[cgal-discuss] Re: The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll
- To:
- Subject: [cgal-discuss] Re: The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll
- Date: Tue, 7 Jun 2011 12:30:33 -0700 (PDT)
Thank you, Laurent.
I have checked the Runtime Library, they were set right.
Now the dll problem has been solved, but I can only run from Release mode.
When I change to debug, the command line window displays "QWidget: Must
construct a QApplication before a QPaintDevice". I have no idea what that
means.
Best wishes,
Liang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/The-procedure-entry-point-Z5qFreePv-could-not-be-located-in-the-dynamic-link-library-QtCore4-dll-tp3578019p3580561.html
- [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Liang, 06/06/2011
- Re: [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Laurent Saboret, 06/07/2011
- [cgal-discuss] Re: The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Liang, 06/07/2011
- Re: [cgal-discuss] The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Laurent Rineau (GeometryFactory), 06/07/2011
- Re: [cgal-discuss] Re: The procedure entry point _Z5qFreePv could not be located in the dynamic link library QtCore4.dll, Laurent Rineau (GeometryFactory), 06/08/2011
