- To:
- Subject: [cgal-discuss] generating a point-cloud with prescribed density
- Date: Wed, 8 Jun 2011 12:53:09 -0400
Dear CGAL developers,
I am interested in producing a tetrahedralization that is faithful to the input boundary and that adheres to a prescribed density function. I have looked into the meshing available with CGAL, but so far the density function must be constant and moreover, the final tetrahedralization does not conform to the input PLC. I would consider another approach, where I generate Steiner points which I can then input to something like Tetgen, where the Steiner points are inserted in a manner that respects the prescribed density function (which in turn is computed based on distance from a specific subvolume of the anatomy).
Does CGAL have anything for producing such a cloud of Steiner points? If not, can anyone suggest software that does this?
Thanks for your kind support.
Best wishes,
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
- [cgal-discuss] generating a point-cloud with prescribed density, Michel Audette, 06/08/2011
- Re: [cgal-discuss] generating a point-cloud with prescribed density, Laurent Rineau (GeometryFactory), 06/09/2011
- Re: [cgal-discuss] generating a point-cloud with prescribed density, Michel Audette, 06/09/2011
