- To:
- Subject: Re: [cgal-discuss] Voronoi diagrams
- Date: Tue, 17 May 2011 17:00:23 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=umXSFzMPYcdGnz2OPg2DyDxegDOqW9BY3pUy4OSp0InjMpgsJEOU129kWx3RionAh4 HJnSvg3CwoReJhEfi9n1MLQPS5YGKaBoY3QpR1NbPnsU/zZLYLnbRaguntj/DEzSe/PO qlC9Ewq6go+QhVJWI5Yf/5iE3C6QZjJoUdKVs=
Hi,
Thanks. I found it. I have to useVisual C++ 2010 with CGAL library.
I have not worked with C++. But i have worked with Visual C#. I
have downloaded CGAL-3.8-Setu.exe and CMAKE 2.8.4 both.
After installing these two, could you please let me know
how to use the code given in that example for Voronoi
Diagram creation in Visual C++ Windows application?
Do i need to add CGAL namespace. Please give me a start.
regards Brian.
On Tue, May 17, 2011 at 4:48 PM, Daniel Duque <> wrote:
On Tuesday 17 May 2011 17:36:35 Brian Sanjeewa Rupasinghe wrote:http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Subsection_35.5.3
> Hi,
> Thanks for the quick reply. I just started using CGAL library. Where can i
> find it? is it in the CGAL tutorial documents?
Best,
Daniel
http://dcain.etsin.upm.es/~daniel
- [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Marc Glisse, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Daniel Duque, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Andreas Fabri, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Karstein Sørli, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/18/2011
