- To:
- Subject: [cgal-discuss] Re: Boolean set operation assertion
- Date: Tue, 22 Mar 2011 08:49:52 -0700 (PDT)
As I already said, this does fix the problem for that case, but makes the
rest of my code much too slow. The example given is heavily cut down from my
code to make as minimal example.
My full code includes calculating Delaunay triangulations for two point sets
from which the polygons are extracted, and a number of tests on these
polygons, including some that require boolean set operations.
When using double coordinates, the program runs in 30 seconds, while it
takes roughly a day when using either Quotient or Gmpq. For this reason,
using exact construction is not an option.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Boolean-set-operation-assertion-tp3396262p3396809.html
- [cgal-discuss] Boolean set operation assertion, T.vanLankveld, 03/22/2011
- Re: [cgal-discuss] Boolean set operation assertion, Efraim Fogel, 03/22/2011
- [cgal-discuss] Re: Boolean set operation assertion, T.vanLankveld, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Efraim Fogel, 03/22/2011
- [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Laurent Rineau (GeometryFactory), 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fabio Casado Ruiz, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Fulvio Mastrogiovanni, 03/22/2011
- Re: [cgal-discuss] Probs loading .off file in mesh_3 demo, Andreas Fabri, 03/22/2011
- Re: [cgal-discuss] Re: Boolean set operation assertion, Ben Supnik, 03/28/2011
