cgal-discuss - Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction
  • To:
  • Subject: Re: [cgal-discuss] Re: CGAL :: Poisson Surface Reconstruction
  • Date: Mon, 01 Aug 2011 09:35:19 +0200
Hi Marc,
I didn't notice answers to your email in the past 3 weeks. Are you still
stuck with Poisson Surface Reconstruction?
Best regards,
Laurent Saboret
Le 12/07/2011 10:11, Marc Klopfenstein a écrit :
Thanks for you help, but the problem isn't solved.
I took the 752_bimba_1Mfaces_noautointersect.off file on the website and put
the point set in a .xyz file.
I run the Point_set_processing_3/normals_example.cpp to generate the
normal’s and saved it again in a .xyz file. Result: 500 000 points.
Finally I run the
Surface_reconstruction_points_3/poisson_reconstruction_example.cpp in which
I just added a point set simplification.
It works well whit less than 200 000 point, above I have the message error
(Error: cannot solve Poisson equation) Why, you can run it much more points
(documentation)? In the source I see a CGAL_TRACE, how can I activate it, to
have more indication?
When I use my point set (average spacing: 25) it works also whit less than
200 000 points and above I have directly a crash in taucs. Why did I have
such a gap between my application (200k points) and yours (1.3M points)?
Thanks,
Marc
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Poisson-Surface-Reconstruction-tp3616368p3661702.html
