Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness
- To:
- Subject: Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness
- Date: Tue, 12 Jul 2011 18:07:42 +0800
On 12 July 2011 16:53, Mariette Yvinec
wrote:
> yes, vx,vy,vz gives the scale transform on each axis.
> As for the origin, I guess it is assumed to be the bottom, left, back corner
> so that the whole image lies in the positive octant.
> (I was not sure about that, but just get it
> from the code of triliniear_interpolation function in Image_3.h
I see, I will try to use those variables and also take a look at Image_3.h .
> one easy test is to compute the value of the function
> at the point you would like to be the center,
> just to test that the value is negative.
> Are you sure about the isovalue " 0.9f " you give
> to define the surface?
> (I don't know what is "f")
Well, since I only have 0 and 1 values in the voxel, so I suppose I
can use arbitrary isovalue as long as it is between 0 and 1, right?
After all my voxel size is already small, so for me slight inaccuracy
is fine.
By the way, 'f' is used to stress that the value that I gave is a
float, not a double. I use that to prevent the accuracy-related
warning.
> One question more :
> It seems that you are creating an image from a set of two polyhedron
> and that you are trying to get a surface mesh approximating the polyhedral
> surfaces.
Actually I do not particularly target a set of polyhedra, but polygon
soup in general, which might have non-manifold topology. The one I
showed in my previous e-mail is just a simpler data set.
> Note that the Surface mesh generator has also "undocumented features" to
> mesh polyhedral surfaces
> and segmented images that might help you.
> I quote below the user manuel:
> The Polyhedron demo has a feature that allows to remesh a polyhedral
> surface, using the 3D Surface Mesh Generator. That has been implemented as a
> special model of SurfaceMeshTraits_3, for polyhedra. That traits class is
> not yet documented because its interface and code have not yet been
> stabilized. It will probably be shipped with next release of Cgal.
> The Surface Mesh Generator demo allows to mesh not only gray level images,
> but also segmented images, when voxels are labelled with a domain index.
> Such images are for example the result of a segmentation of 3D medical
> images. This feature is not yet ready to be documented in current release,
> but will probably be in next release of Cgal.
> Another way, if you prefer documented stuff, which I can easily understand
> is to get the surface mesh you would like out of the Mesh_3 package.
> For this, it suffices to run mesh_3 with trivial criteria for cells.
Ah, I think I missed this part. I will take a look into these classes.
> Mariette Yvinec
> Geometrica project team
> INRIA Sophia-Antipolis
Thank you Mariette!
Best regards,
Nicholas
- [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness, Nicholas Mario Wardhana, 07/11/2011
- Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness, Mariette Yvinec, 07/11/2011
- Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness, Nicholas Mario Wardhana, 07/12/2011
- Re: [cgal-discuss] Questions about surface mesh generation: coordinate system, criteria, randomness, Mariette Yvinec, 07/12/2011
