- To:
- Subject: Re: [cgal-discuss] Re: point converter between two kernels
- Date: Thu, 10 Mar 2011 08:59:00 +0100
ppmm wrote:
http://cgal-discuss.949826.n4.nabble.com/file/n3344605/mesh_class.cppCartesian_converter is a functor, conversion operations are made using operator().
mesh_class.cpp
File attached.
Thank you.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/point-converter-between-two-kernels-tp3340042p3344605.html
Remove the typedef before Cartesian_converter<Kernel,K> and it is working.
S.
- [cgal-discuss] point converter between two kernels, ppmm, 03/07/2011
- Re: [cgal-discuss] point converter between two kernels, Sebastien Loriot (GeometryFactory), 03/08/2011
- [cgal-discuss] Re: point converter between two kernels, ppmm, 03/09/2011
- Re: [cgal-discuss] Re: point converter between two kernels, Sebastien Loriot (GeometryFactory), 03/09/2011
- Re: [cgal-discuss] Re: point converter between two kernels, Sebastien Loriot (GeometryFactory), 03/10/2011
