[cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- To:
- Subject: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- Date: Fri, 18 Feb 2011 11:05:53 -0800 (PST)
On Fri, Feb 18, 2011 at 8:02 PM, Laurent Rineau (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
Le vendredi 18 février 2011 18:57:39, nyiotis a écrit :
> On Fri, Feb 18, 2011 at 6:45 PM, Laurent Rineau (GeometryFactory) [via
>> cgal-discuss] <[hidden email]> wrote:> Voronoi2D/3D needs TAUCS right? *
> > Le vendredi 18 février 2011 17:33:46, nyiotis a écrit :
> > Some parts of examples/Surface_reconstruction do need TAUCS.
> > > Configuring
> > /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Triangulation_2
> > > example
> > > Configuring
> > /Users/nikos/NetBeansProjects/cgal/CGAL-3.7/examples/Triangulation_3
> > > example
> > Triangulation examples do not need TAUCS. The explanation is somewhere
> > else.
> > *OK, so as just to confirm, neither Triangulation2D/3D nor
No.
TAUCS is used by CGAL only to inverse sparse matrices. Only in the following
examples/demos:
demo/Polyhedron/CMakeLists.txt (only for some plugins)
demo/Surface_reconstruction_points_3/CMakeLists.txt
examples/Point_set_processing_3/CMakeLists.txt
examples/Surface_mesh_parameterization/CMakeLists.txt
examples/Surface_reconstruction_points_3/CMakeLists.txt
and that is all!
Very good to know, cheers!
Laurent Rineau, PhDRelease Manager of the CGAL Project http://www.cgal.org/
http://cgal-discuss.949826.n4.nabble.com/Cannot-run-the-examples-for-using-Delaunay-Triangulation-2-whereas-Delaunay-Triangulation-3-runs-fin-tp3313008p3313353.htmlIf you reply to this email, your message will be added to the discussion below:To unsubscribe from Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., click here.
View this message in context: Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine..
- Re: [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., (continued)
- Re: [cgal-discuss] Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Sebastien Loriot (GeometryFactory), 02/18/2011
- [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., nyiotis, 02/18/2011
- Re: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Sebastien Loriot (GeometryFactory), 02/18/2011
- Re: [cgal-discuss] Re: Cannot run the examples for using Delaunay Triangulation_2, whereas Delaunay Triangulation_3 runs fine.., Laurent Rineau (GeometryFactory), 02/18/2011
