cgal-discuss - Re: [cgal-discuss] Voronoi diagrams
  • To:
  • Subject: Re: [cgal-discuss] Voronoi diagrams
  • Date: Fri, 20 May 2011 17:28:59 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=rTq9npAV8swNwvq7NQ0wSaFB1q4q1OEmplE045hmNl+WefvTkdZ+mpU80HknE4gs4b D+ZmEl78/rOpDBde/AoRof0pxXiwQOAZubcjMo6SpK3pWbW2v2bMrrN6xtohxnZQR17/ ZtXPTxpTLfyHXwefUappZnZceW40oXUY2uz48=
Sir,
Ok. Thanks. I got it. I highly appreciate your guidance.
Brian.
On Fri, May 20, 2011 at 5:10 PM, Brian Sanjeewa Rupasinghe <> wrote:
Sir,
Extremely sorry if i troubled you. After configuring CGAL with
CMAKE, I generated the Projects. This error occured when
i tried to build one of the projects; actually Triangulation_2
project.
Thanks again.
Brian.
On Fri, May 20, 2011 at 5:03 PM, Laurent Rineau (GeometryFactory) <> wrote:
On vendredi 20 mai 2011 17:54:13 Sebastien Loriot (GeometryFactory) wrote:
> Andreas already told you to check that when you configured the lib CGAL
> with cmake, you then need to compile it (which will generate the file
> you are missing).
To compile it *twice*: once in Release mode, and once in Debug mode (that is
an option of the Visual Studio GUI).
> Also please stop sending reminders, this thread is already long enough.
I agree.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
