[cgal-discuss] Re: Triangulation_3 compiler error C2143: syntax error: missing ';' before ')'
- To:
- Subject: [cgal-discuss] Re: Triangulation_3 compiler error C2143: syntax error: missing ';' before ')'
- Date: Thu, 24 Mar 2011 23:49:10 -0700 (PDT)
Sebastien Loriot (GeometryFactory) wrote:
> On 03/25/2011 04:18 AM, cmodel wrote:
> > OH... This issue has been solved by rewrite the loop when iterating
> the
> > Cells_Iterator
> > BUT, now does anyone can help me on another issue,
> > within Finite_cells_iterator, and with Delaunay object,
> > I want to get each vertex(Point), not Vertex_handle, by this
> cells_iterator.
> > How to use cells(by iterator) and with cell object, how to get each
> vertex?
> > I saw t.Point(Cell_hanlde c, int index) and t.Point(Vertext_handle v)
> can do
> > something like this.
> > but how to change cell_iterator to Cell_handle ?
> they are the same.
> Cell_iterator cit=....
> cit->vertex(i)->point() gives you the points for i in [0,3]
> Yes, this work it out. and can also use DT3.point(cit->vertex(i)) for i
> in [0,3].
> Thanks.
> S.
> > Thanks.
> > View this message in context:
> http://cgal-discuss.949826.n4.nabble.com/Triangulation-3-compiler-error-C2143-syntax-error-missing-before-tp3402829p3404359.html
> > Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
http://cgal-discuss.949826.n4.nabble.com/Triangulation-3-compiler-error-C2143-syntax-error-missing-before-tp3402829p3404644.html
- [cgal-discuss] Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', cmodel, 03/24/2011
- Re: [cgal-discuss] Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', Sebastien Loriot (GeometryFactory), 03/24/2011
- [cgal-discuss] Re: Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', cmodel, 03/25/2011
- Re: [cgal-discuss] Re: Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', Sebastien Loriot (GeometryFactory), 03/25/2011
