[cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll
- To:
- Subject: [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll
- Date: Mon, 6 Jun 2011 13:50:55 -0700 (PDT)
Hi everyone,
I tried to run Surface_reconstruction_points_3 demo from within Visual
Studio 2008 when I encountered this error: "The procedure entry point
_Z5qFreePv could not be located in the dynamic link library QtCore4.dll"
under both debug and release mode.
For some reason, I have to run this demo from its source code. Although the
CGAL precompiled surface_reconstruction_points_3 demo with the "all demo
dlls" in the same directory works fine, this problem still need to be
resolved.
I have tried reinstalled Qt and rebuilt CGAL, and this error remained.
Really appreciate any help here.
Best regards,
Liang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/The-procedure-entry-point-Z5qFreePv-could-not-be-located-in-the-dynamic-link-library-QtCore4-dll-tp3578019p3578019.html
- [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Liang, 06/06/2011
- Re: [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Laurent Saboret, 06/07/2011
- Re: [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Laurent Rineau (GeometryFactory), 06/07/2011
- [cgal-discuss] Re: The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Liang, 06/07/2011
- Re: [cgal-discuss] Re: The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Laurent Rineau (GeometryFactory), 06/08/2011
