[cgal-discuss] Re: the problem when inserted line feature in to Mesh_domain_with_polyline_features_3
- To:
- Subject: [cgal-discuss] Re: the problem when inserted line feature in to Mesh_domain_with_polyline_features_3
- Date: Tue, 22 Mar 2011 08:18:52 -0700 (PDT)
Here is my code about this problem, Is there anybody to help me to test this
code if it can work well on different envoriment?
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/Triangulation_vertex_base_with_info_3.h>
#include <CGAL/Mesh_3/Robust_intersection_traits_3.h>
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Polyhedral_mesh_domain_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/refine_mesh_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
#include <CGAL/Mesh_domain_with_polyline_features_3.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Mesh_3::Robust_intersection_traits_3 Geom_traits;
typedef Geom_traits::Point_3 Point_3;
typedef CGAL::Polyhedron_3 Polyhedron;
typedef CGAL::Mesh_domain_with_polyline_features_3<
CGAL::Polyhedral_mesh_domain_3<Polyhedron, Geom_traits> >
MD_IntersectedLines;
typedef CGAL::Mesh_triangulation_3::type Tr_MDI;
typedef CGAL::Mesh_criteria_3 Mesh_criteria_MDI;
typedef CGAL::Mesh_complex_3_in_triangulation_3 C3t3_MDI;
typedef C3t3_MDI::Facets_in_complex_iterator Facet_Iter_inComplex;
typedef std::vector InterPolyline;
typedef std::list InterPolylines;
using namespace CGAL::parameters;
int main()
Polyhedron bounding_box; //包围盒
//top face
bounding_box.make_triangle(Point_3(100,100,100), Point_3(0,100,100),
Point_3(0,0,100));
bounding_box.make_triangle(Point_3(100,100,100), Point_3(0,0,100),
Point_3(100,0,100));
//bottom face
bounding_box.make_triangle(Point_3(100,100,0), Point_3(100,0,0),
Point_3(0,0,0));
bounding_box.make_triangle(Point_3(100,100,0), Point_3(0,0,0),
Point_3(0,100,0));
//front face
bounding_box.make_triangle(Point_3(0,0,0), Point_3(100,0,100),
Point_3(0,0,100));
bounding_box.make_triangle(Point_3(0,0,0), Point_3(100,0,0),
//back face
bounding_box.make_triangle(Point_3(0,100,0), Point_3(0,100,100),
Point_3(100,100,100));
bounding_box.make_triangle(Point_3(100,100,100), Point_3(100,100,0),
Point_3(0,100,0));
//left face
bounding_box.make_triangle(Point_3(0,0,0), Point_3(0,0,100),
Point_3(0,100,100));
bounding_box.make_triangle(Point_3(0,0,0), Point_3(0,100,100),
Point_3(0,100,0));
//right face
bounding_box.make_triangle(Point_3(100,100,100), Point_3(100,0,0),
Point_3(100,100,0));
bounding_box.make_triangle(Point_3(100,100,100), Point_3(100,0,100),
Point_3(100,0,0));
std::vector<Polyhedron*> AllSurfaces; //所有限定面
Polyhedron NewPoly_1;
NewPoly_1.make_triangle(Point_3(20,20,20), Point_3(25,20,20),
Point_3(25,40,20));
NewPoly_1.make_triangle(Point_3(20,20,20), Point_3(25,40,20),
Point_3(20,40,20));
AllSurfaces.push_back(&NewPoly_1);
Polyhedron NewPoly_2;
NewPoly_2.make_triangle(Point_3(25,40,20), Point_3(25,20,20),
Point_3(60,20,20));
NewPoly_2.make_triangle(Point_3(60,40,20), Point_3(25,40,20),
Point_3(60,20,20));
AllSurfaces.push_back(&NewPoly_2);
InterPolylines interPolySet;
InterPolyline interLine;
interLine.push_back(Point_3(25,40,20));
interLine.push_back(Point_3(25,20,20));
interPolySet.push_back(interLine);
MD_IntersectedLines domain(AllSurfaces.begin(), AllSurfaces.end(),
bounding_box);
domain.add_features(interPolySet.begin(), interPolySet.end());
Mesh_criteria_MDI criteria(facet_angle=20, cell_size=300,
facet_topology =
CGAL::FACET_VERTICES_ON_SURFACE);
C3t3_MDI c3t3 = CGAL::make_mesh_3(domain, criteria);
// Output
std::ofstream medit_file("out_1.mesh");
c3t3.output_to_medit(medit_file);
medit_file.close();
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/the-problem-when-inserted-line-feature-in-to-Mesh-domain-with-polyline-features-3-tp3393653p3396687.html
- [cgal-discuss] the problem when inserted line feature in to Mesh_domain_with_polyline_features_3, xianhai meng, 03/21/2011
- [cgal-discuss] Re: the problem when inserted line feature in to Mesh_domain_with_polyline_features_3, neman, 03/22/2011
- Re: [cgal-discuss] Re: the problem when inserted line feature in to Mesh_domain_with_polyline_features_3, Laurent Rineau (GeometryFactory), 03/23/2011
