cgal-discuss - Re: [cgal-discuss] Triange/Triangle Intersection
  • To:
  • Subject: Re: [cgal-discuss] Triange/Triangle Intersection
  • Date: Thu, 12 May 2011 21:10:53 +0200
Can you provide a minimal example showing the problem?
(in particular I suspect that typedef are not what you expect)
S.
Bernhard Kornberger wrote:
Am 2011-05-12 15:13, schrieb Sebastien Loriot (GeometryFactory):
This is a documentation bug, the return type can also be Triangle_3.
S.
Thank you, Sebastien. I have adapted my code:
ISTYPE getIntersectionType(const Triangle_3& cgt0,const Triangle_3& cgt1)
cout<<setprecision(20);
cout<<"cgt0="<<cgt0<<endl;
cout<<"cgt1="<<cgt1<<endl;
if(!do_intersect(cgt0,cgt1)) return ISTYPE_NOIS;
vector<Point_3> cg_vPoints;
Point_3 cg_p;
Segment_3 cg_seg;
Triangle_3 cg_t;
ISTYPE cg_ret;
CGAL::Object cg_obj=CGAL::intersection(cgt0,cgt1);
if(CGAL::assign(cg_p,cg_obj))
cg_ret=ISTYPE_PNT;
else if(CGAL::assign(cg_seg,cg_obj))
cg_ret=ISTYPE_SEG;
else if(CGAL::assign(cg_vPoints,cg_obj))
cg_ret=ISTYPE_AREA;
else if(CGAL::assign(cg_t,cg_obj))
cg_ret=ISTYPE_AREA;
...bla...
Now it says:
cgt0=1782.114990234375 -1122.25 353.563323974609375 1782.114990234375 -1122.2501220703125 353.562347412109375 1782.114990234375 -1122.25 353.563201904296875
cgt1=1782.114990234375 -1122.25 353.56378173828125 1782.114990234375 -1122.2496337890625 353.56622314453125 1782.114990234375 -1122.2501220703125 353.56231689453125
object_cast inside Lazy_construction_rep::operator() failed. It needs more else if's (#1)
dynamic type of the Object : St6vectorIN4CGAL7Point_3INS0_16Simple_cartesianINS0_11Interval_ntILb0EEEEEEESaIS6_EE
Unfortunately I do not have more accurate coordinates of the two
triangles.
Best
Bernhard
