- To:
- Subject: [cgal-discuss] how can I create 3d mesh from surface the two surface meshes
- Date: Tue, 19 Jul 2011 08:40:25 -0700 (PDT)
I am new to cgal. It almost satisfies my needs so I am trying to make it work
in my project.
I have a complicated geometry which is composed of fine grid mesh.
I can dump it to cgal to create volume mesh, then I need outer volume mesh
of sphere which includes my object mesh. So, I would like to use surface
mesh from the object mesh for the outer space mesh.
These two can be done separately but how can I merge them ? or can I just
create outer space mesh using object surface mesh and outer space boundary
surface mesh ?
You can simply imagine a wing in the wind turnel in 3D.
| [ Object mesh ] |
[ Space domain ]
thanks..
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/how-can-I-create-3d-mesh-from-surface-the-two-surface-meshes-tp3678445p3678445.html
- [cgal-discuss] how can I create 3d mesh from surface the two surface meshes, kyungjoo, 07/19/2011
- Re: [cgal-discuss] how can I create 3d mesh from surface the two surface meshes, Mariette Yvinec, 07/19/2011
- [cgal-discuss] Re: how can I create 3d mesh from surface the two surface meshes, kyungjoo, 07/19/2011
- Re: [cgal-discuss] Re: how can I create 3d mesh from surface the two surface meshes, Mariette Yvinec, 07/19/2011
