cgal-discuss - Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness
  • To:
  • Subject: Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness
  • Date: Mon, 11 Jul 2011 14:57:45 +0200
Le 11/07/11 11:00, Nicholas Mario Wardhana a écrit :
Hi all,
I have a set of voxels associated to boolean values (either 0 or 1),
and I wish to generate a mesh that approximates the voxels with value
1. The '1' voxels are the result of voxelising an input surface, so
these voxels are relatively smooth (not scattered) but thin. I am able
to generate the INR file which can be properly loaded by CGAL's
surface mesher, but what confuses me is the configuration. So I would
like to ask the questions below, referencing the corresponding manual:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesher/Chapter_main.html
especially Section 46.3.
1) What is the coordinate system of the gray image? I notice that I am
required to determine its centre which is inside the surface, such
that the value of sign( f(centre) - isovalue ) = -1. Let isovalue =
0.5. I choose the centre to be the centre of an arbitrary voxel whose
value is 0. I suppose I can get sign(0 - 0.5) = -1, but instead I got
a 1. Am I right to assume that the mesher's coordinate system is
different from mine? I also notice that the INR file lacks of notion
of origin or anything related, so does it have to do with that?
Note that the coordinate system of a gray image is encoded in the image file.
You are not required to determine the center of the coordinate system.
You are just required to provide a bounding-sphere whose center
is a point inside the surface you want to mesh and whose radius is big enough
for the sphere to include the whole image.
2) Suppose I know the size of the whole voxelisation. What are the
good range estimates for the radius and centre-centre distance upper
bounds relative to the voxelisation size? I made some trial-and-error
efforts and found that the result rarely changes with different
parameters, but when it does, the change is very abrupt. For example,
there is no face generated (only point set) if I use the bounds 0.602
and 0.602, no face is generated, but if I use 0.601 and 0.601, the
algorithm produces so many faces and does not stop after a few
minutes.
The radius bound provide an upper bound on the size of the surface mesh elements.
If you decrease it, you will get a finer mesh with more and smaller elements.
So the right value is function of the size (in terms of number of elements) of the mesh
you want to generate.
The centre-centre bound controls the accuracy of the surface approximation.
It will also has an influence on the granularity of the mesh.
Beware that this parameter should not be small
compared to the precision with which
points on the level set are computed
which is be default set to 1E-03 x the bounding sphere radius.
Typically the centre-centre distance bound should be 10 times the
error bound.
3) Still related to the previous point, even if I use the same
configuration, the results might differ. Sometimes the algorithm stops
after a few seconds, sometimes it does not stop after a few minutes. I
notice somewhere (sorry I forget) that the algorithm has a random
element, but how is it possible that the results are distinctly
different?
The surface_mesher has a randomized way of computing a few initial points
on the surface : it computes intersections with the surface of random rays
casted from the center of the bounding sphere.
Depending of these initial points, different connected components
of the level set can be discovered and meshed. This might explain
what you observe.
Hope this helps.
Please let me know if more information is needed. Thank you.
Best regards,
Nicholas
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
