- To:
- Subject: [cgal-discuss] problem of shaders in poisson reconstruction demo
- Date: Sat, 21 May 2011 00:57:03 -0700 (PDT)
Hi,
I am trying the Surface_reconstruction_point_3 demo. All compiling and
linking process are Ok. But when running the executable file, errors occur.
The console messages like these:
### Loading "libPS_demo_average_spacing_plugin.so"...
### Loading "libPS_demo_cleaning_plugin.so"...
### Loading "libPS_demo_inside_out_plugin.so"...
### Loading "libPS_demo_local_spacing_plugin.so"...
### Loading "libPS_demo_normal_estimation_plugin.so"...
### Loading "libPS_demo_off_plugin.so"...
### Loading "libPS_demo_poisson_plugin.so"...
### Loading "libPS_demo_simplification_plugin.so"...
### Loading "libPS_demo_smoothing_plugin.so"...
### Loading "libPS_demo_xyz_plugin.so"...
SplatRenderer: warning floating point textures are not supported.
Succesfully loaded shader func 'VisibilityVP' in file 'Raycasting.glsl'
Succesfully loaded shader func 'VisibilityFP' in file 'Raycasting.glsl'
Succesfully loaded shader func 'AttributeVP' in file 'Raycasting.glsl'
Succesfully loaded shader func 'AttributeFP' in file 'Raycasting.glsl'
Succesfully loaded shader func 'Finalization' in file 'Finalization.glsl'
Shader info :
linking with uncompiled shaderlinking with uncompiled shader
Shader info :
Shader info :
Point_set_demo:
/home/hushell/Downloads/CGAL-3.8/demo/Surface_reconstruction_points_3/GlSplat/Shader.cpp:92:
void GlSplat::Shader::activate() const: Assertion `mIsValid' failed.
Aborted
I am using Ubuntu 10.04 with 32bits CPU. I have followed the suggestion in:
http://cgal-discuss.949826.n4.nabble.com/Re-Error-by-compiling-poisson-reconstruction-example-td2268101i20.html
, in which Laurent said comment the line findpackage(GLEW) in CMakeList.txt
to disable the GlSplat rendering. Although no errors show up, but loaded
data is invisible. So I guess GLEW is necessary in my case. but how can I
address the shader problem?
Thanks a lot.
-Shelling
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/problem-of-shaders-in-poisson-reconstruction-demo-tp3540279p3540279.html
- [cgal-discuss] problem of shaders in poisson reconstruction demo, shelling343, 05/21/2011
