- To:
- Subject: Re: [cgal-discuss] ridges strength sharpness computation
- Date: Tue, 10 May 2011 17:51:09 +0200
On May 10, 2011, at 5:37 PM, Roberto Lam wrote:
> hi Marc, I am sorry to bother you again.
you're welcome!
> I read the manual an also your report
> "Topology driven algorithms for ridge extraction on Ridges" and I read
> "Multiplying the sharpness by the square of the model size gives a
> threshold and an associated sharpness-filter which are scale
> independent".
> What do you mean by model size?
the radius of the smallest enclosing ball
> I have done some filtering (by using a
> threshold of strength | sharpness threshold as sugested in
> 54.5.3 Example: Filtering of Crest Ridges on a Mechanical Part,
> in my objects and was ok. I am doing some reasearch in 3D object
> recognition by using differential properties of its surfaces.
> If I can use a normalized version sharpness would be nice :-)
the computed one already takes into account the normalization
MArc
> Best regards
> rlam
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] ridges strength sharpness computation, robertolam, 05/06/2011
- Re: [cgal-discuss] ridges strength sharpness computation, Marc Pouget, 05/09/2011
- Re: [cgal-discuss] ridges strength sharpness computation, Roberto Lam, 05/10/2011
- Re: [cgal-discuss] ridges strength sharpness computation, Marc Pouget, 05/10/2011
