- To:
- Subject: Re: [cgal-discuss] ridges strength sharpness computation
- Date: Tue, 10 May 2011 16:37:53 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=L1ECf+IjDhCTn1m5TV7bMwSkhqlh0X7jMvYAlBju2zfLrhhMs6u59684h/bcOtdcSS Udvdbw8Op6l3SMPCE1JIn25lM1+auoYPReub8h9rz5NEEwuL2IMHZifk0eAaHQxJHge5 C1eGsJrCjpfHEDoec9NFDfopnYUj6S6kyKOpk=
hi Marc, I am sorry to bother you again. I read the manual an also your report
"Topology driven algorithms for ridge extraction on Ridges" and I read
"Multiplying the sharpness by the square of the model size gives a
threshold and an associated sharpness-filter which are scale
independent".
What do you mean by model size? I have done some filtering (by using a
threshold of strength | sharpness threshold as sugested in
54.5.3 Example: Filtering of Crest Ridges on a Mechanical Part,
in my objects and was ok. I am doing some reasearch in 3D object
recognition by using differential properties of its surfaces.
If I can use a normalized version sharpness would be nice :-)
Best regards
rlam
- [cgal-discuss] ridges strength sharpness computation, robertolam, 05/06/2011
- Re: [cgal-discuss] ridges strength sharpness computation, Marc Pouget, 05/09/2011
- Re: [cgal-discuss] ridges strength sharpness computation, Roberto Lam, 05/10/2011
- Re: [cgal-discuss] ridges strength sharpness computation, Marc Pouget, 05/10/2011
