- To:
- Subject: Re: [cgal-discuss] Triange/Triangle Intersection
- Date: Thu, 12 May 2011 22:28:23 +0200 (CEST)
On Thu, 12 May 2011, Bernhard Kornberger wrote:
object_cast inside Lazy_construction_rep::operator() failed. It needs more else if's (#1)
dynamic type of the Object : St6vectorIN4CGAL7Point_3INS0_16Simple_cartesianINS0_11Interval_ntILb0EEEEEEESaIS6_EE
Indeed, I can't see anything in Lazy.h to interpret the std::vector<Approximate_kernel::Point_3> returned by the approximate kernel to output a std::vector<Lazy_kernel::Point_3> (both wrapped in an Object). And we had better hope that the order of the points in the vector will be the same with the exact kernel (but then I guess the same applies to segments and triangles and is safe enough as long as they use the same deterministic code).
Marc Glisse
- [cgal-discuss] Triange/Triangle Intersection, Bernhard Kornberger, 05/12/2011
- Re: [cgal-discuss] Triange/Triangle Intersection, Sebastien Loriot (GeometryFactory), 05/12/2011
- Re: [cgal-discuss] Triange/Triangle Intersection, Bernhard Kornberger, 05/12/2011
- Re: [cgal-discuss] Triange/Triangle Intersection, Marc Glisse, 05/12/2011
- Re: [cgal-discuss] Triange/Triangle Intersection, Marc Glisse, 05/13/2011
- Re: [cgal-discuss] Triange/Triangle Intersection, Bernhard Kornberger, 05/13/2011
