cgal-discuss - Re: [cgal-discuss] generating a point-cloud with prescribed density
  • To:
  • Subject: Re: [cgal-discuss] generating a point-cloud with prescribed density
  • Date: Thu, 9 Jun 2011 09:34:48 -0400
Hi Laurent,
thanks for your kind reply. This (the bolded) is exactly what I had in mind. I am extremely grateful that you have this in 3.8, since what I had in 3.6.1 fused some boundaries that were proximate to each other (e.g. it closed separable meshing about one of the Sylvian fissures).
I am going to try the latest version, and get back to you if I run into problems tweaking the density class (which is likely :-) ).
Rest assured that if I am successful, I will mention CGAL prominently in my papers that document this effort, which may include a couple of MICCAI workshops: the Mesh Processing  and the Systems and Architectures for Computer-assisted Interventions workshops.
Warm wishes,
Michel
What do you mean by "conform to the input PLC"? The tetrahedral mesh generator
in CGAL can remesh a polyhedron and respect its sharp edges (that is new in
CGAL-3.8).
As for the density, you can create a special model of the concept
MeshCriteria_3. For a client of GeometryFactory, I have writen such a criteria
class that reads the sizing field from a 3D scalar image, and ensure that for
each tetrahedron in the meshing domain, its size is smaller than the value in
the image at the center of the tetrahedron.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
Michel Audette, Ph.D.
R & D Engineer,
Kitware Inc.,
Chapel Hill, N.C.
