Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement
- To:
- Subject: Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement
- Date: Mon, 07 Mar 2011 14:27:34 +0100
It is working fine on my machine. Maybe the patched file I posted was incomplete. Try with the one attached.
S.
Stzpz wrote:
I am sorry, but could you try it one more time for the first test data? I have tried to rebuild the CGAL library, but the assertion violation problem still existed. I have also tried to run it under Windows 7 64bit with VS2008 SP1 and Ubuntu 10.04 64bit, and the problem occurred on both machine.
The assertion information is listed below:
CGAL error: assertion violation!
Expression : s_vals.size() == t_vals.size()
File : D:\CGAL-3.7\include\CGAL/Arr_geometry_traits/Bezier_cache.h
Line : 418
Explanation:
Refer to the bug-reporting instructions at http://www.cgal.org/bug_report.html
The attachment is the code and the test data. The necessary solution file and make file for VS2008 and Ubuntu are generated using cgal_create_cmake_script and cmake.
Thanks very much!
Stzpz
2011/3/7 Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>>
stzpz wrote:
When I inserting a lot of bezier curves into the bezier
arrangement, two
crash problems may occurred. Here is the code for test:
attaching the file directly should avoid bad formatting.
[snip]
(1) Using the above code, with a test_data.txt contains a lot of
bezier
curves, the insert() is likely to crash because of assertion
violation. It
may sometimes running normally, but it seems that, the more the
curves, the
higher probability of being crashed.
I ran it ten times without any errors.
Here is the test data:
==================== test_data.txt BEGIN ========================
(2) Using the above code, with a lot of bezier curves of the
same control
points, the requiring memory of the code will increasing rapidly
and finally
run out of memory. Here is the test data:
The code in CGAL is able to handle identical curves, but as I
already said, for efficiency reason, if you know that you are having
such
degenerate cases in your examples, I suggest to pre-process
your input to remove duplicated curves (a simply sort on the degree
and comparison of control points should be sufficient).
S.
[snip]
-- You are currently subscribed to cgal-discuss.
// Copyright (c) 2006 Tel-Aviv University (Israel). // All rights reserved. // // This file is part of CGAL (www.cgal.org); you may redistribute it under // the terms of the Q Public License version 1.0. // See the file LICENSE.QPL distributed with CGAL. // // Licensees holding a valid commercial license may use this file in // accordance with the commercial license agreement provided with the software. // // This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE // WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. // // $URL: svn+ssh://scm.gforge.inria.fr/svn/cgal/branches/CGAL-3.7-branch/Arrangement_on_surface_2/include/CGAL/Arr_geometry_traits/Bezier_cache.h $ // $Id: Bezier_cache.h 56667 2010-06-09 07:37:13Z sloriot $ // // // Author(s) : Ron Wein <> #ifndef CGAL_BEZIER_CACHE_H #define CGAL_BEZIER_CACHE_H /*! \file * Header file for the _Bezier_cache class. */ #include <set> #include <map> #include <ostream> namespace CGAL { /*! \class _Bezier_cache * Stores all cached intersection points and vertical tangency points. */ template <class Nt_traits_> class _Bezier_cache { public: typedef Nt_traits_ Nt_traits; typedef typename Nt_traits::Integer Integer; typedef typename Nt_traits::Polynomial Polynomial; typedef typename Nt_traits::Algebraic Algebraic; typedef _Bezier_cache<Nt_traits> Self; /// \name Type definitions for the vertical tangency-point mapping. //@{ typedef size_t Curve_id; typedef std::list<Algebraic> Vertical_tangency_list; typedef typename Vertical_tangency_list::const_iterator Vertical_tangency_iter; //@} /// \name Type definitions for the intersection-point mapping. //@{ /*! \struct Intersection_point_2 * Representation of an intersection point (in both parameter and physical * spaces). */ struct Intersection_point_2 { Algebraic s; // The parameter for the first curve. Algebraic t; // The parameter for the second curve. Algebraic x; // The x-coordinate. Algebraic y; // The y-coordinate. /*! Constructor. */ Intersection_point_2 (const Algebraic& _s, const Algebraic& _t, const Algebraic& _x, const Algebraic& _y) : s(_s), t(_t), x(_x), y(_y) {} }; typedef std::pair<Curve_id, Curve_id> Curve_pair; typedef std::pair<Algebraic, Algebraic> Parameter_pair; typedef std::list<Intersection_point_2> Intersection_list; typedef typename Intersection_list::const_iterator Intersection_iter; private: typedef std::map<Curve_id, Vertical_tangency_list> Vert_tang_map; typedef typename Vert_tang_map::value_type Vert_tang_map_entry; typedef typename Vert_tang_map::iterator Vert_tang_map_iterator; /*! \struct Less_curve_pair * An auxiliary functor for comparing pair of curve IDs. */ struct Less_curve_pair { bool operator() (const Curve_pair& cp1, const Curve_pair& cp2) const { // Compare the pairs of IDs lexicographically. return (cp1.first < cp2.first || (cp1.first == cp2.first && cp1.second < cp2.second)); } }; typedef std::list<Algebraic> Parameter_list; typedef std::pair<Intersection_list, bool> Intersection_info; typedef std::map<Curve_pair, Intersection_info, Less_curve_pair> Intersect_map; typedef typename Intersect_map::value_type Intersect_map_entry; typedef typename Intersect_map::iterator Intersect_map_iterator; /*! \struct My_point_2 * Representation of exact and approximate point coordinates. */ struct My_point_2 { typename Parameter_list::const_iterator prm_it; Algebraic x; Algebraic y; double app_x; double app_y; /*! Default constructor. */ My_point_2 () : app_x (0), app_y (0) {} /*! Constructor. */ My_point_2 (typename Parameter_list::const_iterator it, const Algebraic& _x, const Algebraic& _y) : prm_it (it), x (_x), y (_y), app_x (CGAL::to_double(_x)), app_y (CGAL::to_double(_y)) {} /*! Get the parameter value. */ const Algebraic& parameter () const { return (*prm_it); } /*! Check if the given two points are equal. */ bool equals (const My_point_2& other) const { return (CGAL::compare (x, other.x) == EQUAL && CGAL::compare (y, other.y) == EQUAL); } }; /*! \struct Less_distance_iter * An auxiliary functor for comparing approximate distances. */ typedef std::list<My_point_2> Point_list; typedef typename Point_list::iterator Point_iter; typedef std::pair<double, Point_iter> Distance_iter; struct Less_distance_iter { bool operator() (const Distance_iter& dit1, const Distance_iter& dit2) const { return (dit1.first < dit2.first); } }; // Data members: Nt_traits nt_traits; /*! Number-type traits. */ Vert_tang_map vert_tang_map; /*! Maps curves to their vertical tangency parameters. */ Intersect_map intersect_map; /*! Maps curve pairs to their intersection parameter pairs. */ // Copy constructor and assignment operator - not supported. _Bezier_cache (const Self& ); Self& operator= (const Self& ); public: /*! Constructor. */ _Bezier_cache () {} /*! * Get the vertical tangency parameters of a given curve (X(t), Y(t)). * \param id The curve ID. * \param polyX The coefficients of X(t). * \param normX The normalizing factor of X(t). * \return A list of parameters 0 < t_1 < ...< t_k < 1 such that X'(t_i) = 0. */ const Vertical_tangency_list& get_vertical_tangencies (const Curve_id& id, const Polynomial& polyX, const Integer& normX); /*! * Get the intersection parameters of two given curve (X_1(s), Y_1(s)) * and (X_2(t), Y_2(t)). * \param id1 The ID of the first curve. * \param polyX_1 The coefficients of X_1. * \param normX_1 The normalizing factor of X_1. * \param polyY_1 The coefficients of Y_1. * \param normY_1 The normalizing factor of Y_1. * \param id2 The ID of the second curve. * \param polyX_2 The coefficients of X_2. * \param normX_2 The normalizing factor of X_2. * \param polyY_2 The coefficients of Y_2. * \param normY_2 The normalizing factor of Y_2. * \param do_ovlp Output: Do the two curves overlap. * \pre id1 < id2 (swap their order if this is not the case). * \return A list of parameter pairs (s_1, t_1), ..., (s_k, t_k) such that * X_1(s_i) = X_2(t_i) and Y_1(s_i) = Y_2(t_i). * Each pair is also associated with the physical point coordinates. */ const Intersection_list& get_intersections (const Curve_id& id1, const Polynomial& polyX_1, const Integer& normX_1, const Polynomial& polyY_1, const Integer& normY_1, const Curve_id& id2, const Polynomial& polyX_2, const Integer& normX_2, const Polynomial& polyY_2, const Integer& normY_2, bool& do_ovlp); /*! * Mark two curves as overlapping. * \param id1 The ID of the first curve. * \param id2 The ID of the second curve. */ void mark_as_overlapping (const Curve_id& id1, const Curve_id& id2); private: /*! * Compute all s-parameter values such that the curve (X_1(s), Y_1(s)) * intersects with (X_2(t), Y_2(t)) for some t. * \param polyX_1 The coefficients of X_1. * \param normX_1 The normalizing factor of X_1. * \param polyY_1 The coefficients of Y_1. * \param normY_1 The normalizing factor of Y_1. * \param polyX_2 The coefficients of X_2. * \param normX_2 The normalizing factor of X_2. * \param polyY_2 The coefficients of Y_2. * \param normY_2 The normalizing factor of Y_2. * \param s_vals Output: A list of s-values such that (X_1(s), Y_1(s)) * is an intersection point with (X_2(t), Y_2(t)). * The list is given in ascending order. * Note that the values are not bounded to [0,1]. * \return Do the two curves overlap (if they do, s_vals is empty). */ bool _intersection_params (const Polynomial& polyX_1, const Integer& normX_1, const Polynomial& polyY_1, const Integer& normY_1, const Polynomial& polyX_2, const Integer& normX_2, const Polynomial& polyY_2, const Integer& normY_2, Parameter_list& s_vals) const; /*! * Compute all s-parameter values of the self intersection of (X(s), Y(s)) * with (X(t), Y(t)) for some t. * \param polyX The coefficients of X. * \param polyY The coefficients of Y. * \param s_vals Output: A list of s-values of the self-intersection points. * Note that the values are not bounded to [0,1]. */ void _self_intersection_params (const Polynomial& polyX, const Polynomial& polyY, Parameter_list& s_vals) const; /*! * Compute the resultant of two bivariate polynomials in x and y with * respect to y. The bivariate polynomials are given as vectors of * polynomials, where bp1[i] is a coefficient of y^i, which is in turn a * polynomial in x. * \param bp1 The first bivariate polynomial. * \param bp2 The second bivariate polynomial. * \return The resultant polynomial (a polynomial in x). */ Polynomial _compute_resultant (const std::vector<Polynomial>& bp1, const std::vector<Polynomial>& bp2) const; }; // --------------------------------------------------------------------------- // Get the vertical tangency parameters of a given curve (X(t), Y(t)). // template<class NtTraits> const typename _Bezier_cache<NtTraits>::Vertical_tangency_list& _Bezier_cache<NtTraits>::get_vertical_tangencies (const Curve_id& id, const Polynomial& polyX, const Integer& /* normX */) { // Try to find the curve ID in the map. Vert_tang_map_iterator map_iter = vert_tang_map.find (id); if (map_iter != vert_tang_map.end()) { // Found in the map: return the cached parameters' list. return (map_iter->second); } // We need to compute the vertical tangency parameters: find all t-values // such that X'(t) = 0, and store them in the cache. Vertical_tangency_list& vert_tang_list = vert_tang_map[id]; const Polynomial& polyX_der = nt_traits.derive (polyX); nt_traits.compute_polynomial_roots (polyX_der, 0, 1, std::back_inserter(vert_tang_list)); return (vert_tang_list); } // --------------------------------------------------------------------------- // Get the intersection parameters of two given curve (X_1(s), Y_1(s)) // and (X_2(t), Y_2(t)). // template<class NtTraits> const typename _Bezier_cache<NtTraits>::Intersection_list& _Bezier_cache<NtTraits>::get_intersections (const Curve_id& id1, const Polynomial& polyX_1, const Integer& normX_1, const Polynomial& polyY_1, const Integer& normY_1, const Curve_id& id2, const Polynomial& polyX_2, const Integer& normX_2, const Polynomial& polyY_2, const Integer& normY_2, bool& do_ovlp) { CGAL_precondition (id1 <= id2); // Construct the pair of curve IDs, and try to find it in the map. Curve_pair curve_pair (id1, id2); Intersect_map_iterator map_iter = intersect_map.find (curve_pair); if (map_iter != intersect_map.end()) { // Found in the map: return the cached information. do_ovlp = map_iter->second.second; return (map_iter->second.first); } // We need to compute the intersection-parameter pairs. Intersection_info& info = intersect_map[curve_pair]; // Check if we have to compute a self intersection (a special case), // or a regular intersection between two curves. if (id1 == id2) { // Compute all parameter values that lead to a self intersection. Parameter_list s_vals; _self_intersection_params (polyX_1, polyY_1, s_vals); // Match pairs of parameter values that correspond to the same point. // Note that we make sure that both parameter pairs are in the range [0, 1] // (if not, the self-intersection point is imaginary). typename Parameter_list::iterator s_it; typename Parameter_list::iterator t_it; const Algebraic one (1); const Algebraic& denX = nt_traits.convert (normX_1); const Algebraic& denY = nt_traits.convert (normY_1); Point_list pts1; for (s_it = s_vals.begin(); s_it != s_vals.end(); ++s_it) { if (CGAL::sign (*s_it) == NEGATIVE) continue; if (CGAL::compare (*s_it, one) == LARGER) break; const Algebraic& x = nt_traits.evaluate_at (polyX_1, *s_it); const Algebraic& y = nt_traits.evaluate_at (polyY_1, *s_it); for (t_it = s_it; t_it != s_vals.end(); ++t_it) { if (CGAL::compare (*t_it, one) == LARGER) break; if (CGAL::compare (nt_traits.evaluate_at (polyX_1, *t_it), x) == EQUAL && CGAL::compare (nt_traits.evaluate_at (polyY_1, *t_it), y) == EQUAL) { info.first.push_back (Intersection_point_2 (*s_it, *t_it, x / denX, y / denY)); } } } info.second = false; return (info.first); } // Compute s-values and t-values such that (X_1(s), Y_1(s)) and // (X_2(t), Y_2(t)) are the intersection points. Parameter_list s_vals; do_ovlp = _intersection_params (polyX_1, normX_1, polyY_1, normY_1, polyX_2, normX_2, polyY_2, normY_2, s_vals); if (do_ovlp) { // Update the cache and return an empty list of intersection parameters. info.second = true; return (info.first); } Parameter_list t_vals; do_ovlp = _intersection_params (polyX_2, normX_2, polyY_2, normY_2, polyX_1, normX_1, polyY_1, normY_1, t_vals); CGAL_assertion (! do_ovlp); // s-values and t-values reported lie in the range [0,1]. We have // to pair them together. Note that the numbers of s-values and t-values //can be different as a s-value in [0,1] may correspond to a t-values //outside this range. To make the pairing correct, we choose the one with //less values and look amongst other values the correct one (thus the swapt below). // Compute all points on (X_1, Y_1) that match an s-value from the list. typename Parameter_list::iterator s_it; const Algebraic& denX_1 = nt_traits.convert (normX_1); const Algebraic& denY_1 = nt_traits.convert (normY_1); Point_list pts1; for (s_it = s_vals.begin(); s_it != s_vals.end(); ++s_it) { const Algebraic& x = nt_traits.evaluate_at (polyX_1, *s_it) / denX_1; const Algebraic& y = nt_traits.evaluate_at (polyY_1, *s_it) / denY_1; pts1.push_back (My_point_2 (s_it, x, y)); } // Compute all points on (X_2, Y_2) that match a t-value from the list. typename Parameter_list::iterator t_it; const Algebraic& denX_2 = nt_traits.convert (normX_2); const Algebraic& denY_2 = nt_traits.convert (normY_2); Point_list pts2; for (t_it = t_vals.begin(); t_it != t_vals.end(); ++t_it) { const Algebraic& x = nt_traits.evaluate_at (polyX_2, *t_it) / denX_2; const Algebraic& y = nt_traits.evaluate_at (polyY_2, *t_it) / denY_2; pts2.push_back (My_point_2 (t_it, x, y)); } // Go over the points in the pts1 list. const bool x2_simpler = nt_traits.degree(polyX_2) < nt_traits.degree(polyX_1); const bool y2_simpler = nt_traits.degree(polyY_2) < nt_traits.degree(polyY_1); Point_iter pit1; Point_iter pit2; double dx, dy; Algebraic s, t; const Algebraic one (1); unsigned int k; //pointers are used to set the list pts1_ptr as the one with the less values Point_list* pts1_ptr=&pts1; Point_list* pts2_ptr=&pts2; bool swapt=pts1.size() > pts2.size(); if (swapt) std::swap(pts1_ptr,pts2_ptr); for (pit1 = pts1_ptr->begin(); pit1 != pts1_ptr->end(); ++pit1) { // Construct a vector of distances from the current point to all other // points in the pts2 list. const int n_pts2 = pts2_ptr->size(); std::vector<Distance_iter> dist_vec (n_pts2); for (k = 0, pit2 = pts2_ptr->begin(); pit2 != pts2_ptr->end(); k++, ++pit2) { // Compute the approximate distance between the teo current points. dx = pit1->app_x - pit2->app_x; dy = pit1->app_y - pit2->app_y; dist_vec[k] = Distance_iter (dx*dx + dy*dy, pit2); } // Sort the vector according to the distances from *pit1. std::sort (dist_vec.begin(), dist_vec.end(), Less_distance_iter()); // Go over the vector entries, starting from the most distant from *pit1 // to the closest and eliminate pairs of points (we expect that // eliminating the distant points is done easily). We stop when we find // a pait for *pit1 or when we are left with a single point. bool found = false; const Algebraic& s = pit1->parameter(); Algebraic t; for (k = n_pts2 - 1; !found && k > 0; k--) { pit2 = dist_vec[k].second; if (pit1->equals (*pit2)) { // Obtain the parameter value, and try to simplify the representation // of the intersection point. t = pit2->parameter(); if (x2_simpler) pit1->x = pit2->x; if (y2_simpler) pit1->y = pit2->y; // Remove this point from pts2, as we found a match for it. pts2_ptr->erase (pit2); found = true; } } if (! found) { // We are left with a single point - pair it with *pit1. pit2 = dist_vec[0].second; // Obtain the parameter value, and try to simplify the representation // of the intersection point. t = pit2->parameter(); if (x2_simpler) pit1->x = pit2->x; if (y2_simpler) pit1->y = pit2->y; // Remove this point from pts2, as we found a match for it. pts2_ptr->erase (pit2); } // Check that s- and t-values both lie in the legal range of [0,1]. CGAL_assertion(CGAL::sign (s) != NEGATIVE && CGAL::compare (s, one) != LARGER && CGAL::sign (t) != NEGATIVE && CGAL::compare (t, one) != LARGER); if (!swapt) info.first.push_back (Intersection_point_2 (s, t,pit1->x, pit1->y)); else info.first.push_back (Intersection_point_2 (t, s,pit1->x, pit1->y)); } info.second = false; return (info.first); } // --------------------------------------------------------------------------- // Mark two curves as overlapping. // template<class NtTraits> void _Bezier_cache<NtTraits>::mark_as_overlapping (const Curve_id& id1, const Curve_id& id2) { CGAL_precondition (id1 < id2); // Construct the pair of curve IDs, and try to find it in the map. Curve_pair curve_pair (id1, id2); Intersect_map_iterator map_iter = intersect_map.find (curve_pair); if (map_iter != intersect_map.end()) { // Found in the map: Make sure the curves are marked as overlapping. CGAL_assertion (map_iter->second.second); return; } // Add a new entry and mark the curves as overlapping. Intersection_info& info = intersect_map[curve_pair]; info.second = true; return; } // --------------------------------------------------------------------------- // Compute all s-parameter values of the intersection of (X_1(s), Y_1(s)) // with (X_2(t), Y_2(t)) for some t. // template<class NtTraits> bool _Bezier_cache<NtTraits>::_intersection_params (const Polynomial& polyX_1, const Integer& normX_1, const Polynomial& polyY_1, const Integer& normY_1, const Polynomial& polyX_2, const Integer& normX_2, const Polynomial& polyY_2, const Integer& normY_2, Parameter_list& s_vals) const { // Clear the output parameter list. if (! s_vals.empty()) s_vals.clear(); // We are looking for the s-values s_0 such that (X_1(s_0), Y_1(s_0)) is // an intersection with some point on (X_2(t), Y_2(t)). We therefore have // to solve the system of bivariate polynomials in s and t: // I: X_2(t) - X_1(s) = 0 // II: Y_2(t) - Y_1(s) = 0 // Integer coeff; int k; // Consruct the bivariate polynomial that corresponds to Equation I. // Note that we represent a bivariate polynomial as a vector of univariate // polynomials, whose i'th entry corresponds to the coefficient of t^i, // which is in turn a polynomial it s. const int degX_2 = nt_traits.degree (polyX_2); std::vector<Polynomial> coeffsX_st (degX_2 < 0 ? 1 : (degX_2 + 1)); for (k = degX_2; k >= 0; k--) { coeff = nt_traits.get_coefficient (polyX_2, k) * normX_1; coeffsX_st[k] = nt_traits.construct_polynomial (&coeff, 0); } coeffsX_st[0] = coeffsX_st[0] - nt_traits.scale (polyX_1, normX_2); // Consruct the bivariate polynomial that corresponds to Equation II. const int degY_2 = nt_traits.degree (polyY_2); std::vector<Polynomial> coeffsY_st (degY_2 < 0 ? 1 : (degY_2 + 1)); for (k = degY_2; k >= 0; k--) { coeff = nt_traits.get_coefficient (polyY_2, k) * normY_1; coeffsY_st[k] = nt_traits.construct_polynomial (&coeff, 0); } coeffsY_st[0] = coeffsY_st[0] - nt_traits.scale (polyY_1, normY_2); // Compute the resultant of the two bivariate polynomials and obtain // a polynomial in s. Polynomial res = _compute_resultant (coeffsX_st, coeffsY_st); if (nt_traits.degree (res) < 0) { // If the resultant is identiaclly zero, then the two curves overlap. return (true); } // Compute the roots of the resultant polynomial and mark that the curves do // not overlap. The roots we are interested in must be in the interval [0,1]. nt_traits.compute_polynomial_roots (res,0,1,std::back_inserter (s_vals)); return (false); } // --------------------------------------------------------------------------- // Compute all s-parameter values of the self intersection of (X(s), Y(s)) // with (X(t), Y(t)) for some t. // template<class NtTraits> void _Bezier_cache<NtTraits>::_self_intersection_params (const Polynomial& polyX, const Polynomial& polyY, Parameter_list& s_vals) const { // Clear the output parameter list. if (! s_vals.empty()) s_vals.clear(); // We are looking for the solutions of the following system of bivariate // polynomials in s and t: // I: X(t) - X(s) / (t - s) = 0 // II: Y(t) - Y(s) / (t - s) = 0 // Integer *coeffs; int i, k; // Consruct the bivariate polynomial that corresponds to Equation I. // Note that we represent a bivariate polynomial as a vector of univariate // polynomials, whose i'th entry corresponds to the coefficient of t^i, // which is in turn a polynomial it s. const int degX = nt_traits.degree (polyX); CGAL_assertion(degX > 0); if (degX <= 0) return; //no self intersection if X is constant std::vector<Polynomial> coeffsX_st (degX); coeffs = new Integer [degX]; for (i = 0; i < degX; i++) { for (k = i + 1; k < degX; k++) coeffs[k - i - 1] = nt_traits.get_coefficient (polyX, k); coeffsX_st[i] = nt_traits.construct_polynomial (coeffs, degX - i - 1); } delete[] coeffs; // Consruct the bivariate polynomial that corresponds to Equation II. const int degY = nt_traits.degree (polyY); CGAL_assertion(degY > 0); if (degY <= 0) return; //no self intersection if Y is constant std::vector<Polynomial> coeffsY_st (degY); coeffs = new Integer [degY]; for (i = 0; i < degY; i++) { for (k = i + 1; k < degY; k++) coeffs[k - i - 1] = nt_traits.get_coefficient (polyY, k); coeffsY_st[i] = nt_traits.construct_polynomial (coeffs, degY - i - 1); } delete[] coeffs; // Compute the resultant of the two bivariate polynomials and obtain // a polynomial in s. Polynomial res = _compute_resultant (coeffsX_st, coeffsY_st); if (nt_traits.degree (res) < 0) return; // Compute the roots of the resultant polynomial. nt_traits.compute_polynomial_roots (res, std::back_inserter (s_vals)); return; } // --------------------------------------------------------------------------- // Compute the resultant of two bivariate polynomials. // template<class NtTraits> typename _Bezier_cache<NtTraits>::Polynomial _Bezier_cache<NtTraits>::_compute_resultant (const std::vector<Polynomial>& bp1, const std::vector<Polynomial>& bp2) const { // Create the Sylvester matrix of polynomial coefficients. Also prepare // the exp_fact vector, that represents the normalization factor (see // below). const int m = bp1.size() - 1; const int n = bp2.size() - 1; const int dim = m + n; const Integer zero = 0; const Polynomial zero_poly = nt_traits.construct_polynomial (&zero, 0); int i, j, k; std::vector<std::vector<Polynomial> > mat (dim); std::vector <int> exp_fact (dim); for (i = 0; i < dim; i++) { mat[i].resize (dim); exp_fact[i] = 0; for (j = 0; j < dim; j++) mat[i][j] = zero_poly; } // Initialize it with copies of the two bivariate polynomials. for (i = 0; i < n; i++) for (j = m; j >= 0; j--) mat[i][i + j] = bp1[j]; for (i = 0; i < m; i++) for (j = n; j >= 0; j--) mat[n + i][i + j] = bp2[j]; // Perform Gaussian elimination on the Sylvester matrix. The goal is to // reach an upper-triangular matrix, whose diagonal elements are mat[0][0] // to mat[dim-1][dim-1], such that the determinant of the original matrix // is given by: // // dim-1 // ******* // * * mat[i][i] // * * // i=0 // --------------------------------- // dim-1 // ******* exp_fact[i] // * * (mat[i][i]) // * * // i=0 // bool found_row; Polynomial value; int sign_fact = 1; for (i = 0; i < dim; i++) { // Check if the current diagonal value is a zero polynomial. if (nt_traits.degree (mat[i][i]) < 0) { // If the current diagonal value is a zero polynomial, try to replace // the current i'th row with a row with a higher index k, such that // mat[k][i] is not a zero polynomial. found_row = false; for (k = i + 1; k < dim; k++) { if (nt_traits.degree (mat[k][i]) <= 0) { found_row = true; break; } } if (found_row) { // Swap the i'th and the k'th rows (note that we start from the i'th // column, because the first i entries in every row with index i or // higher should be zero by now). for (j = i; j < dim; j++) { value = mat[i][j]; mat[i][j] = mat[k][j]; mat[k][j] = value; } // Swapping two rows should change the sign of the determinant. // We therefore swap the sign of the normalization factor. sign_fact = -sign_fact; } else { // In case we could not find a non-zero value, the matrix is // singular and its determinant is a zero polynomial. return (mat[i][i]); } } // Zero the whole i'th column of the following rows. for (k = i + 1; k < dim; k++) { if (nt_traits.degree (mat[k][i]) >= 0) { value = mat[k][i]; mat[k][i] = zero_poly; for (j = i + 1; j < dim; j++) { mat[k][j] = mat[k][j] * mat[i][i] - mat[i][j] * value; } // We multiplied the current row by the i'th diagonal entry, thus // multipling the determinant value by it. We therefore increment // the exponent of mat[i][i] in the normalization factor. exp_fact[i] = exp_fact[i] + 1; } } } // Now the determinant is simply the product of all diagonal items, // divided by the normalizing factor. const Integer sgn (sign_fact); Polynomial det_factor = nt_traits.construct_polynomial (&sgn, 0); Polynomial diag_prod = mat[dim - 1][dim - 1]; CGAL_assertion (exp_fact [dim - 1] == 0); for (i = dim - 2; i >= 0; i--) { // Try to avoid unnecessary multiplications by ignoring the current // diagonal item if its exponent in the normalization factor is greater // than 0. if (exp_fact[i] > 0) { exp_fact[i] = exp_fact[i] - 1; } else { diag_prod *= mat[i][i]; } for (j = 0; j < exp_fact[i]; j++) det_factor *= mat[i][i]; } // In case of a trivial normalization factor, just return the product // of diagonal elements. if (nt_traits.degree(det_factor) == 0) return (diag_prod); // Divide the product of diagonal elements by the normalization factor // and obtain the determinant (note that we should have no remainder). Polynomial det, rem; det = nt_traits.divide (diag_prod, det_factor, rem); CGAL_assertion (nt_traits.degree(rem) < 0); return (det); } } //namespace CGAL #endif
- [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, stzpz, 03/06/2011
- Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, Stzpz, 03/06/2011
- Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, Sebastien Loriot (GeometryFactory), 03/07/2011
- Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, Stzpz, 03/07/2011
