Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness
- To:
- Subject: Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness
- Date: Tue, 12 Jul 2011 10:53:01 +0200
Le 12/07/11 05:56, Nicholas Mario Wardhana a écrit : yes, vx,vy,vz gives the scale transform on each axis.Hi Mariette, thank you for your reply! On 11 July 2011 20:57, Mariette Yvinec wrote:Note that the coordinate system of a gray image is encoded in the image file.Which of the variables in the header corresponds to it? Are they the VX, VY, VZ variables? Because I thought they corresponded to the size of one voxel... As for the origin, I guess it is assumed to be the bottom, left, back corner so that the whole image lies in the positive octant. (I was not sure about that, but just get it from the code of triliniear_interpolation function in Image_3.h one easy test is to compute the value of the functionYou are not required to determine the center of the coordinate system. You are just required to provide a bounding-sphere whose center is a point inside the surface you want to mesh and whose radius is big enough for the sphere to include the whole image.My problem is actually in determining the centre point of the bounding sphere itself, because the point I chose (inside an arbitrary voxel with value 0) is rejected on the basis of positive sign, so I was wondering if the coordinate system of the image is different from my voxelisation. at the point you would like to be the center, just to test that the value is negative. As for the radius, as long as the centre is correct, assuming the dimension of the voxels is x times y times z, I suppose it is always safe to set the radius to sqrt(x^2 + y^2 + z^2), which is the diagonal of the dimension?The radius bound provide an upper bound on the size of the surface mesh elements. If you decrease it, you will get a finer mesh with more and smaller elements. So the right value is function of the size (in terms of number of elements) of the mesh you want to generate. The centre-centre bound controls the accuracy of the surface approximation. It will also has an influence on the granularity of the mesh. Beware that this parameter should not be small compared to the precision with which points on the level set are computed which is be default set to 1E-03 x the bounding sphere radius. Typically the centre-centre distance bound should be 10 times the error bound.Thanks Mariette for the explanation. I have been doing experiments with various precision and centre-centre bound (I prefer coarse mesh, so I have a fix 1000.0f for the radius bound). My original environment consists of two fat polyhedra: http://i.imgur.com/MVYqt.jpg , but the best result I got so far is like a very thin plate. You can see it (and the corresponding sampled points) here: http://i.imgur.com/9eHQg.jpg The points the algorithm samples seem to be concentrated in a particular area, so I am wondering whether I made a mistake here? Here is a piece of my code: // -------------------------- code starts ------------------------------------ typedef CGAL::Surface_mesh_default_triangulation_3 Tr; typedef Tr::Geom_traits GT; Gray_level_image image("data/voxel.inr", 0.9f); GT::Sphere_3 bounding_sphere(bounding_sphere_center, bounding_sphere_squared_radius); Surface_3 surface(image, bounding_sphere, 0.001f); CGAL::Surface_mesh_default_criteria_3<Tr> criteria(30., 1000.0f, 0.1f); CGAL::make_surface_mesh(c2t3, surface, criteria, CGAL::Manifold_tag()); // -------------------------- code ends ------------------------------------ Are you sure about the isovalue " 0.9f " you give to define the surface? (I don't know what is "f") One question more : It seems that you are creating an image from a set of two polyhedron and that you are trying to get a surface mesh approximating the polyhedral surfaces. Note that the Surface mesh generator has also "undocumented features" to mesh polyhedral surfaces and segmented images that might help you. I quote below the user manuel:
Another way, if you prefer documented stuff, which I can easily understand is to get the surface mesh you would like out of the Mesh_3 package. For this, it suffices to run mesh_3 with trivial criteria for cells. The surface_mesher has a randomized way of computing a few initial points on the surface : it computes intersections with the surface of random rays casted from the center of the bounding sphere. Depending of these initial points, different connected components of the level set can be discovered and meshed. This might explain what you observe. Hope this helps.I see, that seems to explain the phenomenon.-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness, Nicholas Mario Wardhana, 07/11/2011
- Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness, Mariette Yvinec, 07/11/2011
- Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness, Nicholas Mario Wardhana, 07/12/2011
- Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness, Mariette Yvinec, 07/12/2011
