Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement
- To:
- Subject: Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement
- Date: Thu, 17 Mar 2011 15:57:49 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=Os07QXCegHNw/vkNA+pU7fYYzlpo5IM33uGz87R2YjdOfE/Qmlj/7x+NOCpBQIuBKK fwq/+nVAt+eNQ3TkqcecAlM1PpRxyH5cjMSloo2hQuw5b+XkO0oLHbwv9BubSyY/89lU aE6U+X3u/6Z6c/UX3cJAOe6dys0HhJQhWC6O0=
I am using CGAL 3.8 beta1 now. It seems that there still have some problems in the insert() function when a lot of curves are inserting into the bezier arrangement.
When I insert the bezier curves to the arrangement one by one, the assertion violation may appear at the time of inserting the 106th curves. I have tried some different data, and it crashed at the same point. The assertion information is:
CGAL error: precondition violation!
_expression_ : p.get_originator (_curve, _xid) != p.originators_end()
File : D:\CGAL-3.8-beta1\include\CGAL/Arr_geometry_traits/Bezier_x_monotone_2.h
Line : 1343
Explanation:
When I insert the bezier curves aggregately, the assertion violation may appear when there contains 107 curves. The assertion information is:
CGAL error: assertion violation!
_expression_ : ! t_vals.empty()
Line : 1597
Explanation:
The attachment contains the code and the test data.
Does anybody knows how to solve it?
Thanks!
Stzpz
2011/3/7 Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com>
It is working fine on my machine. Maybe the patched file I posted was incomplete. Try with the one attached.
S.
Stzpz wrote:
I am sorry, but could you try it one more time for the first test data? I have tried to rebuild the CGAL library, but the assertion violation problem still existed. I have also tried to run it under Windows 7 64bit with VS2008 SP1 and Ubuntu 10.04 64bit, and the problem occurred on both machine.2011/3/7 Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>>
The assertion information is listed below:
_expression_ : s_vals.size() == t_vals.size()
File : D:\CGAL-3.7\include\CGAL/Arr_geometry_traits/Bezier_cache.h
Line : 418
Explanation:
Refer to the bug-reporting instructions at http://www.cgal.org/bug_report.html
The attachment is the code and the test data. The necessary solution file and make file for VS2008 and Ubuntu are generated using cgal_create_cmake_script and cmake.
Thanks very much!
Stzpz
stzpz wrote:
When I inserting a lot of bezier curves into the bezier
arrangement, two
crash problems may occurred. Here is the code for test:
attaching the file directly should avoid bad formatting.
[snip]
(1) Using the above code, with a test_data.txt contains a lot of
bezier
curves, the insert() is likely to crash because of assertion
violation. It
may sometimes running normally, but it seems that, the more the
curves, the
higher probability of being crashed.
I ran it ten times without any errors.
Here is the test data:
==================== test_data.txt BEGIN ========================
(2) Using the above code, with a lot of bezier curves of the
same control
points, the requiring memory of the code will increasing rapidly
and finally
run out of memory. Here is the test data:
The code in CGAL is able to handle identical curves, but as I
already said, for efficiency reason, if you know that you are having
such
degenerate cases in your examples, I suggest to pre-process
your input to remove duplicated curves (a simply sort on the degree
and comparison of control points should be sufficient).
S.
[snip]
-- You are currently subscribed to cgal-discuss.
test_insert.rar
Description: application/rar
- [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, stzpz, 03/06/2011
- Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, Stzpz, 03/06/2011
- Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, Sebastien Loriot (GeometryFactory), 03/07/2011
- Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, Stzpz, 03/07/2011
- Re: [cgal-discuss] Crashed problems of insertion operation in bezier arrangement, Stzpz, 03/17/2011
