- To:
- Subject: Re: [cgal-discuss] Voronoi diagrams
- Date: Wed, 18 May 2011 16:25:24 +0200
Brian Sanjeewa Rupasinghe wrote:
Hi,See
Thanks. I tried installing the demo you sent. When i tried to setup it, it gives an error message "QtGui4.dll is missing"
http://www.cgal.org/Manual/latest/doc_html/installation_manual/Chapter_installation_manual.html#Subsection_4.11
S.
Brian.
On Wed, May 18, 2011 at 2:45 PM, Sebastien Loriot (GeometryFactory) <sloriot.ml <http://sloriot.ml>@gmail.com <http://gmail.com>> wrote:
Hi,
In order to install CGAL, I downloaded CGAL setup.exe and CMAKE.exe.
First i installed CGAL and then the CMAKE GUI. Then in order to
configure CGAL, I started the CMAKE and click on configure and
select the generator as Visual 10 (i have visual C++ 2010). In
CMAKE, What specific files i have to chose on 'Browse Source"
and 'Browse Build" before click on Configuration?
Please help.
Brian.
I guess you need to select the CMakeLists.txt in at the root of the CGAL
directory.
Did you tried the pre-compiled demo as I suggested:
http://www.cgal.org/demo/3.8/delaunay_triangulation_2.zip
S.
On Tue, May 17, 2011 at 4:26 PM, Sebastien Loriot
Hi,
Suppose i have a list of ten points in a text file.
I want to create a voronoi diagram of these
points. How van i do it? I am new to CGAL
and please help. I use MS Visual C++ for
programming. I can read the point coordinates
from the file.
Brian.
You can use the Delaunay_triangulation_2 demo.
Sources in the CGAL tarball are here
CGAL-3.8/demo/Triangulation_2.
In addition, on windows a precompiled demo is available here:
The format for input points is
x1 y1
x2 y2
x3 y3
xn yn
S.
-- You are currently subscribed to cgal-discuss.
- Re: [cgal-discuss] Voronoi diagrams, (continued)
- Re: [cgal-discuss] Voronoi diagrams, Marc Glisse, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Daniel Duque, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Andreas Fabri, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Karstein Sørli, 05/17/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Andreas Fabri, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/20/2011
