[cgal-discuss] Re: Triangulation_3 compiler error C2143: syntax error: missing ';' before ')'
- To:
- Subject: [cgal-discuss] Re: Triangulation_3 compiler error C2143: syntax error: missing ';' before ')'
- Date: Thu, 24 Mar 2011 20:18:01 -0700 (PDT)
OH... This issue has been solved by rewrite the loop when iterating the
Cells_Iterator
BUT, now does anyone can help me on another issue,
within Finite_cells_iterator, and with Delaunay object,
I want to get each vertex(Point), not Vertex_handle, by this cells_iterator.
How to use cells(by iterator) and with cell object, how to get each vertex?
I saw t.Point(Cell_hanlde c, int index) and t.Point(Vertext_handle v) can do
something like this.
but how to change cell_iterator to Cell_handle ?
Thanks.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Triangulation-3-compiler-error-C2143-syntax-error-missing-before-tp3402829p3404359.html
- [cgal-discuss] Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', cmodel, 03/24/2011
- Re: [cgal-discuss] Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', Sebastien Loriot (GeometryFactory), 03/24/2011
- [cgal-discuss] Re: Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', cmodel, 03/25/2011
- Re: [cgal-discuss] Re: Triangulation_3 compiler error C2143: syntax error: missing ';' before ')', Sebastien Loriot (GeometryFactory), 03/25/2011
