Re: [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll
- To:
- Subject: Re: [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll
- Date: Tue, 7 Jun 2011 09:50:03 +0200
Le lundi 06 juin 2011 22:50:55, Liang a écrit :
> Hi everyone,
> I tried to run Surface_reconstruction_points_3 demo from within Visual
> Studio 2008 when I encountered this error: "The procedure entry point
> _Z5qFreePv could not be located in the dynamic link library QtCore4.dll"
> under both debug and release mode.
Check your PATH. The version of Qt you used to compile and link your
application is not the same as the version that was found dynamically during
the execution of your application.
Laurent Rineau, PhD
- [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Liang, 06/06/2011
- Re: [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Laurent Saboret, 06/07/2011
- Re: [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Laurent Rineau (GeometryFactory), 06/07/2011
- [cgal-discuss] Re: The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Liang, 06/07/2011
- Re: [cgal-discuss] Re: The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Laurent Rineau (GeometryFactory), 06/08/2011
