[cgal-discuss] Re: how can I create 3d mesh from surface the two surface meshes
- To:
- Subject: [cgal-discuss] Re: how can I create 3d mesh from surface the two surface meshes
- Date: Tue, 19 Jul 2011 09:42:41 -0700 (PDT)
Yes, I saw the API functions for filling the space between surfaces.
However, I also need the object mesh as well as the outer space mesh.
I would like to keep the surface mesh vertices on the object. Or when I
re-mesh the whole space, I would like to give a constraint for the object
surface. I may try to insert 0 and 1 dimension features inside so that it
could maintain the object surface. Still reading the manual and thinking
some ideas. Do you have better idea ? or could you brief about the
necessary API functions that I can refer ?
Thanks.
Mariette Yvinec wrote:
> Using CGAL, you can easily create a 3D mesh filling the space
> between the surface of the object and the outer surface mesh.
> Note however that the bounding surfaces, i.e. the surface mesh from the
> object
> and the outer space boundary surface mesh are going to be remeshed.
> Le 19/07/11 17:40, kyungjoo a écrit :
>> I am new to cgal. It almost satisfies my needs so I am trying to make it
>> work
>> in my project.
>> I have a complicated geometry which is composed of fine grid mesh.
>> I can dump it to cgal to create volume mesh, then I need outer volume
>> mesh
>> of sphere which includes my object mesh. So, I would like to use surface
>> mesh from the object mesh for the outer space mesh.
>> These two can be done separately but how can I merge them ? or can I just
>> create outer space mesh using object surface mesh and outer space
>> boundary
>> surface mesh ?
>> You can simply imagine a wing in the wind turnel in 3D.
>> | [ Object mesh ] |
>> [ Space domain ]
>> thanks..
>> View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/how-can-I-create-3d-mesh-from-surface-the-two-surface-meshes-tp3678445p3678445.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
> Mariette Yvinec
> Geometrica project team
> INRIA Sophia-Antipolis
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
http://cgal-discuss.949826.n4.nabble.com/how-can-I-create-3d-mesh-from-surface-the-two-surface-meshes-tp3678445p3678609.html
- [cgal-discuss] how can I create 3d mesh from surface the two surface meshes, kyungjoo, 07/19/2011
- Re: [cgal-discuss] how can I create 3d mesh from surface the two surface meshes, Mariette Yvinec, 07/19/2011
- [cgal-discuss] Re: how can I create 3d mesh from surface the two surface meshes, kyungjoo, 07/19/2011
- Re: [cgal-discuss] Re: how can I create 3d mesh from surface the two surface meshes, Mariette Yvinec, 07/19/2011
