Re: [cgal-discuss] Triangulation_3 compiler error C2143: syntax error: missing ';' before ')'
- To:
- Subject: Re: [cgal-discuss] Triangulation_3 compiler error C2143: syntax error: missing ';' before ')'
- Date: Thu, 24 Mar 2011 16:43:54 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=GfrF3y4DHnXfliiaaLXZkXMM6X7VPeVvOUkiEwu0RejaUstSWGJnvfkVR/prz6obiI WSXknR7BQ0cvejXQgmVavttJ91XUpLumExgZNMvMKyPuQgAWc5PsJIxpTl4YmLcmnj9y VO6eU6cZSX62rTGBU2zKeopZvb3cForCSI8+Q=
Please post it as code file, we can't see Triangulation_data_structure_3
template parameters.
S.
On 03/24/2011 04:27 PM, cmodel wrote:
Hi,
I am using Triangulation_3 to do something with Delaunay.
in header file, I defined some typedefs:
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_vertex_base_with_info_3<CGAL::Color,K>
Vb3;
typedef CGAL::Triangulation_data_structure_3 Tds3;
typedef CGAL::Delaunay_triangulation_3<K,Tds3> Delaunay3;
typedef Delaunay3::Point DPoint3;
typedef Delaunay3::Vertex_handle DVertex_handle3;
typedef Delaunay3::Finite_cells_iterator DFinite_cells_iterator3;
and in source file, I used the following:
DFinite_cells_iterator3 dit = DT3.finite_cells_begin();
compiler tells me "error C2143: syntax error: missing ';' before ')'
Anyone has idea?
compiler is MSVC-9.0 SP1. 32bit.
Thanks.
Leon
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangulation-3-compiler-error-C2143-syntax-error-missing-before-tp3402829p3402829.html
- [cgal-discuss] Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', cmodel, 03/24/2011
- Re: [cgal-discuss] Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', Sebastien Loriot (GeometryFactory), 03/24/2011
- [cgal-discuss] Re: Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', cmodel, 03/25/2011
- Re: [cgal-discuss] Re: Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', Sebastien Loriot (GeometryFactory), 03/25/2011
