cgal-discuss - Re: [cgal-discuss] Meshing
  • To:
  • Subject: Re: [cgal-discuss] Meshing
  • Date: Tue, 10 May 2011 12:53:06 +0100
  • Organization: School of Engineering, University of Edinburgh
Hi Laurent,
On Friday 06 May 2011 17:09:46 Laurent Rineau (GeometryFactory) wrote:
> On jeudi 05 mai 2011 19:06:47 Bruce Duncan wrote:
> > Let me know if images or code would help clarify what I'm trying to do.
> Yes, sure! Your message is rather imprecise.
I'm not very good at getting my point across clearly. Please bear with me!
I've attached a NEF file (and a PNG of one view of it) which may help me to
describe what I mean.
> > Hi all,
> > I am writing a mesh generator with quite specific requirements. As a
> > result, I need to output a polyhedron in CGNS format.
> > I can do the CGNS output very easily if I have a set of tetrahedra. In
> > fact I have already implemented this to output a Triangulation_3.
> > At first I tried to use Triangulation_3 and it's siblings directly.
> > However, they don't take into account edges and my concave polyhedra are
> > destroyed in the process of triangulation. Is there a way around this?
> What have you tried exactly? How did you "use Triangulation_3"?
std::vector<Nef_polyhedron::Point_3> points;
for (Nef_polyhedron::Vertex_const_iterator it = N_[x][y][z].vertices_begin();
it != N_[x][y][z].vertices_end(); ++it)
points.push_back(it->point());
Delaunay_triangulation T(points.begin(), points.end());
and then I have a loop over finite cells of the triangulation and vertices of
those cells which outputs the CGNS data.
Obviously, the concave polyhedra are made convex and the resulting mesh is
wrong.
Is there a triangulation class which preserves concavity?
Is there a method to cut a concave 3D polyhedron into multiple 3D convex
polyhedra?
> > Next, I turned to the Mesh_triangulation_3 class. This accepts a
> > Polyhedron and gives access to a Triangulation_3. Excellent! The problem
> > is that it does not respect the vertices and edges of the input
> > Polyhedron. My application really depends on having the vertices remain
> > in the same place. Other vertices and edges may be added, however. Is
> > there a way to achieve this?
> The class Mesh_triangulation_3<Polyhedron>::type in itself is just a
> regular triangulation with speciall vertex and cell types.
> Let's assume you have used the function CGAL::make_mesh_3 or
> CGAL::refine_mesh_3 to construct a 3D mesh from your polyhedron.
> > I have tried to use the Polyhedral_mesh_domain_with_features_3 class but
> > without much success... I may post a test case about that next week.
> The 3D mesh generator, in CGAL, with features or not, will remesh the
> polyhedral domain. If there are features, for examples sharp edges to
> respect, then those features will remeshed. You cannot use the CGAL 3D
> mesh generator in a way to respect the full set of vertices, edges, and
> facets of the input polyhedron.
OK thanks. I think the Mesh generator is unusable for my case.
> If you explain better what you want to achieve, maybe we could suggest you
> other ways to do. What is that mesh generator you want to write? What are
> its requirements?
I am writing a cartesian cut cell grid generator. Given an arbitrary
polyhedron (the "solid"), the generator must produce a grid which is mostly
cartesian (the "fluid" region) with "cut" cells where the solid intersects a
cartesian cell. A cut cell is a tetrahedral 3D mesh with facets which match
those of the adjacent solid or fluid cells, but they don't have to map one-to-
one.
If it might help, and if you have the time, there is a paper describing the
method: Developments in Cartesian cut cell methods, D.M.Ingram, Mathematics
and Computers in Simulation 61 (2003) [1].
Thanks for your help!
Bruce
[1]
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6V0T-460DH92-
B&_user=809099&_coverDate=01%2F30%2F2003&_rdoc=1&_fmt=high&_orig=gateway&_origin=gateway&_sort=d&_docanchor=&view=c&_searchStrId=1746953179&_rerunOrigin=scholar.google&_acct=C000043939&_version=1&_urlVersion=0&_userid=809099&md5=5f20a5f5b14d167766d7b4ad21f23a82&searchtype=a
Attachment: cutcell.png
Description: PNG image
Attachment: cutcell.nef
Description: Binary data
Attachment: signature.asc
Description: This is a digitally signed message part.
The University of Edinburgh is a charitable body, registered in
Scotland, with registration number SC005336.
