- To:
- Subject: Re: [cgal-discuss] Voronoi diagrams
- Date: Sun, 22 May 2011 13:33:32 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=SO2E/B7FQGkWjnKS3242xVGMSnOOZ5aiQrnDLeR64R4VAu5q97QUtFdSVKDrWS1AB/ FPFC4srbtRlNgjFQcEsQOVHLJdu2cAjzb97BELR9O8Rh9AlgSK77cGsqzmbrr/g/ysaD dvs46Uni9K6bF5Iy0xh3yKeqG91YC8RpyucqQ=
Dear Sir,
This is the code i have used to create Delaunay triangulation and then to print
number of vertices and faces. Now i need to retrieve coordinates of each vertex
using an index. Please let me know how it can be done? I followed up tutorial in following link.
But could not get how to do it.
#include <CGAL/Projection_traits_xy_3.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <fstream>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Projection_traits_xy_3<K> Gt;
typedef CGAL::Delaunay_triangulation_2<Gt> Delaunay;
typedef K::Point_3 Point;
int _tmain()
//std::ifstream in("data/terrain.cin");
std::ifstream in("data/test.cin");
std::istream_iterator<Point> begin(in);
std::istream_iterator<Point> end;
Delaunay dt;
dt.insert(begin, end);
std::cout << dt.number_of_vertices() << std::endl;
std::cout << dt.number_of_faces() << std::endl;
std::cout << dt;
return 0;
Brian.
On Tue, May 17, 2011 at 4:26 PM, Sebastien Loriot (GeometryFactory) <sloriot.ml@gmail.com> wrote:
You can use the Delaunay_triangulation_2 demo.Brian Sanjeewa Rupasinghe wrote:
Hi,
Suppose i have a list of ten points in a text file.
I want to create a voronoi diagram of these
points. How van i do it? I am new to CGAL
and please help. I use MS Visual C++ for
programming. I can read the point coordinates
from the file.
Brian.
Sources in the CGAL tarball are here CGAL-3.8/demo/Triangulation_2.
In addition, on windows a precompiled demo is available here:
http://www.cgal.org/demo/3.8/delaunay_triangulation_2.zip
The format for input points is
x1 y1
x2 y2
x3 y3
xn yn
S.
- Re: [cgal-discuss] Voronoi diagrams, (continued)
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Laurent Rineau (GeometryFactory), 05/20/2011
- Re: [cgal-discuss] Voronoi diagrams, Brian Sanjeewa Rupasinghe, 05/18/2011
- Re: [cgal-discuss] Voronoi diagrams, Sebastien Loriot (GeometryFactory), 05/18/2011
