);
if (in_range1 && in_range2)
// In case the originators of the intersection point are not marked
// with x-monotone identifiers, mark them now as we know in which
// subcurves they lie.
Originator_iterator p_org1 = pit->get_originator (_curve, _xid);
CGAL_assertion (p_org1 != pit->originators_end());
if (p_org1->xid() == 0)
pit->update_originator_xid (*p_org1, _xid);
Originator_iterator p_org2 = pit->get_originator (cv._curve, cv._xid);
CGAL_assertion (p_org2 != pit->originators_end());
if (p_org2->xid() == 0)
pit->update_originator_xid (*p_org2, cv._xid);
// The point lies within the parameter range of both curves, so we
// report it as a valid intersection point with multiplicity 1.
ipts.push_back (Intersection_point_2 (*pit, 1));
// Since the apporximation went fine we cannot possibly have an overlap:
return (false);
// We did not succeed in isolate the approximate intersection points.
// We therefore resort to the exact procedure and exactly compute them.
bool do_ovlp;
cv._curve.id(),
do_ovlp);
if (do_ovlp)
// Check the case of co-inciding endpoints
if (left().equals (cv.left(), cache))
if (right().equals (cv.right(), cache))
// The two curves entirely overlap one another:
ovlp_cv = cv;
return (true);
Algebraic t_right;
bool is_endpoint;
if (_is_in_range (cv.right(), cache, t_right, is_endpoint))
CGAL_assertion (! is_endpoint);
// Case 1 - *this: s +-----------+ t
// cv: s'+=====+ t'
// Take cv as the overlapping subcurve, and add originators for its
// right endpoint referring to *this.
ovlp_cv = cv;
ovlp_cv.right().add_originator (Originator (_curve, _xid, t_right));
return (true);
else if (cv._is_in_range (right(), cache, t_right, is_endpoint))
// Case 2 - *this: s +----+ t
// cv: s'+==========+ t'
// Take this as the overlapping subcurve, and add originators for its
// right endpoint referring to cv.
ovlp_cv = *this;
ovlp_cv.right().add_originator (Originator (cv._curve, cv._xid,
t_right));
return (true);
// In this case the two curves do not overlap, but have a common left
// endpoint.
ipts.push_back (Intersection_point_2 (left(), 0));
return (false);
else if (right().equals (cv.right(), cache))
Algebraic t_left;
bool is_endpoint;
if (_is_in_range (cv.left(), cache, t_left, is_endpoint))
// Case 3 - *this: s +-----------+ t
// cv: s'+=====+ t'
// left endpoint referring to *this.
ovlp_cv = cv;
ovlp_cv.left().add_originator (Originator (_curve, _xid, t_left));
return (true);
else if (cv._is_in_range (left(), cache, t_left, is_endpoint))
// Case 4 - *this: s +----+ t
// left endpoint referring to cv.
ovlp_cv = *this;
ovlp_cv.left().add_originator (Originator (cv._curve, cv._xid,
t_left));
return (true);
// In this case the two curves do not overlap, but have a common right
// endpoint.
ipts.push_back (Intersection_point_2 (right(), 0));
return (false);
// If we reached here, none of the endpoints coincide.
// Check the possible overlap scenarios.
Point_2 ovrp_src, ovlp_trg;
Algebraic t_cv_src;
Algebraic t_cv_trg;
bool is_endpoint = false;
if (_is_in_range (cv._ps, cache, t_cv_src, is_endpoint) &&
! is_endpoint)
if (_is_in_range (cv._pt, cache, t_cv_trg, is_endpoint) &&
! is_endpoint)
// Case 5 - *this: s +-----------+ t
// cv: s' +=====+ t'
// endpoints referring to *this.
ovlp_cv = cv;
ovlp_cv._ps.add_originator (Originator (_curve, _xid, t_cv_src));
ovlp_cv._pt.add_originator (Originator (_curve, _xid, t_cv_trg));
return (true);
else
// Case 6 - *this: s +-----------+ t
// Use *this as a base, and replace its source point.
ovlp_cv = *this;
ovlp_cv._ps = cv._ps;
// Add an originator to the target point, referring to cv:
CGAL_assertion_code (bool pt_in_cv_range =)
cv._is_in_range (ovlp_cv._pt, cache, t_cv_trg, is_endpoint);
CGAL_assertion (pt_in_cv_range);
ovlp_cv._pt.add_originator (Originator (cv._curve, cv._xid, t_cv_trg));
return (true);
else if (_is_in_range (cv._pt, cache, t_cv_trg, is_endpoint) &&
! is_endpoint)
// Case 7 - *this: s +-----------+ t
// Use *this as a base, and replace its target point.
ovlp_cv = *this;
ovlp_cv._pt = cv._pt;
// Add an originator to the source point, referring to cv:
CGAL_assertion_code (bool ps_in_cv_range =)
cv._is_in_range (ovlp_cv._ps, cache, t_cv_src, is_endpoint);
CGAL_assertion (ps_in_cv_range);
ovlp_cv._ps.add_originator (Originator (cv._curve, cv._xid, t_cv_src));
return (true);
else if (cv._is_in_range (_ps, cache, t_cv_src, is_endpoint) &&
cv._is_in_range (_pt, cache, t_cv_trg, is_endpoint))
// Case 8 - *this: s +---------+ t
// cv: s' +================+ t'
// Take *this as the overlapping subcurve, and add originators for its
// endpoints referring to cv.
ovlp_cv = *this;
return (true);
// If we reached here, there are no overlaps:
return (false);
// Go over the points and report the ones lying in the parameter ranges
// of both curves.
Intersect_iter iit;
if (_is_in_range (iit->s, cache) &&
cv._is_in_range (iit->t, cache))
// Construct an intersection point with unknown multiplicity.
Point_2 pt (iit->x, iit->y,
true); // Dummy parameter.
pt.add_originator (Originator (_curve, _xid, iit->s));
pt.add_originator (Originator (cv._curve, cv._xid, iit->t));
ipts.push_back (Intersection_point_2 (pt, 0));
// Mark that there is no overlap:
return (false);
// Compute the exact vertical position of the point p with respect to the
// curve.
Comparison_result
_Bezier_x_monotone_2<RatKer, AlgKer, NtTrt, BndTrt>::_exact_vertical_position
(const Point_2& p,
// If it is a rational point, obtain its rational reprsentation.
Rat_point_2 rat_p;
if (p.is_rational())
// Get a rational approximation of the parameter values at the endpoints.
Rational my_t_min;
Rational my_t_max;
// In case the parameter value of the source is smaller than the target's.
my_t_min = ps_org->point_bound().t_max;
my_t_max = pt_org->point_bound().t_min;
else
CGAL_assertion (CGAL::compare (pt_org->point_bound().t_max,
ps_org->point_bound().t_min) == SMALLER);
// In case the parameter value of the target is smaller than the source's.
my_t_min = pt_org->point_bound().t_max;
my_t_max = ps_org->point_bound().t_min;
// Start the subdivision process from the entire supporting curve.
std::list<Subcurve> subcurves;
Subcurve init_scv;
Rational x_min, y_min, x_max, y_max;
bool no_x_ovlp;
Comparison_result res_y_min, res_y_max;
std::back_inserter (init_scv.control_points));
init_scv.t_min = 0;
init_scv.t_max = 1;
subcurves.push_back (init_scv);
while (! subcurves.empty())
// Go over the list of subcurves and consider only those lying in the
// given [t_min, t_max] bound.
typename std::list<Subcurve>::iterator iter = subcurves.begin();
bool is_fully_in_range;
while (iter != subcurves.end())
if (CGAL::compare (iter->t_max, my_t_min) == SMALLER ||
CGAL::compare (iter->t_min, my_t_max) == LARGER)
// Subcurve out of bounds of the x-monotone curve we consider - erase
// it and continue to next subcurve.
subcurves.erase(iter++);
continue;
// Construct the bounding box of the subcurve and compare it to
// the bounding box of the point.
iter->bbox (x_min, y_min, x_max, y_max);
no_x_ovlp = (CGAL::compare (x_min, rat_p.x()) == LARGER ||
CGAL::compare (x_max, rat_p.x()) == SMALLER);
else
no_x_ovlp = (CGAL::compare (nt_traits.convert (x_min),
p.x()) == LARGER ||
CGAL::compare (nt_traits.convert (x_max),
p.x()) == SMALLER);
if (no_x_ovlp)
// Subcurve out of x-bounds - erase it and continue to next subcurve.
continue;
// In this case, check if there is an overlap in the y-range.
res_y_min = CGAL::compare (rat_p.y(), y_min);
res_y_max = CGAL::compare (rat_p.y(), y_max);
else
res_y_min = CGAL::compare (p.y(), nt_traits.convert (y_min));
res_y_max = CGAL::compare (p.y(), nt_traits.convert (y_max));
is_fully_in_range = (CGAL::compare (iter->t_min, my_t_min) != SMALLER) &&
(CGAL::compare (iter->t_max, my_t_max) != LARGER);
if (res_y_min != res_y_max || ! is_fully_in_range)
// Subdivide the current subcurve and replace iter with the two
// resulting subcurves using de Casteljau's algorithm.
Subcurve scv_l, scv_r;
scv_l.t_min = iter->t_min;
scv_r.t_max = iter->t_max;
scv_l.t_max = scv_r.t_min = (iter->t_min + iter->t_max) / 2;
bisect_control_polygon_2 (iter->control_points.begin(),
iter->control_points.end(),
std::back_inserter(scv_l.control_points),
std::front_inserter(scv_r.control_points));
subcurves.insert (iter, scv_l);
subcurves.insert (iter, scv_r);
continue;
if (res_y_min == res_y_max)
CGAL_assertion (res_y_min != EQUAL);
// We reached a separation, as p is either strictly above or strictly
// below the bounding box of the current subcurve.
return (res_y_min);
// If we got here without entering one of the clauses above,
// then iter has not been incremented yet.
++iter;
// We can reach here only if we do not force an exact result.
CGAL_assertion (! force_exact);
return (EQUAL);
} //namespace CGAL
#endif
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/About-Bezier-curves-in-Arrangement-tp3238384p3259984.htmlTo unsubscribe from About Bezier curves in Arrangement, click here.
View this message in context: Re: About Bezier curves in Arrangement
- Re: [cgal-discuss] Re: About Bezier curves in Arrangement, Sebastien Loriot (GeometryFactory), 02/01/2011
- [cgal-discuss] Re: About Bezier curves in Arrangement, stzpz, 02/03/2011
- Re: [cgal-discuss] Re: About Bezier curves in Arrangement, Sebastien Loriot (GeometryFactory), 02/04/2011
- [cgal-discuss] Re: About Bezier curves in Arrangement, stzpz, 02/05/2011
- Re: [cgal-discuss] Re: About Bezier curves in Arrangement, Sebastien Loriot (GeometryFactory), 02/07/2011
- [cgal-discuss] Re: About Bezier curves in Arrangement, stzpz, 02/11/2011
- Re: [cgal-discuss] Re: About Bezier curves in Arrangement, Sebastien Loriot (GeometryFactory), 02/11/2011
- [cgal-discuss] Re: About Bezier curves in Arrangement, stzpz, 02/12/2011
- Re: [cgal-discuss] Re: About Bezier curves in Arrangement, Sebastien Loriot (GeometryFactory), 02/16/2011
- Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement, 碰碰, 02/12/2011
- Re:Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement, 碰碰, 02/12/2011
- Re:Re:Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement, 碰碰, 02/12/2011
- Re:Re:Re:Re:Re: [cgal-discuss] Re: About Bezier curves in Arrangement, 碰碰, 02/12/2011
