Re: [cgal-discuss] Re: how can I create 3d mesh from surface the two surface meshes
- To:
- Subject: Re: [cgal-discuss] Re: how can I create 3d mesh from surface the two surface meshes
- Date: Tue, 19 Jul 2011 19:00:27 +0200
you cannot preserve the object mesh
but you can remesh everything, object
and outer space while using the object surface
mesh facets, edges and vertices as 2, 1 and 0
constraints.
These features may be further subdivided in he final mesh
but will be preserved. The final mesh may be overdense.
Le 19/07/11 18:42, kyungjoo a écrit :
Yes, I saw the API functions for filling the space between surfaces.
However, I also need the object mesh as well as the outer space mesh.
I would like to keep the surface mesh vertices on the object. Or when I
re-mesh the whole space, I would like to give a constraint for the object
surface. I may try to insert 0 and 1 dimension features inside so that it
could maintain the object surface. Still reading the manual and thinking
some ideas. Do you have better idea ? or could you brief about the
necessary API functions that I can refer ?
Thanks.
Mariette Yvinec wrote:
Using CGAL, you can easily create a 3D mesh filling the space
between the surface of the object and the outer surface mesh.
Note however that the bounding surfaces, i.e. the surface mesh from the
object
and the outer space boundary surface mesh are going to be remeshed.
Le 19/07/11 17:40, kyungjoo a écrit :
I am new to cgal. It almost satisfies my needs so I am trying to make it--
work
in my project.
I have a complicated geometry which is composed of fine grid mesh.
I can dump it to cgal to create volume mesh, then I need outer volume
mesh
of sphere which includes my object mesh. So, I would like to use surface
mesh from the object mesh for the outer space mesh.
These two can be done separately but how can I merge them ? or can I just
create outer space mesh using object surface mesh and outer space
boundary
surface mesh ?
You can simply imagine a wing in the wind turnel in 3D.
| [ Object mesh ] |
[ Space domain ]
thanks..
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/how-can-I-create-3d-mesh-from-surface-the-two-surface-meshes-tp3678445p3678445.html
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
http://cgal-discuss.949826.n4.nabble.com/how-can-I-create-3d-mesh-from-surface-the-two-surface-meshes-tp3678445p3678609.html
Mariette Yvinec
- [cgal-discuss] how can I create 3d mesh from surface the two surface meshes, kyungjoo, 07/19/2011
- Re: [cgal-discuss] how can I create 3d mesh from surface the two surface meshes, Mariette Yvinec, 07/19/2011
- [cgal-discuss] Re: how can I create 3d mesh from surface the two surface meshes, kyungjoo, 07/19/2011
- Re: [cgal-discuss] Re: how can I create 3d mesh from surface the two surface meshes, Mariette Yvinec, 07/19/2011
