- To:
- Subject: Re: [cgal-discuss] generating a point-cloud with prescribed density
- Date: Thu, 9 Jun 2011 11:40:17 +0200
On mercredi 08 juin 2011 18:53:09 Michel Audette wrote:
> Dear CGAL developers,
> I am interested in producing a tetrahedralization that is faithful to the
> input boundary and that adheres to a prescribed density function. I have
> looked into the meshing available with CGAL, but so far the density
> function must be constant and moreover, the final tetrahedralization does
> not conform to the input PLC.
What do you mean by "conform to the input PLC"? The tetrahedral mesh
generator
in CGAL can remesh a polyhedron and respect its sharp edges (that is new in
CGAL-3.8).
As for the density, you can create a special model of the concept
MeshCriteria_3. For a client of GeometryFactory, I have writen such a
criteria
class that reads the sizing field from a 3D scalar image, and ensure that for
each tetrahedron in the meshing domain, its size is smaller than the value in
the image at the center of the tetrahedron.
Laurent Rineau, PhD
- [cgal-discuss] generating a point-cloud with prescribed density, Michel Audette, 06/08/2011
- Re: [cgal-discuss] generating a point-cloud with prescribed density, Laurent Rineau (GeometryFactory), 06/09/2011
- Re: [cgal-discuss] generating a point-cloud with prescribed density, Michel Audette, 06/09/2011
