Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement
- To:
- Subject: Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement
- Date: Mon, 7 Mar 2011 19:35:39 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=Qul/lyHEQo7v3fwL2amgsXcPOzhv7hw6A5c/VX8udxTdPPVNDxSdBCOxErPw5SLgxk yWoEsHBTyaeC8Xk5UG1D5DbmlR90jxkZV9BxnZIQYn+e4c1CJSBQqBaijXvVRCDMFz6A HRPsXbnTnpQZkvnJMi252fXHc6WaGwBKw3Txw=
I am sorry, but could you try it one more time for the first test data? I have tried to rebuild the CGAL library, but the assertion violation problem still existed. I have also tried to run it under Windows 7 64bit with VS2008 SP1 and Ubuntu 10.04 64bit, and the problem occurred on both machine.
The assertion information is listed below:
CGAL error: assertion violation!
_expression_ : s_vals.size() == t_vals.size()
File : D:\CGAL-3.7\include\CGAL/Arr_geometry_traits/Bezier_cache.h
Line : 418
Explanation:
Refer to the bug-reporting instructions at http://www.cgal.org/bug_report.html
The attachment is the code and the test data. The necessary solution file and make file for VS2008 and Ubuntu are generated using cgal_create_cmake_script and cmake.
Thanks very much!
Stzpz
2011/3/7 Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com>
stzpz wrote:attaching the file directly should avoid bad formatting.
When I inserting a lot of bezier curves into the bezier arrangement, two
crash problems may occurred. Here is the code for test:
[snip]I ran it ten times without any errors.
(1) Using the above code, with a test_data.txt contains a lot of bezier
curves, the insert() is likely to crash because of assertion violation. It
may sometimes running normally, but it seems that, the more the curves, the
higher probability of being crashed.
Here is the test data:
==================== test_data.txt BEGIN ========================The code in CGAL is able to handle identical curves, but as I already said, for efficiency reason, if you know that you are having such
(2) Using the above code, with a lot of bezier curves of the same control
points, the requiring memory of the code will increasing rapidly and finally
run out of memory. Here is the test data:
degenerate cases in your examples, I suggest to pre-process
your input to remove duplicated curves (a simply sort on the degree and comparison of control points should be sufficient).
S.
[snip]
test.rar
Description: application/rar
- [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, stzpz, 03/06/2011
- Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, Stzpz, 03/06/2011
- Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, Sebastien Loriot (GeometryFactory), 03/07/2011
- Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, Stzpz, 03/07/2011
