- To:
- Subject: [cgal-discuss] Compiling C++ without CMAKE with CGAL
- Date: Fri, 20 May 2011 22:18:42 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=Keb03DNklAR26fbcafHi/wdyedonJnLBs2JIE+2eIh7N3jjF5om+N+KZ63snKpBYgb 6yPaBWdDxWZDQDpiNGh2zWi1sPHQL3tRG36nQfmfMuz50UJBtd7eXW9BMcTGbfc68oYu 2Ptey3D5yeWcrhZmQUMfdGzxK/G8f8IqFlyg4=
Hello,
I created the CGAL library for Visual c++ 2008. Now i need to create a new program for Voronoi without CMAKE.
This is the .CPP file of my application.
#include "stdafx.h"
#include <CGAL/Delaunay_triangulation_2.h>
#include <fstream>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Delaunay_triangulation_2<K> Triangulation;
typedef Triangulation::Edge_iterator Edge_iterator;
typedef Triangulation::Point Point;
int _tmain()
std::ifstream in("data/voronoi.cin");
std::istream_iterator<Point> begin(in);
std::istream_iterator<Point> end;
Triangulation T;
T.insert(begin, end);
int ns = 0;
int nr = 0;
Edge_iterator eit =T.edges_begin();
for ( ; eit !=T.edges_end(); ++eit) {
CGAL::Object o = T.dual(eit);
if (CGAL::object_cast<K::Segment_2>(&o)) {++ns;}
else if (CGAL::object_cast<K::Ray_2>(&o)) {++nr;}
std::cout << "The Voronoi diagram has " << ns << " finite edges "
<< " and " << nr << " rays" << std::endl;
return 0;
I followed the procedure given below after creating a new project. However, when the project is compiled it gives an
error: "fatal error LNK1104: cannot open file 'libgmp-10.lib;libmpfr-4.lib'. Any solution for this?
Brian.
Customizing env - If you are not using CMake to create new VS projects
- Go to Tools -> Options -> Projects and Solutions -> VC++ Directories. Add the following to "Include files" (include) and "Library files" (library) [under "show directories for"].
* include: <Boost> (C:\Program Files\boost\boost_1_44)
* include: <CGAL>\include (C:\Program Files\CGAL-3.7\include)
* include: <CGAL>\auxiliary\gmp\include (C:\Program Files\CGAL-3.7\auxiliary\gmp\include)
* include: <QT>\include (C:\Qt\4.7.1\include)
* include: <QT>\include\QtCore (C:\Qt\4.7.1\include\QtCore)
* include: <QT>\include\QtGui (C:\Qt\4.7.1\include\QtGui)
* library: <CGAL>\lib (C:\Program Files\CGAL-3.7\lib)
* library: <QT>\lib (C:\Qt\4.7.1\lib)
* library: <Boost>\lib (C:\Program Files\boost\boost_1_44\lib)
* library: <CGAL>\auxiliary\gmp\lib (C:\Program Files\CGAL-3.7\auxiliary\gmp\lib)
For a specific project using CGAL you need to ignore the auto-link of gmp and mpfr. The names below are for Debug. In Release their names are a bit different.
- Project Propeties -> Linker -> Input
* Add libgmp-10.lib and libmpfr-4.lib to "Additional Dependencies"
* Add gmp-vc90-mt-gd.lib and mpfr-vc90-mt-gd.lib to "Ignore Specific Library".
- [cgal-discuss] Compiling C++ without CMAKE with CGAL, Brian Sanjeewa Rupasinghe, 05/20/2011
